The
interlace button in the video OSD, during tuxbox streaming, does not work/change.....
Any idea....
Should I set it up somewhere else, before starting the streaming
what system are you on? are you doing hw accelleration.. and so on.. -> post a debug log
hi...
have just found out that if I'm on Hardware acceleration (DXVA2)...it does NOT let me deinterlace.
If I'm NOT...then it let me.....
Why is it like this....
I still see the need to deinterlace some sky channels, even with dxva2 enabled...
Can someone put some light on this tech issue
Is it normal ?
Thanks everyone
dxva2 decoding does not support deinterlacing at the moment
got it
Ok then .... this means I wont use dxva2....
But... Do you know how to make PERMANENT DEINTERLACING when I watch TUXBOX streams (dreambox)
If I set it up for the actual channel Im watching.....it won't stay if I change channel
So do I have to set it for EACH channel I watch
Please tell me noooo
