Full Version: [depricated] old YouTube Plugin - XBMC 13.0 Frodo/Gotham only
That's bad luck, I only just installed the YouTube add on for first time tonight, it was working OK. I then installed Bcc iPlayer watched a few videos in that then went back to YouTube add on and now it won't play anything. Does this kinda thing happen often?
Add on is version 4.4.1 running on Frodo
(2013-02-14, 01:10)cw-kid Wrote: [ -> ]That's bad luck, I only just installed the YouTube add on for first time tonight, it was working OK. I then installed Bcc iPlayer watched a few videos in that then went back to YouTube add on and now it won't play anything. Does this kinda thing happen often?
Every couple of months. Usually updated within 3 days automatically... with a manual fix here within 24hours. At least that happened last time. Usually fixed quickly though.
Same issue for me as well. I'm running YouTube v4.4.1 on Frodo final. Was working an hour ago and now I'm getting the "links are bad..mmkay" error too (for everything). ;(
(2013-02-14, 01:41)cami Wrote: [ -> ]
OK doesn't sound too bad then if it gets automatically fixed.
Cheers
It happens the same for me. Using Eden with Youtube plugin rel 3.4.1, and called the plugin from my attactv plugin, gives the same error.
I've set up the Youtube plugin debug logs and copied them entirely into a pastebin link for better inspection, although it can be very reproducible, I'm afraid: Youtube_XBMC_Debug_20130214.log
Hope it helps.
Cheers,
jamontes.
Ah, I guess that explains why I had difficulty getting videos to play last night. I was getting the same error occasionally, but selecting the same video again worked. Of course, that doesn't work now. Hoping to see a fix soon!
Nothing will play. "Couldn't locate video URL"
Fresh install of XBMC 12 in Win8. Plugin version 4.1.1
from what I can tell youtube change the location of the flashvars variable which is breaking this plugin and I assume all other youtube resolvers at the moment
Stopped for me as well last night,can`t stream from phone to Raspmc either.Checked on my work PC and thats the same.I notice there have been some Adobe FP updates ,don`t know if that is causing the problem.
(2013-02-14, 12:19)sicablondu Wrote: [ -> ]broken link https://dl.dropbox.com/u/33024933/plugin...outube.zip
can you please repost?
found the links here, tryied installing them (older versions dough) but still not able to play
http://dl.dropbox.com/u/4490912/plugin.v...outube.zip
http://dl.dropbox.com/u/4490912/script.m...loader.zip
reverted to updated version ... same error (couldnt locate video url)
Quick hack that works for me, replace YouTubePlayer.py with this: https://www.dropbox.com/l/GBKQUmxrRnoOBGFB - you can download this and copy it into your plugin.video.youtube folder.
Alternatively you can install one of the following plugins, which is the regular youtube plugin with the fix applied (go to System | Addons | Install from zip and select the downloaded zip file):
Eden (XBMC 11) plugin zip: https://www.dropbox.com/l/SrdosdpacjeyvDgd
Frodo (XBMC 12) plugin zip: https://www.dropbox.com/l/axITMmdkQzSpIuDD
Update: ... or you can use rc42's patch below...
i looked into the code and created a little workaround. I successfully tested it on my system ( xbmc-13.0-ALPHA1 from feb. 13),
Master version from https://github.com/HenrikDK/youtube-xbmc-plugin.git
patch file YouTubePLayer.py :
299c299
< if line.strip().startswith("var swf = \""):
> if line.strip().startswith("yt.playerConfig"):
310,312c310,312
< data = data[data.find("flashvars"):]
< data = data[data.find("\""):]
< data = data[:1 + data[1:].find("\"")]
> data = data["args"].items()
> for k, v in data:
> flashvars[k] = v
314,316c314
< for k, v in cgi.parse_qs(data).items():
< flashvars[k] = v[0]
< self.common.log(u"flashvars: " + repr(flashvars), 2)
(2013-02-14, 13:38)rc42 Wrote: [ -> ]Hi,
299c299
310,312c310,312
> for k, v in data:
> flashvars[k] = v
314,316c314
Cheers - works on my machine. Note to those playing at home that aren't python coders but can read a diff, see the indenting by hitting reply to this post.
it works for me ,
thanks
Zee
(2013-02-14, 14:03)joshka Wrote: [ -> ]
299c299
310,312c310,312
> for k, v in data:
> flashvars[k] = v
314,316c314
