2010-08-17, 22:11
I must be doing something fundamentally wrong. I can't get the Tetris script to run.
I've installed XBMC Camelot 9.11 (current stable release) and downloaded the Tetris script from http://code.google.com/p/xbmc-scripting/downloads/list, extracting it to %APPDATA%\XBMC\scripts\Tetris. I also tried installing through SVN and got the same results.
I used the default install options and skin and haven't installed any other options or plugins.
When I try to run the script from XBMC's scripts menu, it says "Tetris (Running)" for a few seconds, nothing happens and then it reverts to saying "Testris".
Running XP Professional SP3, IBM Thinkpad T43, ATI Mobility Radeon 7500 1GB RAM
log here: http://pastebin.com/hudqXQA4
I recall having the same problem with the same version for Linux, on a much more recent intel platform, so I'm certain it's something I'm doing or not doing, rather than a bug.
I've tried searching here but surprisingly couldn't find anyone with the same problem.
Advice appreciated
Advice appreciated
