Full Version: [depricated] old YouTube Plugin - XBMC 13.0 Frodo/Gotham only
can youtube videos be saved as a smart playlist??
i can get it to save but the youtube video's do not play
thanks
NaDs Wrote:can youtube videos be saved as a smart playlist??
thanks
I actually don't know what a smart playlist is.
Is it a file? Can you upload the content of the file?
TobiasTheCommie Wrote:I actually don't know what a smart playlist is.
the real reason behind it was to get away from the number of videos on page
i have it set to
number of video's on page = 50
is there any way to have that set to unlimited in the youtube app so that there is no button to click on "more results"
i have like 800 songs in a playlist, and can only have like 50 on each page
would be great to be able to scroll without clicking more results
thanks
Strange, I don't have this issue with any other user, but the bulk of videos on channel 4 do not play for me. No issues on my laptop. Anyone else have this issue?
http://www.youtube.com/user/channel4
NaDs Wrote:the real reason behind it was to get away from the number of videos on page
i have it set to
thanks
No, this isn't really doable. It would take many minutes to load the list, and it would take even longer because youtube would throttle you even further.
So on many levels this isn't really doable.
vijayk416 Wrote:Strange, I don't have this issue with any other user, but the bulk of videos on channel 4 do not play for me. No issues on my laptop. Anyone else have this issue?
You need an updated librtmp that supports handshake type 10.
Such a version does not exist yet. All you, and we, can do is wait.
If you use the dedicated 4oD that works. Their own servers use handshake type 9, which is supported.
2.7.0 seems to work 100% for me using a very recent XBMC nightly, except for one drawback: it takes a much longer time to load lists of videos than 2.1.2 does. Around 20 seconds or so...
Anyone else experiencing this?
cptmarginal Wrote:2.7.0 seems to work 100% for me using a very recent XBMC nightly, except for one drawback: it takes a much longer time to load lists of videos than 2.1.2 does. Around 20 seconds or so...
That should be the other way around.
http://code.google.com/p/youtubexbmc/wik...llDebugLog
OK, here's the (giant) log of me going to My Favorites, then going to a list of related videos. Both lists loaded slowly
http://pastesite.com/28315
TobiasTheCommie Wrote:If you use the dedicated 4oD that works. Their own servers use handshake type 9, which is supported.
I didn't know such a thing existed for XBMC. Can you tell me were it is?
Cheers,
Simon.
Well I've tried and tried.
I can't get this plugin to play a single or any video. :|
Plugin v2.7 (Repo), last nights XBMC SVN pre-eden.
I read the last 10 pages of this topic. Can't figure it out.
Here is my LOG hopefully someone can help me!
http://pastebin.com/EztMffzi
Hope it's not something silly :p
- MiLO83
Can't get the plugin to work also.
I'm running a OpenElec setup and version 2.7.0 is/was installed.
When i try to login it keeps coming back with failed.
Here is log:
http://pastebin.com/TYSTJk4s
TobiasTheCommie Wrote:You need an updated librtmp that supports handshake type 10.
I'm confused. Isn't this all going through youtube? If so, would this problem exist for all youtube videos? Does youtube operate on different platforms? Sorry for the noob questions. Eek
Hi can somebody help me plzzzzzzz i had 2.1.0 installed worked fine updated to 2.7.0
and i get script failed plugin video youtube....i like the features of 2.7.0 to play all videos in a playlist
here is a debug file
http://pastebin.com/GhNkYtwd
This idea must have been suggested before ?
Would it be possible to add a symbol next to or overlaying video thumbnail or some text label showing if video is (for example) SD or HD ?
would it be possible to add yt3d:enable=true capability in configuration ?
it would allow to watch 3d movies ie. using anaglyph glasses
