2010-08-16, 13:49
Hi there!
I'm having a bit of trouble with scanning TV-series into my library. I've got two main issues, which I can't really fix by myself.
#1:
I've sorted all of my series by seasons in separated foders. For example (path):
Series1\Season 1\01. Episodename 1.mkv
The problem seems to be the correct naming of the files. I've read the wiki, but even my test runs with the pattern Series1\s01e01.mkv did not succed.
The name of the series is displayed in the library, but the files are not listed under the name. No matter what filename I try!
Is it possible, to use my name pattern to get the series into my library? I don't want to rename every single episode.
#2:
Some series are stored in english, some in german. The filenames all differ by the different language. But the library (it worked for online one series) lists the complete series in the main language, as selected in xbmc setup.
Is it possible to store one season in english and another in german?
Thank you, for your help!
#1:
#2:
