i know its early but does anyone have any recommendations for spash screens....or have made some?
-matt
same here,
i never see the splash screen. how can i see it ? is there any option in .xml ?
thx.
no option.. you need to be running a later build.
- 21-11-2004 added: startup splash
at least one from the 21st of november.
ts
thanks quick reply tslayer.
i use 30-11-2004 cvs compiled version but it never shows me splash screen.
my setting is 720p with hdtv.
any hint?
:verysad:
ps. can i see a screenshot of splash screen?
it should work in your version. unless the version you d/led did not contain the splash.png.
anyhow, the splash is located here:
http://cvs.sourceforge.net/viewcvs....ew=auto
take that and place it in your xbmc/media folder on your xbox.
ts
i got it!!
thanks again tslayer.
i cant fill the screen with the spash screen what is the res locked 2 please
and y not have it at the screen size
it auto resizes it if its screen size to be half screen size centered
i would like a full screen splash too?
