Full Version: Help with New PC Windows 7
Upgraded my PC and have version 3.0 installed and media will not play just sits at Process-scraping. Been reading through the forums here and downloaded the latest vid files from intel site and installed those but that did not help.
Tried even turning off fire wall .
Is there some settings I can check? Or maybe I need to update to newer version?
Running windows 7 64bit I can put up more info on my PC if needed .
Any help would be awesome.Smile
...What?
Version 3.0 of WHAT installed? Post a debug log so that we can see some of what is going on.
Says this:o Running XBMC 3.0
Quote:22:04:53 T:3592 M:3074764800 NOTICE: -----------------------------------------------------------------------
22:04:53 T:3592 M:3074760704 NOTICE: Starting XBMC, Platform: Windows build 7600. Built on Oct 19 2009 (SVN:23832, compiler 1500)
22:04:53 T:3592 M:3074760704 NOTICE: Pentium® Dual-Core CPU E5500 @ 2.80GHz
22:04:53 T:3592 M:3074756608 NOTICE: Desktop Resolution: 1920x1080 32Bit at 59Hz
22:04:53 T:3592 M:3074756608 NOTICE: Running with restricted rights
22:04:53 T:3592 M:3074756608 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\XBMC
22:04:53 T:3592 M:3074756608 NOTICE: special://masterprofile/ is mapped to: C:\Users\Abet\AppData\Roaming\XBMC\userdata
22:04:53 T:3592 M:3074756608 NOTICE: special://home/ is mapped to: C:\Users\Abet\AppData\Roaming\XBMC
22:04:53 T:3592 M:3074756608 NOTICE: special://temp/ is mapped to: C:\Users\Abet\AppData\Roaming\XBMC\cache
22:04:53 T:3592 M:3074756608 NOTICE: The executable running is: C:\Program Files (x86)\XBMC\XBMC.exe
22:04:53 T:3592 M:3074756608 NOTICE: Log File is located: C:\Users\Abet\AppData\Roaming\XBMC\xbmc.log
22:04:53 T:3592 M:3074756608 NOTICE: -----------------------------------------------------------------------
22:04:53 T:3592 M:3074801664 NOTICE: Setup SDL
22:04:53 T:3592 M:3072638976 NOTICE: load settings...
22:04:53 T:3592 M:3072626688 NOTICE: special://profile/ is mapped to: special://masterprofile/
22:04:53 T:3592 M:3072622592 NOTICE: loading special://masterprofile/guisettings.xml
22:04:53 T:3592 M:3071787008 NOTICE: Getting hardware information now...
22:04:53 T:3592 M:3071787008 NOTICE: Checking resolution 12
22:04:53 T:3592 M:3071782912 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
22:04:53 T:3592 M:3071774720 NOTICE: Loaded playercorefactory configuration
22:04:53 T:3592 M:3071774720 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
22:04:53 T:3592 M:3071774720 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
22:04:53 T:3592 M:3071774720 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
22:04:53 T:3592 M:3071774720 NOTICE: Default DVD Player: dvdplayer
22:04:53 T:3592 M:3071774720 NOTICE: Default Video Player: dvdplayer
22:04:53 T:3592 M:3071774720 NOTICE: Default Audio Player: paplayer
22:04:53 T:3592 M:3071770624 NOTICE: special://masterprofile/sources.xml
22:04:54 T:3592 M:3053445120 NOTICE: GL_VENDOR = Intel
22:04:54 T:3592 M:3053445120 NOTICE: GL_RENDERER = Intel® G45/G43 Express Chipset
22:04:54 T:3592 M:3053445120 NOTICE: GL_VERSION = 2.1.0 - Build 8.15.10.2141
22:04:54 T:3592 M:3053445120 NOTICE: GL_EXTENSIONS = GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_blend_color GL_EXT_abgr GL_EXT_texture3D GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_SGIS_texture_edge_clamp GL_SGIS_generate_mipmap GL_EXT_draw_range_elements GL_SGIS_texture_lod GL_EXT_rescale_normal GL_EXT_packed_pixels GL_EXT_texture_edge_clamp GL_EXT_separate_specular_color GL_ARB_multitexture GL_EXT_texture_env_combine GL_EXT_bgra GL_EXT_blend_func_separate GL_EXT_secondary_color GL_EXT_fog_coord GL_EXT_texture_env_add GL_ARB_texture_cube_map GL_ARB_transpose_matrix GL_ARB_texture_env_add GL_IBM_texture_mirrored_repeat GL_EXT_multi_draw_arrays GL_NV_blend_square GL_ARB_texture_compression GL_3DFX_texture_compression_FXT1 GL_EXT_texture_filter_anisotropic GL_ARB_texture_border_clamp GL_ARB_point_parameters GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_env_crossbar GL_EXT_texture_compression_s3tc GL_ARB_shadow GL_ARB_window_pos GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_ARB_vertex_program GL_EXT_texture_rectangle GL_ARB_fragment_program GL_EXT_stencil_two_side GL_ATI_separate_stencil GL_ARB_vertex_buffer_object GL_EXT_texture_lod_bias GL_ARB_occlusion_query GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_non_power_of_two GL_ARB_vertex_shader GL_NV_texgen_reflection GL_ARB_point_sprite GL_EXT_blend_equation_separate GL_ARB_depth_texture GL_ARB_texture_rectangle GL_ARB_draw_buffers GL_ARB_color_buffer_float GL_ARB_half_float_pixel GL_ARB_texture_float GL_ARB_pixel_buffer_object GL_EXT_framebuffer_object GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_EXT_draw_buffers2 GL_WIN_swap_hint GL_EXT_texture_sRGB GL_EXT_packed_float GL_EXT_texture_shared_exponent GL_ARB_texture_rg GL_ARB_texture_compression_rgtc GL_NV_conditional_render GL_EXT_texture_swizzle GL_ARB_framebuffer_sRGB GL_EXT_packed_depth_stencil GL_ARB_depth_buffer_float GL_EXT_transform_feedback GL_EXT_framebuffer_blit GL_ARB_vertex_array_object
22:04:55 T:3592 M:3051814912 NOTICE: initializing playlistplayer
22:04:55 T:3592 M:3051806720 NOTICE: DONE initializing playlistplayer
22:04:55 T:3592 M:3051798528 NOTICE: load default skin:[Confluence]
22:04:55 T:3592 M:3047936000 ERROR: Can't open the database MyVideos34.db as it is a NEWER version than what we were expecting!
22:04:55 T:3592 M:3047931904 ERROR: Can't open the database MyVideos34.db as it is a NEWER version than what we were expecting!
22:04:55 T:3592 M:3047927808 ERROR: Can't open the database MyVideos34.db as it is a NEWER version than what we were expecting!
22:04:56 T:3592 M:3045216256 NOTICE: CApplication::UpdateLibraries - Starting video library startup scan
22:04:56 T:3592 M:3045191680 ERROR: Can't open the database MyVideos34.db as it is a NEWER version than what we were expecting!
22:04:56 T:3592 M:3045216256 NOTICE: initialize done
22:04:56 T:3592 M:3045216256 NOTICE: Running the application...
22:04:56 T:3688 M:3045150720 ERROR: Can't open the database MyVideos34.db as it is a NEWER version than what we were expecting!
22:04:56 T:3688 M:3045158912 NOTICE: My Videos: Scanning for video info using worker thread, operation took 00:00
22:04:56 T:3592 M:3045142528 NOTICE: ES: Starting event server
22:04:56 T:3700 M:3045138432 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
22:04:56 T:3700 M:3045126144 NOTICE: UDP: Listening on port 9777
22:04:56 T:3592 M:3045109760 ERROR: GL: Vertical Blank Syncing unsupported
22:04:56 T:3592 M:3041062912 ERROR: Can't open the database MyVideos34.db as it is a NEWER version than what we were expecting!
22:04:56 T:3592 M:3040940032 ERROR: Can't open the database MyVideos34.db as it is a NEWER version than what we were expecting!
22:04:56 T:3592 M:3040878592 ERROR: Can't open the database MyVideos34.db as it is a NEWER version than what we were expecting!
22:04:56 T:3592 M:3040571392 ERROR: Can't open the database MyVideos34.db as it is a NEWER version than what we were expecting!
22:04:56 T:3592 M:3040079872 ERROR: Can't open the database MyVideos34.db as it is a NEWER version than what we were expecting!
22:04:56 T:3592 M:3039711232 ERROR: Can't open the database MyVideos34.db as it is a NEWER version than what we were expecting!
22:04:56 T:3592 M:3038728192 ERROR: Can't open the database MyVideos34.db as it is a NEWER version than what we were expecting!
22:04:56 T:3592 M:3038236672 ERROR: Can't open the database MyVideos34.db as it is a NEWER version than what we were expecting!
22:04:56 T:3592 M:3038175232 ERROR: Can't open the database MyVideos34.db as it is a NEWER version than what we were expecting!
22:04:56 T:3592 M:3037265920 ERROR: Can't open the database MyVideos34.db as it is a NEWER version than what we were expecting!
2:05:01 T:3832 M:3022925824 NOTICE: -->Python Interpreter Initialized<--
22:05:05 T:3592 M:3018022912 ERROR: Texture manager unable to load file: C:\Users\Abet\AppData\Roaming\XBMC\scripts\Navi-X\images\icon_window.png
22:05:20 T:3592 M:2946359296 ERROR: Texture manager unable to load file: C:\Users\Abet\AppData\Roaming\XBMC\scripts\Navi-X\\none
22:05:22 T:3592 M:2945679360 ERROR: Texture manager unable to load file: C:\Users\Abet\AppData\Roaming\XBMC\scripts\Navi-X\\none
22:05:34 T:3592 M:3160080384 ERROR: Can't open the database MyVideos34.db as it is a NEWER version than what we were expecting!
22:05:34 T:3592 M:3160055808 NOTICE: DVDPlayer: Opening: http://78.159.107.115/videos/0055/0068/A..._Occor.avi
22:05:34 T:3592 M:3160051712 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
22:05:34 T:3360 M:3160039424 NOTICE: Creating InputStream
22:05:34 T:3360 M:3144302592 NOTICE: Creating Demuxer
First off, you're not running version 3.0, you're running build 23832. Upgrade to the latest build (http://mirrors.xbmc.org/nightlies/win32/...Dharma.exe). Now, I may be wrong, but that error makes me think that you're trying to use a database from a newer build of XBMC than what you have installed. Try upgrading to the version I linked you to and trying then and see what happens.
EDIT: Also, for the record, I see NOTHING even mentioning a version 3.0. Where are you getting that information from?
From what I am reading that error comes from installing an old version over a new version.
I did install xbmc 9.11 from the main site but it did not have navi-x in it so I installed an older version I had XBMCSetup-Rev23863-gl and it seemed like the two combined.
Going to try to uninstall everything.
dodge Wrote:From what I am reading that error comes from installing an old version over a new version.
What exactly is Navi-X? Also, NEVER install an old version over a newer one. It NEVER works properly.
I don't know if we are suppose to discuss the Navi-x or not here. It would be under scripts where movie lists are.
Uninstalled everything and re installed XBMCSetup-Rev23863-gl still same issue No vid will play says Process-scraping.
dodge Wrote:Uninstalled everything and re installed XBMCSetup-Rev23863-gl still same issue No vid will play says Process-scraping.
Did you get rid of the old database and re-scan everything? If not, it's likely still using the newer database.
Just uninstalled everything.
Where does XBMC out the DB at? Program files somewhere?
I could prob use that version you posted I just need to figure out where to install a folder with the N*vi script in it so it will run in that newer version.
Got it going, I had to locate the DB and delete it then I uninstalled everything and reinstalled 9.11 and then located the script folder and placed the most current version of the script in I have have been trying to get to work and that seems to have done the trick.
Thanks for your help..Smile
