CrazyCoder Wrote:2.9.0 version for pre-eden builds if you can't wait until repository is updated:
http://swnet.spb.ru/files/xbmc-addons.zip
(includes all the required dependencies, tested on Windows with XBMC Eden beta2 build).
Installed on Eden Beta 2, Win7 64. Just unzipped in Addons dir with overwrite existing.
Videos now stream play, but won't "download video". Popup just sits at "Preparing download".
errors from log:
Several instances of :
21:29:31 T:7728 ERROR: ADDON: extension 'downloader\' is not currently supported for service addon
21:31:01 T:4632 NOTICE: -->Python Interpreter Initialized<--
21:31:01 T:4632 NOTICE: YouTube-2.9.0
21:31:01 T:4632 NOTICE: CommonFunctions-0.9.1
21:31:01 T:4632 ERROR: ADDON: extension 'downloader\' is not currently supported for service addon
21:31:03 T:1248 ERROR: Previous line repeats 1 times.
21:31:03 T:1248 ERROR: C:\Users\West\AppData\Roaming\XBMC\addons\script.module.simple.downloader\lib\DialogDownloadProgress.py:136: DeprecationWarning: object.__init__() takes no parameters
xbmcgui.WindowXMLDialog.__init__(self, *args, **kwargs)
21:31:03 T:7728 ERROR: CLocalizeStrings::ClearBlock: Trying to clear non existent block C:\Users\West\AppData\Roaming\XBMC\addons\script.module.simple.downloader
21:31:04 T:1248 ERROR: Exception in thread Thread-1:
File "C:\Program Files (x86)\XBMC\system\python\Lib\threading.py", line 532, in __bootstrap_inner
self.run()
File "C:\Program Files (x86)\XBMC\system\python\Lib\threading.py", line 484, in run
self.__target(*self.__args, **self.__kwargs)
File "C:\Users\West\AppData\Roaming\XBMC\addons\script.module.simple.downloader\lib\SimpleDownloader.py", line 125, in _startDownload
self._processQueue()
File "C:\Users\West\AppData\Roaming\XBMC\addons\script.module.simple.downloader\lib\SimpleDownloader.py", line 167, in _processQueue
status = self._downloadURL(filename, item)
File "C:\Users\West\AppData\Roaming\XBMC\addons\script.module.simple.downloader\lib\SimpleDownloader.py", line 413, in _downloadURL
self._updateProgress(filename, item, params)
File "C:\Users\West\AppData\Roaming\XBMC\addons\script.module.simple.downloader\lib\SimpleDownloader.py", line 485, in _updateProgress
speed = int((get("bytes_so_far") / 1024) / (new_mark - get("mark")))
ZeroDivisionError: float division
Yep, download didn't work for me as well.
Anyone with apple tv eden beta 1 can confirm working youtube plugin after update to version 2.9.0? I have downloaded the update today but the plugin does not load at all (script fails)
CrazyCoder Wrote:http://swnet.spb.ru/files/xbmc-addons.zip is not a plug-in, it's just a zipped directory with plug-ins that you need to unpack into XBMC addons directory by hand.
Well, I was not talking about the zip file, the official repository offered an update today of the youtube plugin to version 2.9.0, so I simply downloaded the updated directly in apple tv and now the plugin does not work at all....So are you suggesting that whereas the official repository update does not work, the alternative update through the zip file will help?
No, I thought that you were trying the zip, sorry.
Trying to login, and get the 2-step digit window up. But still I get login false.
20:46:44 T:140302557071104 NOTICE: YouTube-2.9.0
20:46:44 T:140302557071104 NOTICE: CommonFunctions-0.9.1
20:46:44 T:140302557071104 ERROR: ADDON: extension 'downloader/' is not currently supported for service addon
20:46:44 T:140302557071104 ERROR: Previous line repeats 1 times.
20:46:44 T:140302557071104 NOTICE: Thread Background Loader start, auto delete: false
20:46:44 T:140303079061312 ERROR: GetDirectory - Error getting plugin://plugin.video.youtube/?path=/root/login&action=settings&
20:46:44 T:140303079061312 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.youtube/?path=/root/login&action=settings&) failed
Not sure what I'm doing wrong. Worked just a couple of days ago.
Running XBMC 11.0-BETA1 Git:22ad8e4 (Compiled: Jan 17 2012). Any changes upstream which could be explaining this?
Thanks for the plugin though
Loving it when it works.
MindTooth Wrote:Trying to login, and get the 2-step digit window up. But still I get login false.
Thanks for the plugin though Loving it when it works.
Full log to pastebin please.
wmansir Wrote:Installed on Eden Beta 2, Win7 64. Just unzipped in Addons dir with overwrite existing.
errors from log:
self.run()
CrazyCoder Wrote:Yep, download didn't work for me as well.
I tried a clean install and downloading worked fine.
If you installed with the unofficial zip provided above, please uninstall it and upgrade/install through the repository.
ETA: This has been confirmed and is being looked at.
tobias
I tried uninstalling the plugin, and even manually deleting the helper scripts that were included in the zip and letting XBMC reinstall everything, but I couldn't get it to work. Eventually I backed up my XBMC profile and then did a complete uninstall/reinstall of Eden b2.
It looks like everything is working fine now. I just have to restore some bits of my profile.
EDIT: Tried restoring my profile databases and it reverted to same broken behavior. Deleted Addons.db, Addon15.db and commoncache.db, that seems to have fixed it. Maybe it will save someone a reinstall.
Thanks for pushing the 2.9 update out. Much appreciated.
I really like the addition of the watch later and liked videos but nothing's coming up for these lists. Is this a known gap or are these features working for other folks?
I know most of the focus is on PC and ATV, but does anyone here use YouTube with the original XBOX1? I actually still use mine (it is the cheapest set top player and I have used it for years for playing offline videos but wanted to know if anyone could possibly help me with playing YouTube videos? Thanks!
Hey guys i think the update to 2.9 or some of its dependancies may have caused Justin.tv plug in to break.
The following script error started after
-youtube update 2.9.0
-common plugin update
-simple downloader update
14:12:27 T:2896272240 ERROR: Error Type: <type 'exceptions.ValueError'>
14:12:27 T:2896272240 ERROR: Error Contents: No JSON object could be decoded
14:12:27 T:2896272240 ERROR: Traceback (most recent call last):
File "/storage/.xbmc/addons/plugin.video.jtv.archives/default.py", line 559, in <module>
Categories()
File "/storage/.xbmc/addons/plugin.video.jtv.archives/default.py", line 117, in Categories
data = json.loads(result[0])
File "/usr/lib/python2.7/json/__init__.py", line 326, in loads
return _default_decoder.decode(s)
File "/usr/lib/python2.7/json/decoder.py", line 366, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/lib/python2.7/json/decoder.py", line 384, in raw_decode
raise ValueError("No JSON object could be decoded")
ValueError: No JSON object could be decoded
14:12:27 T:3018414800 ERROR: GetDirectory - Error getting plugin://plugin.video.jtv.archives
14:12:27 T:3018414800 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.jtv.archives) failed
14:12:27 T:2896272240 NOTICE: Thread Background Loader start, auto delete: false
14:12:36 T:2896272240 NOTICE: Thread XBPyThread start, auto delete: false
14:12:36 T:3018414800 ERROR: Control 1 in window 10099 has been asked to focus, but it can't
Thank you for updating the plugin, just a little thing, I use two step login, and I'm asked for my pin on every single video I play, well I have disabled two step for the moment, but it would be great to have it back.
On the other hand, may be I'm missing something obvious, but, how can I invert the order for "watch later" videos? rigth now latest videos are at the end, so I have to click more videos to get to the latest (and this will grow every time I add a new video)
RGB_Gamer Wrote:I know most of the focus is on PC and ATV, but does anyone here use YouTube with the original XBOX1? I actually still use mine (it is the cheapest set top player and I have used it for years for playing offline videos but wanted to know if anyone could possibly help me with playing YouTube videos? Thanks!
We do not support xbmc4xbox in any way shape or form.
Other people have ported the plugin to the xbox, but you will have to find out the details on the xbmc4xbox site.
