Full Version: [depricated] old YouTube Plugin - XBMC 13.0 Frodo/Gotham only
(2012-12-21, 17:02)F.Horst Wrote: [ -> ]ppa:wsnipex/xbmc-xvba - XVBA and VDPAU improved monthly updated PPA (Unstable)
but with this also nothing works
ok thanks!
erm, what is it though? Big Grin
(2012-12-21, 16:31)F.Horst Wrote: [ -> ]i deleted
plugin.video.youtube in /storage/.xbmc/addons
and
plugin.video.youtube.beta in /storage/.xbmc/userdata/addon_data
but nothing works
the search is blank
Huh
Try deleting /.xbmc/userdata/Database/commoncache.db, if that doesn't work I'm out of ideas.
No chance, but thanks!!
I gave up and downgrade to OE 2.0.
Now works youtube like a charm
i've deleted commoncache.db loads of times. whenever this plugin stopped being able to download, i would close xbmc, rename the file and start xbmc. never caused me any problems. xbmcc just recreates a fresh db file
(2012-12-20, 04:13)Salabim Wrote: [ -> ]Changes from the cyrrelic subscription fix broke the script.
When I manually alter the .py files as they are in the revision, XBMC says the script is broken.
The only "fix" working there is replacing line 240 in YouTubeCore.py from :
folder["channel"] = folder["Title"]
...to...
folder["channel"] = self.common.parseDOM(node, 'yt:username')[0]
... and leaving the rest untouched will fix the empty "My subscriptions" problem.
The rest of the changes in that changeset broke the script.
This change doesn't fix "My Subscriptions" error. So far there has nothing been posted on the web that gets this working in Frodo rc1.
(2012-12-19, 22:08)Xiider Wrote: [ -> ]Here is a link for the beta zip ready to install from the website said some posts before.
Google Two-Factor Authentication works fine.
http://xiider.de/yt.zip
This fixed the login issue for me. Thanks yo!
(2012-12-22, 00:42)sealcouch Wrote: [ -> ]
Yes, the yt.zip fixes the login, but doesn't seem to fix the subscriptions and explore in Fodo rc1.
Is there a fix in the works for the login issue with Eden?
This is the main addon I use in xbmc watching youtube subscriptions, it sucks Sad
(2012-12-22, 03:29)okie Wrote: [ -> ]Is there a fix in the works for the login issue with Eden?
I just updated from Eden a couple days ago, but yt was logging in just fine.
So you are saying it maybe me and not the plugin?
I haven't updated anything that would have caused it.
Am I the only one with Eden all of a sudden having this issue?
(2012-12-22, 04:43)okie Wrote: [ -> ]So you are saying it maybe me and not the plugin?
I just now checked all of my current Eden boxes and it works without any issues. It however no longer works properly on my other box that I've updated from Eden final to Frodo rc1. Before I updated, that Eden box had YouTube running fine on it as well.
How weird....I even downgraded yt and still can't login.
Strange.
Yt works but I can't login, can you actually login to view your subscriptions?
Upgraded to Frodo rc2 on Linux Mint 12 with plugin 3.3.0 and login is working fine for me, as does search. Plugin operates as I've come to expect.
Frodo RC2, Youtube 3.3.0: no items at "Explore YouTube->YouTube Music->YouTube Top 100 Music Chart" :/
(2012-12-22, 11:17)jackparsons Wrote: [ -> ]Upgraded to Frodo rc2 on Linux Mint 12 with plugin 3.3.0 and login is working fine for me, as does search. Plugin operates as I've come to expect.
Okay, updated from rc1 to rc2 and official YouTube addon still doesn't log in, but YouTube Beta that is posted here logs in okay. However, neither addon allows you to get into "My Subscriptions" section which is main thing that I use this addon for.
