2010-08-19, 23:37
Hello,
It s my 2nd installation of Lucid 64 2.6.35 and everytime I launch xbmc it crashes. Unfortunately I was not able to find what was the issue (even googling).
Here is the output of the crash in case someone can provide some help.
THanks
XabiX
################ SYSTEM INFO ################
Date: jeudi 19 août 2010, 23:23:51 (UTC+0200)
XBMC Options:
Arch: x86_64
Kernel: Linux 2.6.35-020635-generic #020635 SMP Mon Aug 2 09:08:21 UTC 2010
Release:
Distributor ID: Ubuntu
Description: Ubuntu 10.04.1 LTS
Release: 10.04
Codename: lucid
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====> Core file: /home/xabix/core
[New Thread 19370]
[New Thread 19382]
[New Thread 19380]
[New Thread 19379]
[New Thread 19381]
Core was generated by `/usr/share/xbmc/xbmc.bin'.
Program terminated with signal 11, Segmentation fault.
#0 0x0000000000a4e896 in CGUIFontTTFGL::Begin() ()
Thread 5 (Thread 19381):
#0 0x00007f561eb17f83 in poll () from /lib/libc.so.6
#1 0x00007f561f9c3c60 in ?? () from /lib/libdbus-1.so.3
#2 0x00007f561f9c206d in ?? () from /lib/libdbus-1.so.3
#3 0x00007f561f9ae59e in ?? () from /lib/libdbus-1.so.3
#4 0x00007f561f9b06b0 in ?? () from /lib/libdbus-1.so.3
#5 0x0000000000696871 in DBUSSERVER::CDbusServer::Run() ()
#6 0x0000000000673f0f in CThread::staticThread(void*) ()
#7 0x00007f5623c939ca in start_thread () from /lib/libpthread.so.0
#8 0x00007f561eb246fd in clone () from /lib/libc.so.6
#9 0x0000000000000000 in ?? ()
Thread 4 (Thread 19379):
#0 0x00007f5623c9c11d in nanosleep () from /lib/libpthread.so.0
#1 0x00000000005ea7c7 in Sleep(unsigned int) ()
#2 0x0000000000a7f0cc in XBPyThread::Process() ()
#3 0x0000000000673f0f in CThread::staticThread(void*) ()
#4 0x00007f5623c939ca in start_thread () from /lib/libpthread.so.0
#5 0x00007f561eb246fd in clone () from /lib/libc.so.6
#6 0x0000000000000000 in ?? ()
Thread 3 (Thread 19380):
#0 0x00007f561eb1cfe3 in select () from /lib/libc.so.6
#1 0x0000000000688191 in SOCKETS::CSocketListener::Listen(int) ()
#2 0x0000000000681cb6 in EVENTSERVER::CEventServer::Run() ()
#3 0x0000000000681f58 in EVENTSERVER::CEventServer::Process() ()
#4 0x0000000000673f0f in CThread::staticThread(void*) ()
#5 0x00007f5623c939ca in start_thread () from /lib/libpthread.so.0
#6 0x00007f561eb246fd in clone () from /lib/libc.so.6
#7 0x0000000000000000 in ?? ()
Thread 2 (Thread 19382):
#1 0x00007f562637c4da in ?? () from /usr/lib/libavahi-common.so.3
#2 0x00007f562637b02e in avahi_simple_poll_run () from /usr/lib/libavahi-common.so.3
#3 0x00007f562637b7ad in avahi_simple_poll_iterate () from /usr/lib/libavahi-common.so.3
#4 0x00007f562637b7dd in avahi_simple_poll_loop () from /usr/lib/libavahi-common.so.3
#5 0x00007f562637c32c in ?? () from /usr/lib/libavahi-common.so.3
#6 0x00007f5623c939ca in start_thread () from /lib/libpthread.so.0
#7 0x00007f561eb246fd in clone () from /lib/libc.so.6
#8 0x0000000000000000 in ?? ()
Thread 1 (Thread 19370):
#1 0x0000000000a420b5 in CGUITextLayout::Render(float, float, float, unsigned int, unsigned int, unsigned int, float, bool) ()
#2 0x00000000009bcca0 in CGUIButtonControl::RenderText() ()
#3 0x00000000009bcaf5 in CGUIButtonControl::Render() ()
#4 0x00000000009c6ed3 in CGUIControl::DoRender(unsigned int) ()
#5 0x0000000000a1a645 in CGUIWindow::Render() ()
#6 0x0000000000a1fcd1 in CGUIWindowManager::Render_Internal() ()
#7 0x00000000006bdf63 in CApplication::DoRender() ()
#8 0x00000000008e40fa in CApplicationRenderer::Render(bool) ()
#9 0x00000000006b6311 in CApplication::Render() ()
#10 0x00000000008d66dd in CXBApplicationEx::Run() ()
#11 0x00000000008d6e3a in main ()
############# END STACK TRACE ###############
################# LOG FILE ##################
23:23:48 T:140007993440288 M:1365008384 NOTICE: -----------------------------------------------------------------------
23:23:48 T:140007993440288 M:1365008384 NOTICE: Starting XBMC, Platform: GNU/Linux. Built on Aug 19 2010 (SVN:26018)
23:23:48 T:140007993440288 M:1365008384 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
23:23:48 T:140007993440288 M:1365008384 NOTICE: special://masterprofile/ is mapped to: /home/xabix/.xbmc/userdata
23:23:48 T:140007993440288 M:1365008384 NOTICE: special://home/ is mapped to: /home/xabix/.xbmc
23:23:48 T:140007993440288 M:1365008384 NOTICE: special://temp/ is mapped to: /home/xabix/.xbmc/temp
23:23:48 T:140007993440288 M:1365008384 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
23:23:48 T:140007993440288 M:1365008384 NOTICE: Log File is located: /home/xabix/.xbmc/temp/xbmc.log
23:23:48 T:140007993440288 M:1364103168 NOTICE: Setup SDL
23:23:49 T:140007993440288 M:1366257664 NOTICE: load settings...
23:23:49 T:140007993440288 M:1366257664 NOTICE: special://profile/ is mapped to: special://masterprofile/
23:23:49 T:140007993440288 M:1366257664 NOTICE: loading special://masterprofile/guisettings.xml
23:23:49 T:140007993440288 M:1366319104 ERROR: Unable to load special://masterprofile/guisettings.xml, creating new special://masterprofile/guisettings.xml with default values
23:23:49 T:140007993440288 M:1366126592 NOTICE: Getting hardware information now...
23:23:49 T:140007993440288 M:1366126592 NOTICE: Checking resolution 12
23:23:49 T:140007993440288 M:1366315008 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
23:23:49 T:140007993440288 M:1366315008 NOTICE: Loaded playercorefactory configuration
23:23:49 T:140007993440288 M:1366315008 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
23:23:49 T:140007993440288 M:1366315008 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
23:23:49 T:140007993440288 M:1366315008 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
23:23:49 T:140007993440288 M:1366315008 NOTICE: Default DVD Player: dvdplayer
23:23:49 T:140007993440288 M:1366315008 NOTICE: Default Video Player: dvdplayer
23:23:49 T:140007993440288 M:1366315008 NOTICE: Default Audio Player: paplayer
23:23:49 T:140007993440288 M:1366315008 NOTICE: special://masterprofile/sources.xml
23:23:50 T:140007993440288 M:1363226624 NOTICE: Using fbConfig[0]
23:23:50 T:140007993440288 M:1360019456 NOTICE: GL_VENDOR = Tungsten Graphics, Inc
23:23:50 T:140007993440288 M:1360019456 NOTICE: GL_RENDERER = Mesa DRI Intel® IGDNG_D GEM 20091221 2009Q4
23:23:50 T:140007993440288 M:1360019456 NOTICE: GL_VERSION = 2.1 Mesa 7.7.1
23:23:50 T:140007993440288 M:1360019456 NOTICE: GL_EXTENSIONS = GL_EXT_compiled_vertex_array GL_EXT_texture_env_add GL_ARB_copy_buffer GL_ARB_depth_texture GL_ARB_depth_clamp GL_ARB_draw_buffers GL_ARB_draw_elements_base_vertex GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_half_float_pixel GL_ARB_map_buffer_range GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_seamless_cube_map GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_shading_language_120 GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_logic_op GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_cull_vertex GL_EXT_copy_texture GL_EXT_draw_range_elements GL_EXT_framebuffer_blit GL_EXT_framebuffer_object GL_EXT_fog_coord GL_EXT_gpu_program_parameters GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_polygon_offset GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_subtexture GL_EXT_texture GL_EXT_texture3D GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_swizzle GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_3DFX_texture_compression_FXT1 GL_APPLE_client_storage GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ATI_blend_equation_separate GL_ATI_envmap_bumpmap GL_ATI_texture_env_combine3 GL_ATI_separate_stencil GL_IBM_multimode_draw_arrays GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_INGR_blend_func_separate GL_MESA_pack_invert GL_MESA_texture_signed_rgba GL_MESA_ycbcr_texture GL_MESA_window_pos GL_NV_blend_square GL_NV_depth_clamp GL_NV_light_max_exponent GL_NV_packed_depth_stencil GL_NV_texture_env_combine4 GL_NV_texture_rectangle GL_NV_texgen_reflection GL_NV_vertex_program GL_NV_vertex_program1_1 GL_OES_read_format GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays
23:23:50 T:140007993440288 M:1360019456 ERROR: GLX: Same window as before, refreshing context
THanks
XabiX
XBMC Options:
Arch: x86_64
Release:
Release: 10.04
Codename: lucid
[New Thread 19370]
[New Thread 19382]
[New Thread 19380]
[New Thread 19379]
[New Thread 19381]
