Full Version: [depricated] old YouTube Plugin - XBMC 13.0 Frodo/Gotham only
(2012-09-05, 19:31)protocol77 Wrote: [ -> ]
(2012-09-04, 19:40)dkplayaclub Wrote: [ -> ]I have had so many problems with this plugin. Only thing I am able to do reliably is search and play videos. I have taken to using Navi-X to browse youtube otherwise, since it works flawlessly.
I've been using my iPad to search then using AirPlay to display them on my tv
Sorry if I wasn't clear. My wording could be confusing. I AM able to search and view videos fine. I have problems with all the other features however, such as Explore Youtube, Youtube Movies etc.
(2012-09-06, 04:41)dkplayaclub Wrote: [ -> ]
Log or it didn't happen: http://code.google.com/p/youtubexbmc/wik...llDebugLog
Also information about country of residence and what you're seeing.
Please note we do not support US rental movie listings from youtube as we have no way of testing that any eventual solution would work over time..
(2012-08-08, 05:17)dkplayaclub Wrote: [ -> ]Don't normally do this, but I'm desperately bumping this post. If anyone can take one last look for me that would be awesome. I have taken up using Navi-X to search YouTube, but this plugin is easier IMO and has a clean look.
(2012-08-02, 17:41)dkplayaclub Wrote: [ -> ]
(2012-08-02, 12:31)HenrikDK Wrote: [ -> ]Apparently when the plugin tries to scrape the movies page, its empty.. since we expect the page to contain some movies, this causes an infinite loop (opps Smile)
does this link : http://www.youtube.com/movies/comedy?feature=mv_c
provide a proper looking movie listing?
Yes, when I follow that link in my web browser I do see a list of movies properly. After setting my debug level to 7 as you suggested this is what I got when I tried to bring up a movie list through Explore YouTube. Gave it a few minutes while loading the list and, as usual, had to give up. Sad
I had to split the log up to fit under the limit (I can't afford to pay for a service I don't use that much)
Part 1
Part 2
Part 3
I hope that is enough info to figure out what I have going on. Thanks again for your continued support.
EDIT - I just noticed that if I follow that link I do see a list of movies, but clicking most of the links (besides the movies themselves) comes up with a missing page error. Not sure if that's important.
Can't wait to get this working again....
Posted a while back. My log was so long because at first nobody could help me so I set the log detail level or whatever higher. Reposted this 3 part log file and nobody got back to me after that. Shame, since I would love to get this plugin working the way it did long ago.
Hi
I am having an issue with this plugin where it seems to login fine, will download details of a plylist, but when you clcik any videos to play, it says there is an error.
Any ideas on things to check?
Hello everyone, i think answer to my question should be very simple but i do not know how to formulate search request for google or for this thread search engine.
Issue is that despite the fact that i chose max resolution of videos as 1080p XBMC (latest nightly build) play SD only. What should i change to get HD quality and is there any possibility to change quality during playback?
I applied the fix from the post above, however the plugin doesn't return any results!
20:53:01 T:1075675136   ERROR: GetDirectory - Error getting plugin://plugin.video.youtube/?path=/root/search&feed=search&sea
20:52:47 T:1296217184  NOTICE: [YouTube-3.1.0] _fetchPage : 'connecting to server... http://gdata.youtube.com/feeds/api/vide
20:56:40 T:1287828576  NOTICE: YouTube-3.1.0 ARGV: ['plugin://plugin.video.youtube/', '0', '?path=/root/search&feed=search&search=test&']
20:56:42 T:1287828576  NOTICE: [StorageClient-1.1.0] __init__ : 'Setting table to : YouTube'
20:56:42 T:1287828576  NOTICE: CommonFunctions-1.1.0
20:56:43 T:1287828576  NOTICE: [YouTube-3.1.0] __init__ : ''
20:56:43 T:1287828576  NOTICE: [StorageClient-1.1.0] __init__ : 'Setting table to : Downloader'
20:56:43 T:1287828576  NOTICE: [YouTube-3.1.0] __init__ : 'Done'
20:56:43 T:1287828576  NOTICE: [YouTube-3.1.0] retrieveSettings : 'Got key 'store_searches''
20:56:43 T:1287828576  NOTICE: [YouTube-3.1.0] storeSettings : 'Got key 'store_searches''
20:56:43 T:1287828576  NOTICE: perpage 50
20:56:43 T:1287828576  NOTICE: [YouTube-3.1.0] _fetchPage : 'called for : {'api': 'true', 'link': 'http://gdata.youtube.com/feeds/api/videos?q=test&safeSearch=moderate&start-index=1&max-results=50', 'auth': None}'
20:56:43 T:1287828576  NOTICE: [YouTube-3.1.0] _fetchPage : 'got default: http://gdata.youtube.com/feeds/api/videos?q=test&safeSearch=moderate&start-index=1&max-results=50'
20:56:43 T:1287828576  NOTICE: [YouTube-3.1.0] _fetchPage : 'got api'
20:56:43 T:1287828576  NOTICE: [YouTube-3.1.0] _fetchPage : 'connecting to server... http://gdata.youtube.com/feeds/api/videos?q=test&safeSearch=moderate&start-index=1&max-results=50'
20:56:53 T:1287828576  NOTICE: [YouTube-3.1.0] _fetchPage : 'URLError : <urlopen error [Errno 2] temporary failure in name resolution.>'
20:56:56 T:1287828576  NOTICE: [YouTube-3.1.0] _fetchPage : 'called for : {'api': 'true', 'link': 'http://gdata.youtube.com/feeds/api/videos?q=test&safeSearch=moderate&start-index=1&max-results=50', 'auth': None, 'error': 1}'
20:56:56 T:1287828576  NOTICE: [YouTube-3.1.0] _fetchPage : 'got default: http://gdata.youtube.com/feeds/api/videos?q=test&safeSearch=moderate&start-index=1&max-results=50'
20:56:56 T:1287828576  NOTICE: [YouTube-3.1.0] _fetchPage : 'got api'
20:56:56 T:1287828576  NOTICE: [YouTube-3.1.0] _fetchPage : 'connecting to server... http://gdata.youtube.com/feeds/api/videos?q=test&safeSearch=moderate&start-index=1&max-results=50'
Already tested resolving gdata.youtube.com manually and that works fine.
Hello there
I've also been fighting with the script failure, mainly when trying to play a whole youtube playlist.
Installing 2.7.0 and updating didn't work for me, also tried 2.70 without updating and it didn't work at all...
...but...
2.90 works perfect Smile without updating from it later...
Here's the link: http://mirrors.xbmc.org/addons/eden-pre/...-2.9.0.zip
(2012-08-01, 23:47)tinybutstrong Wrote: [ -> ]@HenrikDK, can you add more languages to subtitle support in next update?
Thank you!
For portuguese subtitle i make this ( in linux ), while wait for official support
In ~/.xbmc/addons/plugin.video.youtube/resources/settings.xml
search for
<setting id="lang_code" type="enum" label="30276" lvalues="30277|30278|30279|30280|30281|30282|30283|"default="0" />
change to
<setting id="lang_code" type="enum" label="30276" lvalues="30277|30278|30279|30280|30281|30282|30283|30289" default="0" />
in ~/.xbmc/addons/plugin.video.youtube/resources/language/English/strings.xml
search for
<string id="30288">Show YouTube History</string>
after this line add this
<string id="30289">Portuguese</string>
in ~/.xbmc/addons/plugin.video.youtube/YouTubePlayer.py
search for all lines with ( three lines )
lang_code = ["off", "en", "es", "de", "fr", "it", "ja"][int(self.settings.getSetting("lang_code"))]
change to
lang_code = ["off", "en", "es", "de", "fr", "it", "ja", "pt"][int(self.settings.getSetting("lang_code"))]
In Plugins settings change to Portuguese
This work for me.
ref: https://developers.google.com/youtube/2....l_captions
and http://www.loc.gov/standards/iso639-2/php/code_list.php
@locossaurorex, thanks a lot! I hope it can be implemented to default plugin in next upgrade.
Now, a feature suggestion if it is technically possible: custom subtitle (closed captions) color:
Getting an error, can someone please look into this? It just started in the last 24 hours.
http://sprunge.us/KdCD
No system modifications have been performed during this time.
(2012-09-14, 02:44)vijayk416 Wrote: [ -> ]Getting an error, can someone please look into this? It just started in the last 24 hours.
Concur Sad
Yep, same error here. I think it worked fine just a few days ago..
wow im so glad i found this after 3 hours of troubleshooting lol.....at least its not just me.
(Sort of) same results here.
I noticed the URL has a leading '=' which I stripped out, but after doing that curl gives error 22 when trying to acccess the URL. No idea what curl is getting, but if I try to open that URL in my browser I get a 403 forbidden error.
I can confirm this YouTube addin is no longer managing to download videos.
However, note that the logfile referenced http://sprunge.us/KdCD says it's trying to access a channel that is deleted, when I paste the url of the video into a web browser. So that logfile can probably be ignored.
(2012-09-14, 14:28)jackparsons Wrote: [ -> ]I can confirm this YouTube addin is no longer managing to download videos.
When I'm back home I'll try and post a logfile from my machine, meantime it would likely help if others posted their logfiles.
