2010-08-12, 01:57
> PASTEBIN LINK <
(please help)
I am having a terrible time trying to add some TV shows to my library. A little background, I am using the latest version of XBMC (August 11th build), and the latest version of Media Companion.
The problem persists whether I use Media Companion to tag my shows or not. It also occurs on a number of TV shows(I have tested 7 already).
Folders are set up like this:
W:\Television\Cougar Town
-----------------\Cougar Town S01E01 Pilot 720p WEB-DL h.264.mkv
-----------------\Cougar Town S01E01 Pilot 720p WEB-DL h.264.nfo
-----------------\Cougar Town S01E01 Pilot 720p WEB-DL h.264.tbn
as well as:
W:\Television\30 Rock 720p WEB-DL DD5.1 AVC
-----------------\Season 1
-------------------------\30 Rock S01E01.mkv
-------------------------\30 Rock S01E01.nfo
-------------------------\30 Rock S01E01.tbn
No matter how I name the files/folders the TV shows are not added to the library. When adding say, Cougar Town, I set content to TV Shows, scraped by TVDB.com, automatic scan, folder contains single show. (I have also tried every possible option scenario when setting content).
The dialog box then tells me that it is scraping the TV shows. It will say "Pilot" followed shortly by "1x1 Pilot" and so on.
It then compresses the database and all is supposed to be good to go. However, when then going to TV Shows the new show is not there??
When trying to add 30 Rock it doesn't even attempt to scrape the episodes, it simply goes to "Compressing Database" and thats it.
I have tried deleting all NFOs created my Media Companion from the television show folders, and even scraping new shows that Media Companion hasn't even touched. I have also used different naming formats (S01E02, 01x02, 1x2, etc. etc.) all nothing..
I have searched the forum as well as Google for the past two days and have found nothing that will cure this problem. I have deleted my video db file from the AppData folder as well as deleted the Cache folder all together. Also, I tried 5+ versions of XBMC and 2 other verions of Media Companion, still no go!
Would someone please help me
(please help)
as well as:
