2013-07-18, 06:17
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315
2013-07-18, 09:07
(2013-07-17, 07:16)MoronicAcid Wrote: [ -> ]Even when using the pages.plusgoogle.com account, I still can't login to my YouTube account.
Did you set a password and change both username and password in XBMC?
2013-07-18, 09:40
(2013-07-18, 06:17)marvtigre Wrote: [ -> ]@ Update to 4.4.6
' Script failed! : plugin.video.youtube ' on OpenElec on HTPC as well as on XBMC on PC.
Anyone?
Same problem. Here's the log file concerning this issue:
10:24:51 T:7760 NOTICE: YouTube-4.4.6
10:24:51 T:7760 NOTICE: CommonFunctions-2.5.1
10:24:52 T:7760 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.UnicodeEncodeError'>
Error Contents: 'ascii' codec can't encode characters in position 0-4: ordinal not in range(128)
File "C:\Users\Zoomer\AppData\Roaming\XBMC\addons\plugin.video.youtube\default.py", line 120, in <module>
navigation.executeAction(params)
File "C:\Users\Zoomer\AppData\Roaming\XBMC\addons\plugin.video.youtube\YouTubeNavigation.py", line 143, in executeAction
self.player.playVideo(params)
File "C:\Users\Zoomer\AppData\Roaming\XBMC\addons\plugin.video.youtube\YouTubePlayer.py", line 80, in playVideo
(video, status) = self.buildVideoObject(params)
File "C:\Users\Zoomer\AppData\Roaming\XBMC\addons\plugin.video.youtube\YouTubePlayer.py", line 285, in buildVideoObject
(links, video) = self.extractVideoLinksFromYoutube(video, params)
File "C:\Users\Zoomer\AppData\Roaming\XBMC\addons\plugin.video.youtube\YouTubePlayer.py", line 418, in extractVideoLinksFromYoutube
result = self.getVideoPageFromYoutube(get)
File "C:\Users\Zoomer\AppData\Roaming\XBMC\addons\plugin.video.youtube\YouTubePlayer.py", line 401, in getVideoPageFromYoutube
page = self.core._fetchPage({u"link": self.urls[u"video_stream"] % get(u"videoid"), "login": login})
File "C:\Users\Zoomer\AppData\Roaming\XBMC\addons\plugin.video.youtube\YouTubeCore.py", line 447, in _fetchPage
self.login._httpLogin()
File "C:\Users\Zoomer\AppData\Roaming\XBMC\addons\plugin.video.youtube\YouTubeLogin.py", line 183, in _httpLogin
ret = self.core._fetchPage(fetch_options)
File "C:\Users\Zoomer\AppData\Roaming\XBMC\addons\plugin.video.youtube\YouTubeCore.py", line 400, in _fetchPage
request = urllib2.Request(link, urllib.urlencode(get("url_data")))
File "C:\Program Files (x86)\XBMC\system\python\Lib\urllib.py", line 1269, in urlencode
v = quote_plus(str(v))
UnicodeEncodeError: 'ascii' codec can't encode characters in position 0-4: ordinal not in range(128)
10:24:52 T:7760 WARNING: The python script "C:\Users\Zoomer\AppData\Roaming\XBMC\addons\plugin.video.youtube\default.py" has left several classes in memory that we couldn't clean up. The classes include: Addon,Addon
10:24:52 T:5276 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.youtube/?path=/root/video&action=play_video&videoid=BUY6HGqYweQ]
Also is there a place I can download the previous version?
2013-07-18, 12:13
last night before the update i could play videos just fine, now it gives me that "script failed" error described on the post above
12:00:35 T:4912 NOTICE: YouTube-4.4.6
12:00:35 T:4912 NOTICE: CommonFunctions-2.5.1
12:00:37 T:4912 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Contents: 'ascii' codec can't encode character u'\xf3' in position 12: ordinal not in range(128)
File "C:\Users\~\AppData\Roaming\XBMC\addons\plugin.video.youtube\default.py", line 120, in <module>
File "C:\Users\~\AppData\Roaming\XBMC\addons\plugin.video.youtube\YouTubeNavigation.py", line 143, in executeAction
File "C:\Users\~\AppData\Roaming\XBMC\addons\plugin.video.youtube\YouTubePlayer.py", line 80, in playVideo
File "C:\Users\~\AppData\Roaming\XBMC\addons\plugin.video.youtube\YouTubePlayer.py", line 285, in buildVideoObject
File "C:\Users\~\AppData\Roaming\XBMC\addons\plugin.video.youtube\YouTubePlayer.py", line 418, in extractVideoLinksFromYoutube
File "C:\Users\~\AppData\Roaming\XBMC\addons\plugin.video.youtube\YouTubePlayer.py", line 401, in getVideoPageFromYoutube
File "C:\Users\~\AppData\Roaming\XBMC\addons\plugin.video.youtube\YouTubeCore.py", line 447, in _fetchPage
File "C:\Users\~\AppData\Roaming\XBMC\addons\plugin.video.youtube\YouTubeLogin.py", line 183, in _httpLogin
File "C:\Users\~\AppData\Roaming\XBMC\addons\plugin.video.youtube\YouTubeCore.py", line 400, in _fetchPage
UnicodeEncodeError: 'ascii' codec can't encode character u'\xf3' in position 12: ordinal not in range(128)
12:00:37 T:4912 WARNING: The python script "C:\Users\~\AppData\Roaming\XBMC\addons\plugin.video.youtube\default.py" has left several classes in memory that we couldn't clean up. The classes include: Addon,Addon
12:00:37 T:3780 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.youtube/?path=/root/video&action=play_video&videoid=ajtW-DrV-ps]
12:00:37 T:4600 NOTICE: Thread Background Loader start, auto delete: false
12:00:56 T:2608 NOTICE: Thread XBPyThread start, auto delete: false
12:00:56 T:2608 NOTICE: -->Python Interpreter Initialized<--
12:00:56 T:2608 NOTICE: Loading cookies from :'C:\\Users\\~\\AppData\\Roaming\\XBMC\\userdata\\addon_data\\plugin.video.youtube\\yt-cookiejar.txt'
12:00:56 T:2608 NOTICE: YouTube-4.4.6
12:00:56 T:2608 NOTICE: CommonFunctions-2.5.1
12:00:58 T:2608 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
12:00:58 T:2608 WARNING: The python script "C:\Users\~\AppData\Roaming\XBMC\addons\plugin.video.youtube\default.py" has left several classes in memory that we couldn't clean up. The classes include: Addon,Addon
12:00:58 T:3780 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.youtube/?path=/root/video&action=play_video&videoid=HF7JAyhnlQ0]
12:01:01 T:1916 NOTICE: Thread Background Loader start, auto delete: false
12:01:20 T:4376 NOTICE: Thread XBPyThread start, auto delete: false
12:01:20 T:4376 NOTICE: -->Python Interpreter Initialized<--
12:01:20 T:4376 NOTICE: Loading cookies from :'C:\\Users\\~\\AppData\\Roaming\\XBMC\\userdata\\addon_data\\plugin.video.youtube\\yt-cookiejar.txt'
12:01:20 T:4376 NOTICE: YouTube-4.4.6
12:01:20 T:4376 NOTICE: CommonFunctions-2.5.1
12:01:23 T:4376 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
12:01:23 T:4376 WARNING: The python script "C:\Users\~\AppData\Roaming\XBMC\addons\plugin.video.youtube\default.py" has left several classes in memory that we couldn't clean up. The classes include: Addon,Addon
12:01:23 T:3780 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.youtube/?path=/root/video&action=play_video&videoid=Zgc5w-xyQa0]
12:01:23 T:4368 NOTICE: Thread Background Loader start, auto delete: false
12:01:25 T:5016 NOTICE: Thread XBPyThread start, auto delete: false
12:01:25 T:5016 NOTICE: -->Python Interpreter Initialized<--
12:01:25 T:5016 NOTICE: Loading cookies from :'C:\\Users\\~\\AppData\\Roaming\\XBMC\\userdata\\addon_data\\plugin.video.youtube\\yt-cookiejar.txt'
12:01:25 T:5016 NOTICE: YouTube-4.4.6
12:01:25 T:5016 NOTICE: CommonFunctions-2.5.1
12:01:27 T:5016 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
12:01:27 T:5016 WARNING: The python script "C:\Users\~\AppData\Roaming\XBMC\addons\plugin.video.youtube\default.py" has left several classes in memory that we couldn't clean up. The classes include: Addon,Addon
12:01:27 T:3780 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.youtube/?path=/root/video&action=play_video&videoid=9qCgyyzqD_g]
12:01:27 T:2184 NOTICE: Thread Background Loader start, auto delete: false
12:01:33 T:4156 NOTICE: Thread XBPyThread start, auto delete: false
12:01:33 T:4156 NOTICE: -->Python Interpreter Initialized<--
12:01:33 T:4156 NOTICE: Loading cookies from :'C:\\Users\\~\\AppData\\Roaming\\XBMC\\userdata\\addon_data\\plugin.video.youtube\\yt-cookiejar.txt'
12:01:33 T:4156 NOTICE: YouTube-4.4.6
12:01:33 T:4156 NOTICE: CommonFunctions-2.5.1
12:01:35 T:4156 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
12:01:35 T:4156 WARNING: The python script "C:\Users\~\AppData\Roaming\XBMC\addons\plugin.video.youtube\default.py" has left several classes in memory that we couldn't clean up. The classes include: Addon,Addon
12:01:35 T:3780 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.youtube/?path=/root/video&action=play_video&videoid=9qCgyyzqD_g]
12:01:35 T:3652 NOTICE: Thread Background Loader start, auto delete: false
12:01:41 T:5108 NOTICE: Thread XBPyThread start, auto delete: false
12:01:41 T:5108 NOTICE: -->Python Interpreter Initialized<--
12:01:42 T:5108 NOTICE: Loading cookies from :'C:\\Users\\~\\AppData\\Roaming\\XBMC\\userdata\\addon_data\\plugin.video.youtube\\yt-cookiejar.txt'
12:01:42 T:5108 NOTICE: YouTube-4.4.6
12:01:42 T:5108 NOTICE: CommonFunctions-2.5.1
12:01:44 T:5108 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
12:01:44 T:5108 WARNING: The python script "C:\Users\~\AppData\Roaming\XBMC\addons\plugin.video.youtube\default.py" has left several classes in memory that we couldn't clean up. The classes include: Addon,Addon
12:01:44 T:3780 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.youtube/?path=/root/video&action=play_video&videoid=3F0pJv8BToA]
12:01:45 T:2760 NOTICE: Thread Background Loader start, auto delete: false
2013-07-18, 16:02
it works again
edit: worked for 1 video then it stopped working again
(2013-07-18, 12:13)tuputamadre Wrote: [ -> ]last night before the update i could play videos just fine, now it gives me that "script failed" error described on the post above
Code:12:00:35 T:4912 NOTICE: YouTube-4.4.6
2013-07-18, 18:12
Script failed message also. Yesterday worked fine - now not...
18:55:46 T:140118897358592 NOTICE: YouTube-4.4.6
18:55:47 T:140118897358592 NOTICE: CommonFunctions-2.5.1
18:55:48 T:140118897358592 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Contents: 'ascii' codec can't encode characters in position 12-13: ordinal not in range(128)
File "/home/razerdog/.xbmc/addons/plugin.video.youtube/default.py", line 120, in <module>
File "/home/razerdog/.xbmc/addons/plugin.video.youtube/YouTubeNavigation.py", line 143, in executeAction
File "/home/razerdog/.xbmc/addons/plugin.video.youtube/YouTubePlayer.py", line 80, in playVideo
File "/home/razerdog/.xbmc/addons/plugin.video.youtube/YouTubePlayer.py", line 285, in buildVideoObject
File "/home/razerdog/.xbmc/addons/plugin.video.youtube/YouTubePlayer.py", line 418, in extractVideoLinksFromYoutube
File "/home/razerdog/.xbmc/addons/plugin.video.youtube/YouTubePlayer.py", line 401, in getVideoPageFromYoutube
File "/home/razerdog/.xbmc/addons/plugin.video.youtube/YouTubeCore.py", line 447, in _fetchPage
File "/home/razerdog/.xbmc/addons/plugin.video.youtube/YouTubeLogin.py", line 183, in _httpLogin
File "/home/razerdog/.xbmc/addons/plugin.video.youtube/YouTubeCore.py", line 400, in _fetchPage
File "/usr/lib/python2.7/urllib.py", line 1312, in urlencode
UnicodeEncodeError: 'ascii' codec can't encode characters in position 12-13: ordinal not in range(128)
2013-07-19, 02:00
ok, so i rolled back to 4.4.4 and it started working again, why didnt i think of this sooner? lol
2013-07-19, 02:09
(2013-07-19, 02:00)tuputamadre Wrote: [ -> ]ok, so i rolled back to 4.4.4 and it started working again, why didnt i think of this sooner? lol
Could you please share the download link?
2013-07-19, 02:32
I had the same problem with 4.4.6 but it start working again a couple of hours ago.
2013-07-19, 06:43
2013-07-19, 10:03
(2013-07-19, 06:43)marvtigre Wrote: [ -> ](2013-07-19, 02:09)Zoomer88 Wrote: [ -> ](2013-07-19, 02:00)tuputamadre Wrote: [ -> ]ok, so i rolled back to 4.4.4 and it started working again, why didnt i think of this sooner? lol
You have 'Rollback' option in plugin's info.
Sadly, not in OpenELEC :/
Yeah, see it now. I'm an idiot, sorry :\
2013-07-19, 23:31
4.4.6 does not work for me ether. Rolling back to 4.4.4.did fix it. Seems there might be a bug in this release.
2013-07-20, 00:19
i'm sorry but 4.4.4 and 4.4.6 are not working for me - something has changed with Youtube ?
2013-07-20, 08:23
I was hoping someone can help me with a subscription not showing up.
I'm using version 4.4.6, though the problem also occurred with v 4.4.5.
I added a subscription for Freeman's Mind, which is unfortunately part of the Machinma conglomerate.
Here's the url to the Freemans Mind channel...
The subscription shows up in my Youtube subscriptions sidebar on my PC's browser, however it will not appear in the subscriptions for the Youtube plugin.
Could the problem be Machinima?
I was wondering if Freemans Mind is a Machinima playlist, which might be the cause. Though, it does appear as a subscription in my PC's browser. Also, the URL is a "channel" url.
Anyone else experience this problem, or have a solution.
Thanks to the developers for this plugin, it's incredible.
https://www.youtube.com/channel/SWbYPdeqBaYDg
2013-07-20, 12:46
I would be grateful if someone could let me know where the YouTube plug in Log File is stored when using the OPENELEC version of XMBC.
