Full Version: [depricated] old YouTube Plugin - XBMC 13.0 Frodo/Gotham only
Hi!
I have the same problem. The plugin youtube worked for me when i was logout, when login plugin fail.
I'm from Spain and I configure the language settings in spanish.
My version XBMC: EDEN
Plugin Youtube version: 3.4.1
In xmbc.log:
3:41:53 T:3056597872   ERROR: Traceback (most recent call last):
                                              File "/home/xbmcsalon/.xbmc/addons/plugin.video.youtube/default.py", line 111, in <module>
                                                navigation.listMenu(params)
                                              File "/home/xbmcsalon/.xbmc/addons/plugin.video.youtube/YouTubeNavigation.py", line 109, in listMenu
                                                return self.list(params)
                                              File "/home/xbmcsalon/.xbmc/addons/plugin.video.youtube/YouTubeNavigation.py", line 193, in list
                                                self.parseVideoList(params, results)
                                              File "/home/xbmcsalon/.xbmc/addons/plugin.video.youtube/YouTubeNavigation.py", line 488, in parseVideoList
                                                self.addVideoListItem(params, result_params, listSize)
                                              File "/home/xbmcsalon/.xbmc/addons/plugin.video.youtube/YouTubeNavigation.py", line 440, in addVideoListItem
                                                cm = self.addVideoContextMenuItems(params, item_params)
                                              File "/home/xbmcsalon/.xbmc/addons/plugin.video.youtube/YouTubeNavigation.py", line 536, in addVideoContextMenuItems
                                                cm.append((self.language(30512) % studio, 'XBMC.RunPlugin(%s?path=%s&channel=%s&action=add_subscription)' % (sys.argv[0], item("path"), url_studio)))
                                            ValueError: incomplete format
13:41:53 T:11421440   ERROR: GetDirectory - Error getting plugin://plugin.video.youtube/?path=/root/playlists&playlist=PLZDyik5DKB_mVvHEpOvcWx9i8Z6GzwpEZ&user_feed=playlist&login=true&
13:41:53 T:11421440   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.youtube/?path=/root/playlists&playlist=PLZDyik5DKB_mVvHEpOvcWx9i8Z6GzwpEZ&user_feed=playlist&login=true&) failed
This solution work for me:
In the plugin directory, go /resources/language/Spanish/strings.xml. Open the file and search
<string id="30512">Subscribirse a %s%</string>
<string id="30513">Dar de baja de %s%</string>
Change for
<string id="30512">Subscribirse a %s</string>
<string id="30513">Dar de baja de %s</string>
Hi all,
i face a problem with youtube plugin: problem is that the script fails when i try to search using greek characters. Actually after i try to search with greek characters the script fails all the time when i choose search, before i even try to search for something.
I use FRODO RC3 and youtube plugin 4.4.1
xbmc script is here: http://pastebin.ca/2307574
(2013-01-25, 17:51)Surgo Wrote: [ -> ]
(2013-01-15, 19:02)folkg Wrote: [ -> ]Q: Can someone confirm that live YouTube streams don't work? YouTube streams some live sports that I would love to be able to receive through XBMC, but currently the plugin says that the video stream doesn't exist. I have to access the videos through my browser. Is this a known limitation? Or am I missing something important?
Having the same issue right now (just started using XBMC). Regular Youtube vids work, but attempting to watch the League of Legends Championship Qualifiers livestream is failing Undecided Says "couldn't locate video url". Fails both when I click on it using my remote, and use "Send to XBMC" from my browser.
For that matter, the livestreams are not showing up on the user's channel in my subscriptions either.
Attempting to fix myself but drugged up after wisdom teeth extraction (same reason I'm watching it from my couch in the first place heh) so not going so well
I'm trying to watch lacrosse on YouTube live right now and I get the URL not found error as well. From my log, it looks like it can't find the video when it is scraping the page. For some reason, some live videos work fine. I don't know why the addon would be able to scrape some pages and not others.
I can't get any youtube videos to work on Frodo RC3 with youtube plugin 4.4.1. any help please?
(2013-01-26, 10:08)perro6969 Wrote: [ -> ]Just like I thought... look at this post. It's working for me:
http://forum.xbmc.org/showthread.php?tid...pid1292056
Thank you for this. It worked for me also.
Probably something to do because I use Norwegian letters I guess.
(2013-01-20, 21:23)BillDino Wrote: [ -> ]Apple TV 2 XBMC wont "Play All/Play and Shuffle All" on youtube. Any help? Tried downgrading to 3.3.0 youtube but still no luck. Here is my debug. Thank you!
http://pastebin.com/wEupKUBA
were you able to find a solution?
(2013-01-16, 22:20)nihilist Wrote: [ -> ]It seems that my chrome and firefox plugin taken from
http://wiki.xbmc.org/index.php?title=Add...extensions
does not show any "play in xbmc" Button on a youtube page
can anybody confirm this?
I use xbmc 12-rc2
I am having the same problem, I can't see the button anywhere. I have searched this thread and not found a solution just yet. It was suggested to delete the plugin folders manually and reload, which I did, but still nothing. I have tried both chrome and firefox. I'm on a mac if that matters. Can anyone offer any thoughts on why the button is not showing up for me?
(2013-01-20, 00:21)watanave Wrote: [ -> ]Hola,
Youtube addon does not work for me. When I click any option (favorites, Etc.) it says "plugin error"
Here is the log: http://pastebin.com/Qw1X9xEJ
Adiós.
I think I've found the problem that gives me the "Plugin Error" when accessing my favorites or any other option in youtube plugin. My language was setting in Spanish and XMBC showed me the error.
Here is the debug log "Spanish Settings": http://pastebin.com/twni4rwW
And then I changed the language to English and voilá... No error, everything worked like expected.
This is the debug log "English Settings": http://pastebin.com/8rsZhk94 (No error)
Can anybody who knows coding, tell me how to fix this.
Gracias.
(2013-01-28, 23:39)martinLB Wrote: [ -> ]
Nope :\
(2013-01-30, 04:07)watanave Wrote: [ -> ]
Adiós.
Gracias.
pacmora gives you the solution a few messages up.
Is this a known issue ? Whenever a youtube video has an age limit, it's impossible to play it with this add-on ?
This issue is rather annoying Smile
(2013-01-09, 13:28)ghizzu Wrote: [ -> ]
(2013-01-09, 02:44)MadPriest Wrote: [ -> ]this is from a message i posted 3 days ago
noone got the answers?
19:15:47 T:2750528320   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <type 'exceptions.UnicodeDecodeError'>
                                            Error Contents: 'ascii' codec can't decode byte 0xd1 in position 7: ordinal not in range(128)
                                              File "/home/igalsc/.xbmc/addons/plugin.video.youtube/default.py", line 111, in <module>
                                              File "/home/igalsc/.xbmc/addons/plugin.video.youtube/YouTubeNavigation.py", line 109, in listMenu
                                              File "/home/igalsc/.xbmc/addons/plugin.video.youtube/YouTubeNavigation.py", line 184, in list
                                                (results, status) = self.storage.list(params)
                                              File "/home/igalsc/.xbmc/addons/plugin.video.youtube/YouTubeStorage.py", line 53, in list
                                                return self.getStoredSearches(params)
                                              File "/home/igalsc/.xbmc/addons/plugin.video.youtube/YouTubeStorage.py", line 112, in getStoredSearches
                                                thumbnail = self.retrieveSettings(params, "thumbnail", item)
                                              File "/home/igalsc/.xbmc/addons/plugin.video.youtube/YouTubeStorage.py", line 476, in retrieveSettings
                                                key = self.getStorageKey(params, type, item)
                                              File "/home/igalsc/.xbmc/addons/plugin.video.youtube/YouTubeStorage.py", line 249, in getStorageKey
                                                return self._getThumbnailStorageKey(params, item)
                                              File "/home/igalsc/.xbmc/addons/plugin.video.youtube/YouTubeStorage.py", line 299, in _getThumbnailStorageKey
                                                return key.encode("utf-8","ignore")
                                            UnicodeDecodeError: 'ascii' codec can't decode byte 0xd1 in position 7: ordinal not in range(128)
Try this:
in YouTubeStorage.py find this line:
and replace it with this one:
return key.decode("utf-8").encode("utf-8","ignore")
It should work (don't ask me why)
Can someone dumb it down for me, when I try "sudo nano" on those directories, I find nothing.
Where do I find YouTubeStorage.py in xbmcbuntu?
Is this the fix for "Script failed! : plugin.video.youtube"?
Can someone please tell me where to find "YouTubeStorage.py" file in xbmcbuntu?
Is there a way to normalize the volume of the Youtube Video's?
I notice when I play a playlist there's a lot of difference in volumes between video's.
I tried looking thru the plugin's settings as well as XBMC's settings, but there's nothing when it comes to video's that normalize the volume.
Is this possible? If not, is it maybe a nice feature to add in the future?
Any progress on the YouTube issue? I've tried the "return key.decode("utf-8").encode("utf-8","ignore")" patch and I still get the video url not found. Any suggestions?
Hello,
my youtube add-on is not working. When I start it is displaying "Open Stream" and after some seconds it closes (without starting the video) without error message and returns to the clip overview.
In the debug log there is a warning followed by some error messages.
Here is the logfile: http://pastebin.com/VEwZFNbf
I'm running youtube add-on 4.4.1 with XBMC Frodo / OpenElec on Raspberry Pi
Thanks for your help!
Johannes
