FEATURE REQUEST
I do hope this is the right place for this sort of thing. I apologise if not.
For some time I have been pretty damned frustrated with how youtube manages subscriptions, not allowing us to group them, to in effect create our own custom channels (eg. all film trailer/clip related subscriptions in one place, and not cluttered by other things). I have just noticed this now exists, and is called 'collections', I think it's only been around for a little while, but I wondered what the likelihood was that we could get this into the XBMC plugin as it would make my month?
Dan
(2013-05-31, 11:08)djfourmoney Wrote: [ -> ]I have a problem with the You Tube app. I wanted to watch the anime Dirty Pair from Manga's channel on You Tube. Its mature content and I get URL Not Found Error message from inside the app. Of course I can watch it via the browser, that's not what I want.
I searched and found its a 4oD issue or something with all sort of mature or age consent content.
Is there a fix?
Can I get a bump? I have two other options obviously but I want to watch it on You Tube and not have to download it or store it on physical media or even the cloud.
I've been using the 4.4.4 version of this addon for several months perfectly then all of a sudden today it's prompting me to login and now i'm getting login failures, I've uninstalled and reinstalled and i'm still getting the login failures over 20 attempts. Help? Please see my pastebin debug log here
http://pastebin.com/8WmDu6Ha
mac os x
xbmc 12.2
youtube 4.4.4 from xbmc.org repo
Hi, just recently installed xbmc on windows and as well on a pi, I can not get youtube to work which also affects trailer being launched from movie info its just wont open the stream. Is there a different repo available for this plug in or just the one from the official repo?
You can ignore this as this was a router issue, for some reason my dns's was blocking the stream set it back to isp's and started working.
Bump!
mac os x
xbmc 12.2
(2013-06-06, 16:40)nerdstalker Wrote: [ -> ]Bump!
I've been using the 4.4.4 version of this addon for several months perfectly then all of a sudden today it's prompting me to login and now i'm getting login failures, I've uninstalled and reinstalled and i'm still getting the login failures over 20 attempts. Help? Please see my pastebin debug log here http://pastebin.com/8WmDu6Ha
mac os x
xbmc 12.2
I just posted an issue to the google code group about this
https://code.google.com/p/youtubexbmc/is...tail?id=94
I have the same issue with my primary account, my other accounts are able to logon.
mac os x
xbmc 12.2
10:15:14 T:4660400128 NOTICE: [YouTube-4.4.4] _httpLogin : 'Returning error: u'The username or password you entered is incorrect.''
An xbmc notification with that message should have popped in your bottom right corner.
During my troubleshooting in addition to correct username and password data I also attempted entering incorrect username and password data to see if it would even throw me a different fail message, that was one of those attempts.
I successfully entered the correct identical un/pw in the browser several times however the addon still will not accept it and still displays the "Login Failed" message. As stated by someone else on this thread everything was working perfect for me as well then all of a sudden this happens. Look forward to a fix.
mac os x
xbmc 12.2
Same here. Done all troubleshooting and cleaning. Logs read the same as already posted elsewhere.
Maybe this is possibly related to G+ linking of Youtube accounts?
I tried installing the Youtube addon today, but I just can't get it to work. I tried to uninstall, delete those two folders and install it again as it was suggested somewhere, but still without luck.
I hope someone can help me.
My debug log:
http://pastebin.com/1kD9Uqr9
I had this problem too, turned out to be a DNS problem which is still happening, i use unotelly and on xbmc only for some reason they have this problem, i contacted and they confirmed and also said that youtube was still in beta with them which it does actually say on their site, if you turn dns off it works fine. Maybe someone else can test this to confirm, if you have changed your dns that is
(2013-05-31, 04:59)metatime Wrote: [ -> ]I'm having trouble with when I want to fast forward on the video in youtube but the app stalls. Like for example if I want to start at 5 mins into a video, the app stalls and nothing happens.
I'm having this issue too. Skipping 30 secs and by the timeline bar freezes the video. Is this a recent issue or known?
