2010-08-22, 00:08
Hi, trying to build Dharma (which I have earlier had success with) I now get this -- Ubuntu Hardy on an ATV:
make[1]: Leaving directory `/home/atv/dev/Dharma/xbmc/cores/dvdplayer/Codecs/libdvd'
make -C lib/libass/xbmc
make[1]: Entering directory `/home/atv/dev/Dharma/lib/libass/xbmc'
make -C ..
make[2]: Entering directory `/home/atv/dev/Dharma/lib/libass'
make all-recursive
make[3]: Entering directory `/home/atv/dev/Dharma/lib/libass'
Making all in libass
make[4]: Entering directory `/home/atv/dev/Dharma/lib/libass/libass'
/bin/bash ../libtool --tag=CC --mode=compile gcc -DHAVE_CONFIG_H -I. -I.. -Wall -fPIC -DPIC -D_REENTRANT -D_LARGEFILE64_SOURCE -D_FILE_OFFSET_BITS=64 -DNDEBUG=1 -O2 -I/usr/include/freetype2 -MT ass.lo -MD -MP -MF .deps/ass.Tpo -c -o ass.lo ass.c
../libtool: line 827: X--tag=CC: command not found
../libtool: line 860: libtool: ignoring unknown tag : command not found
../libtool: line 827: X--mode=compile: command not found
../libtool: line 994: *** Warning: inferring the mode of operation is deprecated.: command not found
../libtool: line 995: *** Future versions of Libtool will require --mode=MODE be specified.: command not found
../libtool: line 1138: Xgcc: command not found
../libtool: line 1138: X-DHAVE_CONFIG_H: command not found
../libtool: line 1138: X-I.: command not found
../libtool: line 1138: X-I..: command not found
../libtool: line 1138: X-Wall: command not found
../libtool: line 1138: X-fPIC: command not found
../libtool: line 1138: X-DPIC: command not found
../libtool: line 1138: X-D_REENTRANT: command not found
../libtool: line 1138: X-D_LARGEFILE64_SOURCE: command not found
../libtool: line 1138: X-D_FILE_OFFSET_BITS=64: command not found
../libtool: line 1138: X-DNDEBUG=1: command not found
../libtool: line 1138: X-O2: command not found
../libtool: line 1138: X-I/usr/include/freetype2: No such file or directory
../libtool: line 1138: X-MT: command not found
../libtool: line 1138: Xass.lo: command not found
../libtool: line 1138: X-MD: command not found
../libtool: line 1138: X-MP: command not found
../libtool: line 1138: X-MF: command not found
../libtool: line 1138: X.deps/ass.Tpo: No such file or directory
../libtool: line 1138: X-c: command not found
../libtool: line 1191: Xass.lo: command not found
../libtool: line 1196: libtool: compile: cannot determine name of library object from `': command not found
make[4]: *** [ass.lo] Error 1
make[4]: Leaving directory `/home/atv/dev/Dharma/lib/libass/libass'
make[3]: *** [all-recursive] Error 1
make[3]: Leaving directory `/home/atv/dev/Dharma/lib/libass'
make[2]: *** [all] Error 2
make[2]: Leaving directory `/home/atv/dev/Dharma/lib/libass'
make[1]: *** [../libass/.libs/libass.so] Error 2
make[1]: Leaving directory `/home/atv/dev/Dharma/lib/libass/xbmc'
make: *** [dvdpcodecs] Error 2
atv@atv:~/dev$
