2010-08-18, 18:45
How to upgrade to Nvidia 256.xx Drivers as of now the current driver for the 32 bit system is 256.44
go to the Nvidia site and find the latest driver to a driver you want download or roll back to.
http://www.nvidia.com/Download/Find.aspx
find the driver of choice you want to download and right click on the file and copy the URL of the file it should look some thing like this
for this example I am going to use putty
open putty and type the following replace the url to the driver of choice you copied
now you need to stop xbmc before installing or you will get an error about X running
so type this
now you want to install the driver
your going to type in the exact file name of the driver you downloaded
click ok, yes, etc,
to start xbmc again type
maybe this can get moved to tips / tricks if mods find it useful
-=Jason=-
http://us.download.nvidia.com/XFree86/Linux-x86/260.19.12/NVIDIA-Linux-x86-260.19.12.run
wget http://us.download.nvidia.com/XFree86/Linux-x86/260.19.12/NVIDIA-Linux-x86-260.19.12.run
so type this
sudo stop xbmc-live
sudo sh NVIDIA-Linux-x86-260.19.12.run
click ok, yes, etc,
sudo start xbmc-live
-=Jason=-
