since yesterday my login doesnt work anymore
i get a youtube script error when i press on the button for my subcriptions
search button and video plays fine without stuttering
I have had this problem in the very recent past (month or two) and just deleted the youtube plugin folder and reinstalled but now reddit, bestofyt, and youtube itself are doing it again:
behavior: videos will not start loading until a 10 second delay each and every time.
Anyone else seen this and figured it out completely?
(2013-01-17, 02:35)debennett2 Wrote: [ -> ]I have had this problem in the very recent past (month or two) and just deleted the youtube plugin folder and reinstalled but now reddit, bestofyt, and youtube itself are doing it again:
i already did this, but no effect.
I have the feeling that it stopped working around the time that youtube got its new layout, but i have
no real evidence for that.
Guys i have just reloaded xbmc onto my windows pc but cannot stream any videos when clicked on it says "unable to extract from url"
Help please?!!!!!
I'm using Firefox 18 and the Youtube XBMC plugin but I can't seem to get it to 'push' URLS to XBMC?
It's configured - I've manually changed my XBMC port (for good reasons) but I know that's ok because the XBMC remote works.
Set the right user / pass but I can't see an icon on the youtube page / firefox browser to "pass this URL to XBMC" ?
Is it simply out of date, or redesigns on youtube site throwing it out?
Anyone?
YouTube plugin doesn't work...
(2013-01-19, 16:24)pacooka Wrote: [ -> ]YouTube plugin doesn't work...
Doesn't work for me, either.
Hola,
Youtube addon does not work for me. When I click any option (favorites, Etc.) it says "plugin error"
Here is the log:
http://pastebin.com/Qw1X9xEJ
AdiĆ³s.
The add on works for me . My only problem is that I have 75 subscriptions , but can only see 50 . There needs to be a more button or arrow , to get to the rest .
Is there a way to see all of my subscriptions. Should be able to work like videos if you are in a particular subscription . Thanks
Apple TV 2 XBMC wont "Play All/Play and Shuffle All" on youtube. Any help? Tried downgrading to 3.3.0 youtube but still no luck. Here is my debug. Thank you!
http://pastebin.com/wEupKUBA
I've tried to the use the download feature in the YouTube add-on however this fails to copy the download to my target destination. The file downloads to the temp location on my local drive, but the destination is a SMB share. Looking in the log file I see;
ERROR: XFILE::CFile::Rename - Error renaming file C:\Users\XXXX\AppData\Roaming\XBMC\userdata\addon_data\script.module.simple.downloader\YYYYYYYYYYY-[ZZZZZZZ].mp4
ERROR: CLocalizeStrings::ClearBlock: Trying to clear non existent block C:\Users\XXXX\AppData\Roaming\XBMC\addons\script.module.simple.downloader
I'm running Frodo RC3 on Windows 7 64-bit.
YouTube addon is YouTube-4.4.1
(2013-01-20, 21:23)BillDino Wrote: [ -> ]Apple TV 2 XBMC wont "Play All/Play and Shuffle All" on youtube. Any help? Tried downgrading to 3.3.0 youtube but still no luck. Here is my debug. Thank you!
where did you get the 3.3.0 version? i am having the same problem as you but i think i can make it work with a 3.3.0
(2013-01-21, 21:46)martinLB Wrote: [ -> ] (2013-01-20, 21:23)BillDino Wrote: [ -> ]Apple TV 2 XBMC wont "Play All/Play and Shuffle All" on youtube. Any help? Tried downgrading to 3.3.0 youtube but still no luck. Here is my debug. Thank you!
There is a rollback button under the addon settings for youtube. let me know if you have an update! Thanks!
