Full Version: [depricated] old YouTube Plugin - XBMC 13.0 Frodo/Gotham only
(2013-02-14, 13:35)Mossy Wrote: [ -> ]Eden plugin zip: https://www.dropbox.com/l/SrdosdpacjeyvDgd
Thanks Mossy, I can confirm that it works on Eden!
For the paranoid ones, there's nothing bad happening here :-)
$ md5sum plugin.video.youtube-3.4.1b.zip
880de45802510ddbc1a948ca82c5b705  plugin.video.youtube-3.4.1b.zip
$ diff -r plugin.video.youtube plugin.video.youtube-3.4.1 | grep -v pyc
diff -r plugin.video.youtube/addon.xml plugin.video.youtube-3.4.1/addon.xml
2c2
< <addon id="plugin.video.youtube" name="YouTube" provider-name="TheCollective" version="3.4.1b">
> <addon id="plugin.video.youtube" name="YouTube" provider-name="TheCollective" version="3.4.1">
21c21
<     <summary lang="en">YouTube video plugin, with quick fix</summary>
>     <summary lang="en">YouTube video plugin</summary>
122c122
< </addon>
> </addon>
\ No newline at end of file
diff -r plugin.video.youtube/YouTubePlayer.py plugin.video.youtube-3.4.1/YouTubePlayer.py
22d21
< import re
25a25
296,300c296,312
<     pattern = "yt.playerConfig\s*=\s*({.*});"
<     match = re.search(pattern, data)
<     if match is None:
<         return flashvars
>         found = False
>         for line in data.split("\n"):
>             if line.strip().startswith("var swf = \""):
>                 found = True
>                 p1 = line.find("=")
>                 p2 = line.rfind(";")
>                 if p1 <= 0 or p2 <= 0:
>                     continue
>                 data = line[p1 + 1:p2]
>                 break
>         if found:
>             data = json.loads(data)
>             data = data[data.find("flashvars"):]
>             data = data[data.find("\""):]
>             data = data[:1 + data[1:].find("\"")]
302,303c314,315
<     playerconfig =  json.loads(match.group(1))
<     flashvars =  playerconfig['args']
>             for k, v in cgi.parse_qs(data).items():
>                 flashvars[k] = v[0]
315d326
319c330
<     for url_desc in flashvars[u"url_encoded_fmt_stream_map"].split(u","):
Thanks for the fix. can finally use the play2xbmc script again Smile
Thanks Mossy. Really appreciate it. Smile
Works fine now - thx for fix - just replaced YouTubePlayer.py with fix from above, for Frodo Rofl
(2013-02-14, 13:35)Mossy Wrote: [ -> ]Frodo plugin zip: https://www.dropbox.com/l/axITMmdkQzSpIuDD
Confirm this works on Frodo / Linux Mint 12.
cd .xbmc/addons/
mv plugin.video.youtube plugin.video.youtube.old
unzip plugin.video.youtube-4.4.1b.zip
Hi.
Thanks for the fix.
Anyone encountered a 'script failed' error when clicking 'Search'? I ran it once and got an error, and now I can't even type the keyword..
Thanks, Mossy I used the link for Frodo and it works great
(2013-02-15, 00:14)nir.zamir Wrote: [ -> ]Anyone encountered a 'script failed' error when clicking 'Search'? I ran it once and got an error, and now I can't even type the keyword..
Just tried some searches and it works fine for me.
I searched as well and received no errors, everything seems to be working OK, subscriptions are also updating as expected.
(2013-02-02, 11:19)pike Wrote: [ -> ]Is this a known issue ? Whenever a youtube video has an age limit, it's impossible to play it with this add-on ?
This issue is rather annoying Smile
For some reason, to get it to work, the plugin requires that you re-login by modifying you username twice:
1. change the username it to something wrong,
2. (try to) login (with wrong username)
3. change the username back
3. login (with correct username)
Just trying to login again will not work, you actually have to get a failed login to get it to "reset".
After this age restricted videos will play when logged in without issue, at least on my Eden setup.
Please see: http://code.google.com/p/youtubexbmc/iss...tail?id=80
thanks works great again
(2012-09-18, 04:07)SimonC Wrote: [ -> ]
(2012-09-16, 10:08)sandmac Wrote: [ -> ]
(2012-09-16, 09:47)Sonic Crash Wrote: [ -> ]I've tried your files and, while they work great on my windows box, my crystalbuntu box is having trouble logging into my account. Could the fact I have two-factor authentication be an issue? It doesn't prompt me to put in an authenticator pin and gives me a failed login prompt.
You have to have a separate password for accounts like this. Go to this page and create an application specific password.
https://accounts.google.com/b/0/IssuedAuthSubTokens
Thanks for the information, unfortunately turning on 2 step verification and creating a password for XBMC Windows does not work in my case. I tried using my YouTube name, the YouTube ID, Google name with and without @gmail and still get a dreaded login fail. Also used the new application specific password and my original Google password with no luck.
Anyone know an answer? I'm on a similar situation... cannot login... tried every user(youtube ID, google ID) & passwd (gogle, generated specific) like above.
I'm on RASPBIAN XBMC Youtube addon 4.4.1b
Thanks in advance...
JCL
JCL
(2010-08-22, 20:34)HenrikDK Wrote: [ -> ]This plugin is now the official YouTube plugin in the add-on repo.
The latest stable version of the plugin is 3.1.0.
To run the plugin it is recommended that you use the stable XBMC 11 Eden release and simply get it from the official add-ons repo.
Login:
We understand that some users might be hesitant to pass on their google account credentials to the plug-in (paranoia is healthy Smile), and for these users we suggest only providing YouTube specific account credentials (ie. only the YouTube username and password).
NOTES:
Users who are still experiencing login issues should follow these guidelines when posting about their problems:
Troubleshooting Login issues
Since several components of the plugin are now distributed as distinct services, manual installation has become so complex that we've decided to no longer provide old version of the plugin on our website. The source code for the plugin can now be found in our Mercurial repository: here
We've had some requests for the source of the plugin lately, the plugin is still licensed under GPL3 and the code can be found here:
http://hg.tobiasussing.dk/hgweb.cgi/youtubexbmc/
Issues and Problems:
Until now we've been using this thread to handle bug reporting, but it's gotten way to long, if you have persistent problems and you're unable to find answers on this forum, we suggest following this guide:
http://code.google.com/p/youtubexbmc/wik...llDebugLog
and posting an issue on our bug tracker here:
http://code.google.com/p/youtubexbmc/issues/list
Know issues and Testing
Part of this plugin also includes an extensive automated test suite where we test aprox. 70% of all the plugins functions nightly, if something breaks we'll usually know it. Please check the test results from this site before posting a bug on our tracker:
http://tc.tobiasussing.dk/jenkins/view/YouTube/
Hi ,
Can you please help me with the following error?
PlayBack failed
It is not working
Hi, im getting an error in the youtube addon aswell as when i try to play youtube trailers of movies aswell.
Here is my log
Trailers seem to work with other URLS besides youtube
Im using XBMC 12.0 Git:fb595f2
I have some errors as well recently plaing videos:
19:52:20 T:139687620499200 NOTICE: [YouTube-4.4.1] getXBMCVersion : '12.0'
19:52:20 T:139687620499200 NOTICE: [YouTube-4.4.1] buildVideoObject : '{'action': 'play_video', 'videoid': 'KYebpiRoeOc'}'
19:52:20 T:139687620499200 NOTICE: [StorageClient-2.5.0] 'get' : 'videoidcacheKYebpiRoeOc'
19:52:20 T:139687620499200 NOTICE: [StorageClient-2.5.0] '_sock_init' : ''
19:52:20 T:139687620499200 NOTICE: [StorageClient-2.5.0] '_sock_init' : 'Done: u'/home/vladi/.xbmc/temp/commoncache.socket''
19:52:21 T:139687620499200 NOTICE: [YouTube-4.4.1] _fetchPage : 'called for : {'api': 'true', 'link': 'http://gdata.youtube.com/feeds/api/videos/KYebpiRoeOc'}'
19:52:21 T:139687620499200 NOTICE: [YouTube-4.4.1] _fetchPage : 'got default: http://gdata.youtube.com/feeds/api/videos/KYebpiRoeOc'
19:52:21 T:139687620499200 NOTICE: [YouTube-4.4.1] _fetchPage : 'got api'
19:52:21 T:139687620499200 NOTICE: [YouTube-4.4.1] _fetchPage : 'connecting to server... http://gdata.youtube.com/feeds/api/videos/KYebpiRoeOc'
19:52:21 T:139687620499200 NOTICE: [YouTube-4.4.1] _fetchPage : 'done'
19:52:21 T:139687620499200 NOTICE: [YouTube-4.4.1] updateVideoIdStatusInCache : 'videoidcache'
19:52:21 T:139687620499200 NOTICE: [StorageClient-2.5.0] 'setMulti' : 'videoidcache'
19:52:21 T:139687620499200 NOTICE: [StorageClient-2.5.0] '_sock_init' : ''
19:52:21 T:139687620499200 NOTICE: [StorageClient-2.5.0] '_sock_init' : 'Done: u'/home/vladi/.xbmc/temp/commoncache.socket''
19:52:21 T:139687620499200 NOTICE: [YouTube-4.4.1] getVideoIdStatusFromCache : 'vidstatus-'
19:52:21 T:139687620499200 NOTICE: [StorageClient-2.5.0] 'getMulti' : 'vidstatus-'
19:52:23 T:139687620499200 NOTICE: [StorageClient-2.5.0] 'set' : 'videoidcacheKYebpiRoeOc'
19:52:23 T:139687620499200 NOTICE: [StorageClient-2.5.0] '_sock_init' : ''
19:52:23 T:139687620499200 NOTICE: [StorageClient-2.5.0] '_sock_init' : 'Done: u'/home/vladi/.xbmc/temp/commoncache.socket''
19:52:23 T:139687620499200 NOTICE: [YouTube-4.4.1] extractVideoLinksFromYoutube : 'trying website: {'action': 'play_video', 'videoid': 'KYebpiRoeOc'}'
19:52:23 T:139687620499200 NOTICE: [YouTube-4.4.1] _fetchPage : 'called for : {'login': 'true', u'link': 'http://www.youtube.com/watch?v=KYebpiRoeOc&safeSearch=none'}'
19:52:23 T:139687620499200 NOTICE: [YouTube-4.4.1] _fetchPage : 'got default: http://www.youtube.com/watch?v=KYebpiRoe...earch=none'
19:52:23 T:139687620499200 NOTICE: [YouTube-4.4.1] _fetchPage : 'got login'
19:52:23 T:139687620499200 NOTICE: [YouTube-4.4.1] _httpLogin : ''
19:52:23 T:139687620499200 NOTICE: [YouTube-4.4.1] _httpLogin : 'returning existing login info: xxxxxx'
19:52:23 T:139687620499200 NOTICE: [YouTube-4.4.1] _fetchPage : 'connecting to server... http://www.youtube.com/watch?v=KYebpiRoe...earch=none'
19:52:23 T:139687620499200 NOTICE: [YouTube-4.4.1] _fetchPage : 'Setting cookie: PREF=f1=50000000&hl=en;'
19:52:23 T:139687620499200 NOTICE: [YouTube-4.4.1] _fetchPage : 'done'
19:52:23 T:139687620499200 NOTICE: [YouTube-4.4.1] isVideoAgeRestricted : '[]'
19:52:24 T:139687620499200 NOTICE: Previous line repeats 1 times.
19:52:24 T:139687620499200 NOTICE: [YouTube-4.4.1] scrapeWebPageForVideoLinks : ''
19:52:24 T:139687620499200 NOTICE: [YouTube-4.4.1] extractFlashVars : 'flashvars: {}'
19:52:24 T:139687620499200 NOTICE: [YouTube-4.4.1] extractVideoLinksFromYoutube : 'Couldn't find video url- or stream-map.'
19:52:24 T:139687620499200 NOTICE: [YouTube-4.4.1] _findErrors : ''
19:52:24 T:139687620499200 NOTICE: [YouTube-4.4.1] _findErrors : '1'
19:52:24 T:139687620499200 NOTICE: [YouTube-4.4.1] _findErrors : '2'
19:52:24 T:139687620499200 NOTICE: [YouTube-4.4.1] _findErrors : '4'
19:52:24 T:139687620499200 NOTICE: [YouTube-4.4.1] _findErrors : 'couldn't find any errors: {'status': 200, 'new_url': 'http://www.youtube.com/watch?v=KYebpiRoeOc&safeSearch=none', 'content': u'<!DOCTYPE html><html lang="en"><head> <script>\nvar yt = yt || {};yt.timing = yt.timing || {};yt.timing.data_ = yt.timing.data_ || {};yt.timing.tick = function(label, opt_time) {var tick = yt.timing.data_[\'tick\'] || {};tick[label] = opt_time || new Date().getTime();yt.timing.data_[\'tick\'] = tick;};yt.timing.info = function(label, value) {var info = yt.timing.data_[\'info\'] || {};info[label] = value;yt.timing.data_[\'info\'] = info;};yt.timing.reset = function() {yt.timing.data_ = {};};if (document.webkitVisibilityState == \'prerender\') {yt.timing.info(\'prerender\', 1);document.addEventListener(\'webkitvisibilitychange\', function() {yt.timing.tick(\'start\');}, false);}yt.timing.tick(\'start\');try {yt.timing.info(\'pt\', (window.gtbExternal && window.gtbExternal.pageT() ||window.external && window.external.pageT));} catch(e) {}if (window.chrome && window.chrome.csi) {yt.timing.info(\'pt\', Math.floor(window.chrome.csi().pageT));} </script>\n\n<script>var yt = yt || {};yt.preload =
Great... Thanks Cool
Confirmed plugin.videoyoutube-4.4.1b.zip fixed... "can't locate the video URL" Nod
Win s7n XBMC 12.0 Git:20130127-fb595f2
