2013-07-09, 02:11
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315
2013-07-10, 14:24
http://pastebin.ca/2424581
I can't find "change or add password" on advanced page
And cant find user name with @pages.plusgoogle.com
Help me, please
(2013-07-07, 04:04)Fragarach Wrote: [ -> ]I was finally able to login. After messing around with damn near everything.
Log into youtube from your pc
In the upper right corner click the little arrow to the right of your name
Click "youtube settings" in the header that pops up
Under your name in the middle click "advanced"
On the advanced page click "change or add password"
The page should show you your new youtube user name (should end in @pages.plusgoogle.com) that youtube changed to when they added the google + crap.
You need to change your user name in XBMC to this.
Set a password. It can be your current youtube password or a new one. If you change it to new, you must also change it in XBMC
Login in XBMC
Help me, please
2013-07-10, 18:55
XBMC 12.2 for Windows 7.
Installed YouTube add-on 4.4.4 directly from XBMC menus.
Tried half a dozen different login methods. None worked.
http://pastebin.ca/2424763
I blotted out my password from inside that log file, but everything else is intact.
Any help in FINALLY getting this thing to work is appreciated. Thank you.
2013-07-11, 04:13
Does anybody know how to get "The Young Turks" to play on this plugin?
I have tried to get their weekday 9-11PM EST show to play and no matter what I try it just says "Couldn't locate video url".
http://pastebin.com/peBUFjn2
is all I see when trying debug mode out but from reading it I can't really determine the cause of failure.
I tried this on Win 7, 8, and Raspbmc on the Raspberry Pi. All fail.
Also apparently the subject of this thread is too long because I had to delete "MC" off of XBMC at the end before it would even permit me to post a reply.
2013-07-11, 04:42
(2013-07-11, 04:13)RedPenguin Wrote: [ -> ]Does anybody know how to get "The Young Turks" to play on this plugin?
Replace your YouTubePlayer.py (from the last page) It will work. I just did it.
2013-07-11, 04:50
(2013-07-11, 04:42)tinfox Wrote: [ -> ](2013-07-11, 04:13)RedPenguin Wrote: [ -> ]Does anybody know how to get "The Young Turks" to play on this plugin?
Wow thank you so very much. I wasn't sure if that would work at first being it said mainly for VEVO but it worked perfectly .
2013-07-12, 01:01
This last step is where this instruction fails for me.
As you can see, my youtube user ID does NOT end in @pages.plusgoogle.com, and any attempt to login with that youtube user ID and my regular youtube password gave me an error message. ("The username or password is incorrect.")
And yes, I tried both capital I and small L in my user ID. Neither worked.
This add-on is horribly frustrating.
2013-07-12, 05:47
I dunno what I did differently............................like I said I messed with a lot of stuff. I seem to remember a part where it asked something about enabling something to use devices.....................that it would create a password that could be used across platforms that would be compatible with both google and youtube or something like that...............basically creating one password for everything that would eliminate the confusion on devices that wouldn't allow you to choose.............or I may have had too much bourbon......................
I will see if I can find where that is again and what I did.................
Ok..................if this works I will edit my first post to include this.............
Log into youtube on your pc
Click the arrow in the upper right corner next to your name
In the header that pops up under google+ click settings
On the google+ settings page, scroll down to "Third Party Tools"
I am not sure what it will say to you, to me it asks about setting up a password. When I click that it shows me that my auto-generated username is my old user name plus some numbers ending in the pages.plusgoogle.com thingy..............and something about "one password for all of google"......I think that you have to enable the third party tools first to get the new username, then follow my previous steps. Hope this works.
2013-07-12, 14:02
4:56:31 T:140407111415552 NOTICE: YouTube-4.4.4
14:56:31 T:140407111415552 NOTICE: CommonFunctions-2.5.1
14:56:31 T:140407111415552 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ImportError'>
Error Contents: No module named SimpleDownloader
File "/storage/.xbmc/addons/plugin.video.youtube/default.py", line 90, in <module>
import SimpleDownloader as downloader
ImportError: No module named SimpleDownloader
14:56:32 T:140408393684800 ERROR: GetDirectory - Error getting plugin://plugin.video.youtube
14:56:32 T:140408393684800 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.youtube) failed
2013-07-13, 21:20
Hi
I have Raspbian and XBMC installed but I'm not able to play Youtube videos. I frequently get failures trying to open the stream, see messages in the XBMC log sometimes saying unsupported format, but whenever I do get a download that looks like it's succedded only the audio plays and I get on Open GL Spectrum graphic displayed but no video.
I loaded the Youtube plugin using Addons. I turned on debug and you can find the xbmc log here => http://filebin.ca/ntSEi48dYCj/xbmc.log. I put there as it's to big for pastebin. I hope someone can shed light on the issue(s) to help me out ( and maybe help others too_.
thanks
John
thanks
John
2013-07-13, 23:28
The plugin is broken again! for HTML5
2013-07-14, 01:29
new youtubeplayer.py see: https://code.google.com/p/youtubexbmc/is...?id=95#c67
2013-07-17, 07:16
Even when using the pages.plusgoogle.com account, I still can't login to my YouTube account.
2013-07-18, 00:53
Are Youtube videos extremely slow to load for anyone else? No matter what quality the video is, it takes a good 2 minutes to start playing, but after that it seems to be totally fine.
Edit: Guess I should have deferred to Google first. Disabling the Watchdog add-on has fixed everything.
2013-07-18, 03:17
The new version allows me to login to my YouTube account using my email address, however I am still having problems accessing My Subscriptions.
~/.xbmc/temp/xbmc.log
18:10:30 T:3077416832 NOTICE: -----------------------------------------------------------------------
18:10:30 T:3077416832 NOTICE: Starting XBMC (12.2 Git:Unknown), Platform: Linux (Fedora release 18 (Spherical Cow), 3.8.5-201.fc18.i686 i686). Built on Jun 6 2013
18:10:30 T:3077416832 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
18:10:30 T:3077416832 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
18:10:30 T:3077416832 NOTICE: special://masterprofile/ is mapped to: /home/jonathan/.xbmc/userdata
18:10:30 T:3077416832 NOTICE: special://home/ is mapped to: /home/jonathan/.xbmc
18:10:30 T:3077416832 NOTICE: special://temp/ is mapped to: /home/jonathan/.xbmc/temp
18:10:30 T:3077416832 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
18:10:30 T:3077416832 NOTICE: Local hostname: alfonso
18:10:30 T:3077416832 NOTICE: Log File is located: /home/jonathan/.xbmc/temp/xbmc.log
18:10:30 T:3077416832 WARNING: CXRandR::Query - output LVDS1 has no current mode, assuming disconnected
18:10:31 T:3077416832 NOTICE: load settings...
18:10:31 T:3077416832 NOTICE: special://profile/ is mapped to: special://masterprofile/
18:10:31 T:3077416832 NOTICE: loading special://masterprofile/guisettings.xml
18:10:31 T:3077416832 NOTICE: Getting hardware information now...
18:10:31 T:3077416832 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
18:10:31 T:3077416832 NOTICE: Loaded playercorefactory configuration
18:10:31 T:3077416832 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
18:10:31 T:3077416832 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
18:10:31 T:3077416832 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
18:10:31 T:3077416832 NOTICE: Loaded settings file from special://profile/advancedsettings.xml
18:10:31 T:3077416832 NOTICE: Contents of special://profile/advancedsettings.xml are...
<advancedsettings>
<network>
<cachemembuffersize>357913941</cachemembuffersize>
</network>
</advancedsettings>
18:10:31 T:3077416832 NOTICE: Default DVD Player: dvdplayer
18:10:31 T:3077416832 NOTICE: Default Video Player: dvdplayer
18:10:31 T:3077416832 NOTICE: Default Audio Player: paplayer
18:10:31 T:3077416832 NOTICE: Disabled debug logging due to GUI setting. Level 0.
18:10:31 T:3077416832 NOTICE: Log level changed to 0
18:10:31 T:3077416832 NOTICE: Loading media sources from special://masterprofile/sources.xml
18:10:31 T:3077416832 NOTICE: Running database version Addons15
18:10:34 T:3074460480 NOTICE: Thread XBMC Peripherals start, auto delete: false
18:10:34 T:3077416832 NOTICE: Previous line repeats 1 times.
18:10:34 T:3077416832 NOTICE: Setup SDL
18:10:34 T:3077416832 NOTICE: Checking resolution 15
18:10:35 T:3077416832 NOTICE: Using visual 0x22
18:10:35 T:3077416832 NOTICE: GL_VENDOR = Intel Open Source Technology Center
18:10:35 T:3077416832 NOTICE: GL_RENDERER = Mesa DRI Intel(R) IGD
18:10:35 T:3077416832 NOTICE: GL_VERSION = 1.4 Mesa 9.0.1
18:10:35 T:3077416832 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.20
18:10:35 T:3077416832 NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_multitexture GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_3DFX_texture_compression_FXT1 GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_NV_vertex_program GL_ARB_depth_texture GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_vertex_program1_1 GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_MESA_ycbcr_texture GL_ARB_half_float_pixel GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_pixel_buffer_object GL_ARB_texture_rectangle GL_EXT_pixel_buffer_object GL_EXT_texture_rectangle GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_packed_depth_stencil GL_APPLE_object_purgeable GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_EXT_gpu_program_parameters GL_OES_EGL_image GL_ARB_copy_buffer GL_ARB_map_buffer_range GL_EXT_separate_shader_objects GL_ARB_ES2_compatibility GL_ARB_debug_output GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_provoking_vertex GL_ARB_sampler_objects GL_ARB_texture_rgb10_a2ui GL_EXT_provoking_vertex GL_ARB_robustness GL_ARB_texture_storage GL_ARB_invalidate_subdata
18:10:36 T:3077416832 NOTICE: Running database version Addons15
18:10:36 T:3077416832 NOTICE: Running database version ViewModes4
18:10:36 T:3077416832 NOTICE: Running database version Textures13
18:10:36 T:3077416832 NOTICE: Running database version MyMusic32
18:10:36 T:3077416832 NOTICE: Running database version MyVideos75
18:10:36 T:3077416832 NOTICE: Running database version TV22
18:10:36 T:3077416832 NOTICE: Running database version Epg7
18:10:36 T:3077416832 NOTICE: start dvd mediatype detection
18:10:36 T:3077416832 NOTICE: initializing playlistplayer
18:10:36 T:3077416832 NOTICE: DONE initializing playlistplayer
18:10:36 T:3075087168 NOTICE: Thread CDetectDVDMedia start, auto delete: false
18:10:37 T:2932861760 NOTICE: Thread XBPyThread start, auto delete: false
18:10:37 T:3077416832 NOTICE: initialize done
18:10:37 T:3077416832 NOTICE: Running the application...
18:10:37 T:2924469056 NOTICE: Thread XBPyThread start, auto delete: false
18:10:38 T:2932861760 NOTICE: -->Python Interpreter Initialized<--
18:10:38 T:2924469056 NOTICE: -->Python Interpreter Initialized<--
18:10:38 T:2897292096 NOTICE: Thread Jobworker start, auto delete: true
18:10:38 T:3077416832 NOTICE: Webserver: Starting...
18:10:38 T:3077416832 NOTICE: WebServer: Started the webserver
18:10:38 T:3077416832 NOTICE: ES: Starting event server
18:10:38 T:3077416832 NOTICE: starting zeroconf publishing
18:10:38 T:2846935872 NOTICE: Thread CEventServer start, auto delete: false
18:10:38 T:2846935872 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
18:10:38 T:2846935872 NOTICE: UDP: Listening on port 9777
18:10:38 T:2830150464 NOTICE: Thread Jobworker start, auto delete: true
18:10:38 T:2838543168 NOTICE: Thread CTCPServer start, auto delete: false
18:10:38 T:2924469056 NOTICE: StorageServer Module loaded RUN
18:10:38 T:2924469056 NOTICE: StorageClient-2.5.2 Starting server
18:10:38 T:2924469056 NOTICE: StorageServer-2.5.2 Storage Server starting /home/jonathan/.xbmc/temp/commoncache.db
18:10:38 T:3075087168 NOTICE: Thread CRssReader start, auto delete: false
18:10:39 T:3077416832 ERROR: GLX: Same window as before, refreshing context
18:10:42 T:3077416832 ERROR: CheckDisplayEvents - no display event after 3 seconds
18:10:54 T:3077416832 ERROR: GLX: Same window as before, refreshing context
18:11:06 T:3077416832 ERROR: Previous line repeats 1 times.
18:11:06 T:3077416832 ERROR: CheckDisplayEvents - no display event after 3 seconds
18:11:07 T:2932861760 NOTICE: Thread Background Loader start, auto delete: false
18:11:08 T:2932861760 NOTICE: Thread Jobworker start, auto delete: true
18:11:10 T:2794580800 NOTICE: Previous line repeats 1 times.
18:11:10 T:2794580800 NOTICE: Thread XBPyThread start, auto delete: false
18:11:10 T:2794580800 NOTICE: -->Python Interpreter Initialized<--
18:11:10 T:2794580800 NOTICE: Loading cookies from :'/home/jonathan/.xbmc/userdata/addon_data/plugin.video.youtube/yt-cookiejar.txt'
18:11:10 T:2794580800 NOTICE: YouTube-4.4.6
18:11:10 T:2794580800 NOTICE: CommonFunctions-2.5.1
18:11:11 T:2794580800 NOTICE: Thread Background Loader start, auto delete: false
18:11:13 T:2794580800 NOTICE: Thread XBPyThread start, auto delete: false
18:11:13 T:2794580800 NOTICE: -->Python Interpreter Initialized<--
18:11:13 T:2794580800 NOTICE: Loading cookies from :'/home/jonathan/.xbmc/userdata/addon_data/plugin.video.youtube/yt-cookiejar.txt'
18:11:13 T:2794580800 NOTICE: YouTube-4.4.6
18:11:14 T:2794580800 NOTICE: CommonFunctions-2.5.1
18:11:15 T:3077416832 ERROR: GetDirectory - Error getting plugin://plugin.video.youtube/?folder=true&login=true&path=%2froot%2fsubscriptions&user_feed=subscriptions
18:11:15 T:3077416832 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.youtube/?folder=true&login=true&path=%2froot%2fsubscriptions&user_feed=subscriptions) failed
18:11:15 T:2794580800 NOTICE: Thread Background Loader start, auto delete: false
18:11:19 T:2794580800 NOTICE: Thread XBPyThread start, auto delete: false
18:11:19 T:2794580800 NOTICE: -->Python Interpreter Initialized<--
18:11:19 T:2794580800 NOTICE: Loading cookies from :'/home/jonathan/.xbmc/userdata/addon_data/plugin.video.youtube/yt-cookiejar.txt'
18:11:19 T:2794580800 NOTICE: YouTube-4.4.6
18:11:19 T:2794580800 NOTICE: CommonFunctions-2.5.1
18:11:23 T:2794580800 NOTICE: Thread Background Loader start, auto delete: false
18:11:29 T:3077416832 ERROR: GLX: Same window as before, refreshing context
18:12:19 T:2821757760 NOTICE: Thread Background Loader start, auto delete: false
18:12:20 T:2932861760 NOTICE: Thread Jobworker start, auto delete: true
18:12:20 T:3077416832 NOTICE: Previous line repeats 1 times.
18:12:20 T:3077416832 ERROR: GLX: Same window as before, refreshing context
18:12:22 T:2897292096 NOTICE: Thread Background Loader start, auto delete: false
18:12:22 T:2830150464 NOTICE: Thread Jobworker start, auto delete: true
18:12:23 T:3077416832 ERROR: CheckDisplayEvents - no display event after 3 seconds
18:12:24 T:2897292096 NOTICE: Thread XBPyThread start, auto delete: false
18:12:24 T:2897292096 NOTICE: -->Python Interpreter Initialized<--
18:12:25 T:2897292096 NOTICE: Loading cookies from :'/home/jonathan/.xbmc/userdata/addon_data/plugin.video.youtube/yt-cookiejar.txt'
18:12:25 T:2897292096 NOTICE: YouTube-4.4.6
18:12:25 T:2897292096 NOTICE: CommonFunctions-2.5.1
18:12:25 T:2793270080 NOTICE: Thread Background Loader start, auto delete: false
18:12:25 T:2793270080 NOTICE: Thread Jobworker start, auto delete: true
18:12:27 T:2897292096 NOTICE: Thread XBPyThread start, auto delete: false
18:12:27 T:2897292096 NOTICE: -->Python Interpreter Initialized<--
18:12:27 T:2897292096 NOTICE: Loading cookies from :'/home/jonathan/.xbmc/userdata/addon_data/plugin.video.youtube/yt-cookiejar.txt'
18:12:27 T:2897292096 NOTICE: YouTube-4.4.6
18:12:28 T:2897292096 NOTICE: CommonFunctions-2.5.1
18:12:29 T:3077416832 ERROR: GetDirectory - Error getting plugin://plugin.video.youtube/?folder=true&login=true&path=%2froot%2fsubscriptions&user_feed=subscriptions
18:12:29 T:3077416832 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.youtube/?folder=true&login=true&path=%2froot%2fsubscriptions&user_feed=subscriptions) failed
18:12:29 T:2897292096 NOTICE: Thread Background Loader start, auto delete: false
18:12:31 T:2897292096 NOTICE: Thread XBPyThread start, auto delete: false
18:12:32 T:2897292096 NOTICE: -->Python Interpreter Initialized<--
18:12:32 T:2897292096 NOTICE: Loading cookies from :'/home/jonathan/.xbmc/userdata/addon_data/plugin.video.youtube/yt-cookiejar.txt'
18:12:32 T:2897292096 NOTICE: YouTube-4.4.6
18:12:32 T:2897292096 NOTICE: CommonFunctions-2.5.1
18:12:34 T:2784877376 NOTICE: Thread XBPyThread start, auto delete: false
18:12:34 T:2784877376 NOTICE: -->Python Interpreter Initialized<--
18:12:34 T:2784877376 NOTICE: Loading cookies from :'/home/jonathan/.xbmc/userdata/addon_data/plugin.video.youtube/yt-cookiejar.txt'
18:12:35 T:2784877376 NOTICE: YouTube-4.4.6
18:12:35 T:2784877376 NOTICE: CommonFunctions-2.5.1
18:12:35 T:2784877376 NOTICE: Thread Background Loader start, auto delete: false
18:12:35 T:3077416832 NOTICE: Previous line repeats 1 times.
18:12:35 T:3077416832 ERROR: GetDirectory - Error getting plugin://plugin.video.youtube/?action=settings&path=%2froot%2fsettings
18:12:35 T:3077416832 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.youtube/?action=settings&path=%2froot%2fsettings) failed
18:12:35 T:2784877376 NOTICE: Thread XBPyThread start, auto delete: false
18:12:35 T:2784877376 NOTICE: -->Python Interpreter Initialized<--
18:12:35 T:2784877376 NOTICE: Loading cookies from :'/home/jonathan/.xbmc/userdata/addon_data/plugin.video.youtube/yt-cookiejar.txt'
18:12:36 T:2897292096 NOTICE: Thread Background Loader start, auto delete: false
18:12:37 T:2897292096 NOTICE: Previous line repeats 1 times.
18:12:37 T:2897292096 NOTICE: Thread XBPyThread start, auto delete: false
18:12:37 T:2897292096 NOTICE: -->Python Interpreter Initialized<--
18:12:38 T:2897292096 NOTICE: Loading cookies from :'/home/jonathan/.xbmc/userdata/addon_data/plugin.video.youtube/yt-cookiejar.txt'
18:12:38 T:2897292096 NOTICE: YouTube-4.4.6
18:12:38 T:2897292096 NOTICE: CommonFunctions-2.5.1
18:12:39 T:3077416832 ERROR: GetDirectory - Error getting plugin://plugin.video.youtube/?folder=true&login=true&path=%2froot%2fsubscriptions&user_feed=subscriptions
18:12:39 T:3077416832 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.youtube/?folder=true&login=true&path=%2froot%2fsubscriptions&user_feed=subscriptions) failed
18:12:39 T:2897292096 NOTICE: Thread XBPyThread start, auto delete: false
18:12:39 T:2897292096 NOTICE: -->Python Interpreter Initialized<--
18:12:39 T:2897292096 NOTICE: Loading cookies from :'/home/jonathan/.xbmc/userdata/addon_data/plugin.video.youtube/yt-cookiejar.txt'
18:12:39 T:2897292096 NOTICE: YouTube-4.4.6
18:12:39 T:2897292096 NOTICE: CommonFunctions-2.5.1
18:12:39 T:2784877376 NOTICE: Thread Background Loader start, auto delete: false
18:12:42 T:3077416832 ERROR: GLX: Same window as before, refreshing context
