Full Version: [depricated] old YouTube Plugin - XBMC 13.0 Frodo/Gotham only
Hi
I too can't log into youtube here is my youtube debug log
John
xbmc irc suggested using only username and not email ( eg rileyp not [email protected] ) Didnt work for me though....
help the addon was working fine but suddenly i can't login for nuts Sad
Is anyone able to get the list of movies within the Explore Youtube section? Everything in there returns "No results!" for me.
(2012-06-01, 02:31)rupertos Wrote: [ -> ]hello
i want to have automatic viewtype Shift after every search.. but I have wall instead...
how to change that..?
bump? anyone?
Having 'login failed' issues on my Linux XBMC box. Installed the plugin (2.9.2) through repository.
http://xbmclogs.com/show.php?id=3435
Hi, login code is broken atm, we're preparing a fix..
BTW Can anyone else confirm for me that this page:
www.youtube.com/trailers
Is empty?
In that case we're killing the youtube trailers page.
(2012-06-09, 00:00)newatv2user Wrote: [ -> ]Is anyone able to get the list of movies within the Explore Youtube section? Everything in there returns "No results!" for me.
I'll look into it thanks Smile
(2012-06-09, 15:47)rupertos Wrote: [ -> ]
bump? anyone?
We don't support all the different skin views, the plugin is only built for confluence. But you can disable the current view changing behaviour..
In settings under the advanced tab there's an option called "view mode for confluence" if you set it to default the plugin will stop messing with you listings. Though it wont change for folders you've already listed.
Yup, no trailers in there for me.
(2012-06-10, 20:34)HenrikDK Wrote: [ -> ]Hi, login code is broken atm, we're preparing a fix..
Is empty?
Yeah, that page is empty for me.
Cannot see YouTube Plugin, in videos section, in xbmc eden, windows platform
Yes the trailers page is blank for me, Thanks so much for working on a fix for login. Can't wait to be able to use my subscriptions again! Smile
appreciate all efforts to fix login issue Nod
Any fix as of yet
Hi since 3 day's the youtube plugin xbmc cant login whithe my account ,i tray it bothe whithe dharma and edden
hop you can fix it
thx
(2012-06-12, 19:05)kobyboy Wrote: [ -> ]Any fix as of yet
We have the fix mostly ready, I'm still unsatisfied with the current performance of the shows scraper, but hopefully we'll push a new release this weekend.
