Full Version: [depricated] old YouTube Plugin - XBMC 13.0 Frodo/Gotham only
(2013-10-11, 18:01)Baswazz Wrote: [ -> ]I can't play some video's:
http://www.youtube.com/watch?v=ghb6eDopW8I
https://www.youtube.com/watch?v=cmSbXsFE3l8
It does work for me, did you updated the YouTubePlayer.py file so it reproduce the files from VEVO? VEVO put a limitation so you couldn't download the videos some time ago, so the plugin wasn't able to watch those, if you can't find it I'll upload a backup of my YouTubePlayer.py
https://code.google.com/p/youtubexbmc/is...tail?id=95
the #163
Still unable to login, and unwilling to delete my Google+ account to fix it. Any suggestions or plans to find a solution?
(2013-10-11, 21:27)Knurlhelm Wrote: [ -> ]
the #163
Thanks that did the trick. Smile
Can anyone help me with this? The last time it did this, someone said to use that YouTubePlayer.py file that Knurlhelm referred to. It worked then. But nothing I do is helping anymore. I haven't been able to watch the Young Turks live stream for at least a month.
Here's my log file: http://xbmclogs.com/show.php?id=68950
And here's a direct link to the live stream if you need it: http://www.youtube.com/watch?v=U2CKDRQBUsI
Thanks for any help you can give!
Post Deleted
Did Google borked things again? I can't see any of my subscriptions or history since this morning.
is there a way to get the same results as i get on my desktop when i do a search on youtube?
kind of frustrating when it doesn't show the results properly.
(2013-10-15, 21:27)verismo Wrote: [ -> ]is there a way to get the same results as i get on my desktop when i do a search on youtube?
Examples of such?
Just did a quick search to find an example:
When i search "Stand up comedians" on xbmc and normal youtube, they both show different results
"justin bieber" appears to be working fine though
You probably getting results based on prefs and history, which I don't think you get with the app
(2013-10-17, 13:41)gott_sei_dank Wrote: [ -> ]
same thing happens in private browsing
Something has happened, youtube.plugin works again!
All I did upgraded to newest 3.2.3 version..
(2013-10-18, 21:14)pumo Wrote: [ -> ]Something has happened, youtube.plugin works again!
Could you point me to this version, please?
My current version is 4.4.6...
Sorry. With Openelec 3.2.3 youtube plugin works.
