recently I have thi problem with xbmc plugin 4.4.6 on xbmc 12.3 (win 7 ultimate):
the plugin login apparently correctly to my account but every time I selecy my subrisctions or favorites or anything else it says "No results"...
I had a channell on youtube where sometimes i upload some videos. recently youtube ask me in which way I want to identify myself on youtube: my gmail or the channel name, I select the channel name (maybe is an identity linked to my gmail). I tried to set on xbmc plugin the gmail credential and also the youtube linked identity credential: the credential are accepted both from plugin but the problem is the same.
I attached debug log of my session: started plugin - my subscription selection - my favorites selection (both no results), the login is my principal gmail account.
16:38:50 T:2108 NOTICE: -----------------------------------------------------------------------
16:38:50 T:2108 NOTICE: Starting XBMC (12.3 Git:20131212-9ed3e58), Platform: Windows 7 64-bit, build 7600. Built on Dec 19 2013 (compiler 1600)
16:38:50 T:2108 NOTICE: Intel(R) Atom(TM) CPU 330 @ 1.60GHz
16:38:50 T:2108 NOTICE: Desktop Resolution: 1280x720 32Bit at 60Hz
16:38:50 T:2108 NOTICE: Running with administrator rights
16:38:50 T:2108 NOTICE: Aero is enabled
16:38:50 T:2108 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\XBMC
16:38:50 T:2108 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\XBMC
16:38:50 T:2108 NOTICE: special://masterprofile/ is mapped to: C:\Users\Riccardo\AppData\Roaming\XBMC\userdata
16:38:50 T:2108 NOTICE: special://home/ is mapped to: C:\Users\Riccardo\AppData\Roaming\XBMC\
16:38:50 T:2108 NOTICE: special://temp/ is mapped to: C:\Users\Riccardo\AppData\Roaming\XBMC\cache
16:38:50 T:2108 NOTICE: The executable running is: C:\Program Files (x86)\XBMC\XBMC.exe
16:38:50 T:2108 NOTICE: Local hostname: mediacenter
16:38:50 T:2108 NOTICE: Log File is located: C:\Users\Riccardo\AppData\Roaming\XBMC\xbmc.log
16:38:51 T:2108 NOTICE: Found 2 Lists of Devices
16:38:51 T:2108 NOTICE: Enumerated DirectSound devices:
16:38:51 T:2108 NOTICE: Device 1
16:38:51 T:2108 NOTICE: m_deviceName : {6D11DD53-2422-42D5-B725-A4784A710241}
16:38:51 T:2108 NOTICE: m_displayName : HDMI - NVIDIA HDMI Out (NVIDIA High Definition Audio)
16:38:51 T:2108 NOTICE: m_displayNameExtra: DirectSound: NVIDIA HDMI Out (NVIDIA High Definition Audio)
16:38:51 T:2108 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
16:38:51 T:2108 NOTICE: m_channels : FL,FR
16:38:51 T:2108 NOTICE: m_sampleRates : 48000
16:38:51 T:2108 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_AC3
16:38:51 T:2108 NOTICE: Device 2
16:38:51 T:2108 NOTICE: m_deviceName : {2EB0AF4E-4C01-4AF0-BCB4-4392F9DE737C}
16:38:51 T:2108 NOTICE: m_displayName : SPDIF - Digital Audio (S/PDIF) (2- High Definition Audio Device)
16:38:51 T:2108 NOTICE: m_displayNameExtra: DirectSound: Digital Audio (S/PDIF) (2- High Definition Audio Device)
16:38:51 T:2108 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
16:38:51 T:2108 NOTICE: m_sampleRates : 44100
16:38:51 T:2108 NOTICE: Enumerated WASAPI devices:
16:38:51 T:2108 NOTICE: m_displayNameExtra: WASAPI: Digital Audio (S/PDIF) (2- High Definition Audio Device)
16:38:51 T:2108 NOTICE: m_sampleRates : 192000,96000,88200,48000,44100
16:38:51 T:2108 NOTICE: m_dataFormats : AE_FMT_DTS,AE_FMT_AC3,AE_FMT_AAC,AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S32NE,AE_FMT_S32LE,AE_FMT_S32BE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
16:38:51 T:2108 NOTICE: m_displayNameExtra: WASAPI: NVIDIA HDMI Out (NVIDIA High Definition Audio)
16:38:51 T:2108 NOTICE: m_sampleRates : 48000,44100
16:38:51 T:2108 NOTICE: m_dataFormats : AE_FMT_EAC3,AE_FMT_DTS,AE_FMT_AC3,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
16:38:51 T:2108 NOTICE: load settings...
16:38:51 T:2108 NOTICE: special://profile/ is mapped to: special://masterprofile/
16:38:51 T:2108 NOTICE: loading special://masterprofile/guisettings.xml
16:38:51 T:2108 NOTICE: Getting hardware information now...
16:38:51 T:2108 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
16:38:51 T:2108 NOTICE: Loaded playercorefactory configuration
16:38:51 T:2108 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
16:38:51 T:2108 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
16:38:51 T:2108 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
16:38:51 T:2108 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
16:38:51 T:2108 NOTICE: Default DVD Player: dvdplayer
16:38:51 T:2108 NOTICE: Default Video Player: dvdplayer
16:38:51 T:2108 NOTICE: Default Audio Player: paplayer
16:38:51 T:2108 NOTICE: Disabled debug logging due to GUI setting. Level 0.
16:38:51 T:2108 NOTICE: Log level changed to 0
16:38:51 T:2108 NOTICE: Loading media sources from special://masterprofile/sources.xml
16:38:51 T:3852 NOTICE: Thread CSoftAE start, auto delete: false
16:38:51 T:2108 NOTICE: Running database version Addons15
16:38:51 T:3068 NOTICE: Thread XBMC Peripherals start, auto delete: false
16:38:51 T:1556 NOTICE: Thread CRemoteControl start, auto delete: false
16:38:51 T:2976 NOTICE: Thread XBMC Peripherals start, auto delete: false
16:38:51 T:2108 NOTICE: Found screen: Generic PnP Monitor on NVIDIA ION, adapter 0.
16:38:51 T:2108 NOTICE: Primary mode: 1280x720 @ 60.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 640x480 @ 60.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 640x480 @ 59.94 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 720x480 @ 60.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 720x480 @ 59.94 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 720x576 @ 50.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 800x600 @ 50.00 - Full Screen
16:38:51 T:2108 NOTICE: Previous line repeats 2 times.
16:38:51 T:2108 NOTICE: Additional mode: 800x600 @ 60.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 800x600 @ 59.94 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1024x768 @ 50.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1024x768 @ 60.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1024x768 @ 59.94 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1024x768 @ 24.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1024x768 @ 23.98 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1152x864 @ 50.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1152x864 @ 60.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1152x864 @ 59.94 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1152x864 @ 24.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1152x864 @ 23.98 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1176x664 @ 50.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1176x664 @ 60.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1176x664 @ 59.94 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1280x720 @ 50.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1280x720 @ 60.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1280x720 @ 59.94 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1280x768 @ 50.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1280x768 @ 60.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1280x768 @ 59.94 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1280x768 @ 24.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1280x768 @ 23.98 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1280x800 @ 50.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1280x800 @ 60.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1280x800 @ 59.94 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1280x800 @ 24.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1280x800 @ 23.98 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1280x960 @ 50.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1280x960 @ 60.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1280x960 @ 59.94 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1280x960 @ 24.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1280x960 @ 23.98 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1280x1024 @ 50.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1280x1024 @ 60.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1280x1024 @ 59.94 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1280x1024 @ 24.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1280x1024 @ 23.98 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1360x768 @ 50.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1360x768 @ 60.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1360x768 @ 59.94 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1360x768 @ 24.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1360x768 @ 23.98 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1366x768 @ 50.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1366x768 @ 60.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1366x768 @ 59.94 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1366x768 @ 24.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1366x768 @ 23.98 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1600x900 @ 50.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1600x900 @ 60.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1600x900 @ 59.94 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1600x900 @ 24.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1600x900 @ 23.98 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1600x1024 @ 50.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1600x1024 @ 60.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1600x1024 @ 59.94 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1600x1024 @ 24.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1600x1024 @ 23.98 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1680x1050 @ 50.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1680x1050 @ 60.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1680x1050 @ 59.94 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1680x1050 @ 24.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1680x1050 @ 23.98 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1768x992 @ 50.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1768x992 @ 60.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1768x992 @ 59.94 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1768x992 @ 25.00i - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1768x992 @ 30.00i - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1768x992 @ 29.97i - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1768x992 @ 24.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1768x992 @ 23.98 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1920x1080 @ 50.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1920x1080 @ 60.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1920x1080 @ 59.94 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1920x1080 @ 25.00i - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1920x1080 @ 30.00i - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1920x1080 @ 29.97i - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1920x1080 @ 24.00 - Full Screen
16:38:51 T:2108 NOTICE: Additional mode: 1920x1080 @ 23.98 - Full Screen
16:38:52 T:2108 NOTICE: Checking resolution 16
16:38:53 T:2108 NOTICE: Running database version Addons15
16:38:53 T:2108 NOTICE: Running database version ViewModes4
16:38:53 T:2108 NOTICE: Running database version Textures13
16:38:53 T:2108 NOTICE: Running database version MyMusic32
16:38:53 T:2108 NOTICE: Running database version MyVideos75
16:38:53 T:2108 NOTICE: Running database version TV22
16:38:53 T:2108 NOTICE: Running database version Epg7
16:38:53 T:2108 NOTICE: initializing playlistplayer
16:38:53 T:2108 NOTICE: DONE initializing playlistplayer
16:38:54 T:3156 NOTICE: Thread XBPyThread start, auto delete: false
16:38:54 T:2108 NOTICE: CApplication::UpdateLibraries - Starting video library startup scan
16:38:54 T:864 NOTICE: Thread CVideoInfoScanner start, auto delete: false
16:38:54 T:2108 NOTICE: initialize done
16:38:54 T:1288 NOTICE: Thread XBPyThread start, auto delete: false
16:38:54 T:1288 NOTICE: -->Python Interpreter Initialized<--
16:38:54 T:3156 NOTICE: -->Python Interpreter Initialized<--
16:38:54 T:2108 NOTICE: Running the application...
16:38:54 T:1288 NOTICE: StorageServer Module loaded RUN
16:38:54 T:1288 NOTICE: StorageClient-2.5.2 Starting server
16:38:54 T:1288 NOTICE: StorageServer-2.5.2 Storage Server starting C:\Users\Riccardo\AppData\Roaming\XBMC\cache\commoncache.db
16:38:54 T:3344 NOTICE: Thread Jobworker start, auto delete: true
16:38:54 T:2108 NOTICE: Webserver: Starting...
16:38:54 T:2108 NOTICE: WebServer: Started the webserver
16:38:54 T:2108 NOTICE: starting upnp server
16:38:55 T:2108 NOTICE: starting upnp renderer
16:38:55 T:2108 NOTICE: ES: Starting event server
16:38:55 T:3356 NOTICE: Thread CEventServer start, auto delete: false
16:38:55 T:3356 NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
16:38:55 T:3356 NOTICE: UDP: Listening on port 9777
16:38:55 T:4476 NOTICE: Thread CTCPServer start, auto delete: false
16:38:55 T:864 NOTICE: VideoInfoScanner: Starting scan ..
16:38:55 T:4608 NOTICE: Thread CRssReader start, auto delete: false
16:38:55 T:864 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:01
16:38:57 T:4216 NOTICE: Thread Background Loader start, auto delete: false
16:39:00 T:4956 NOTICE: Thread XBPyThread start, auto delete: false
16:39:00 T:4956 NOTICE: -->Python Interpreter Initialized<--
16:39:00 T:4956 NOTICE: Loading cookies from :'C:\\Users\\Riccardo\\AppData\\Roaming\\XBMC\\userdata\\addon_data\\plugin.video.youtube\\yt-cookiejar.txt'
16:39:00 T:4956 NOTICE: YouTube-4.4.6 ARGV: ['plugin://plugin.video.youtube/', '1', '']
16:39:00 T:4956 NOTICE: [StorageClient-2.5.2] '__init__' : 'Setting table to : YouTube'
16:39:00 T:4956 NOTICE: CommonFunctions-2.5.1
16:39:01 T:4956 NOTICE: [YouTube-4.4.6] __init__ : ''
16:39:01 T:4956 NOTICE: [StorageClient-2.5.2] '__init__' : 'Setting table to : Downloader'
16:39:01 T:4956 NOTICE: [YouTube-4.4.6] __init__ : 'Done'
16:39:01 T:3012 NOTICE: Thread Background Loader start, auto delete: false
16:39:04 T:4916 NOTICE: Thread XBPyThread start, auto delete: false
16:39:04 T:4916 NOTICE: -->Python Interpreter Initialized<--
16:39:04 T:4916 NOTICE: Loading cookies from :'C:\\Users\\Riccardo\\AppData\\Roaming\\XBMC\\userdata\\addon_data\\plugin.video.youtube\\yt-cookiejar.txt'
16:39:04 T:4916 NOTICE: YouTube-4.4.6 ARGV: ['plugin://plugin.video.youtube/', '2', '?folder=true&login=true&path=%2froot%2fsubscriptions&user_feed=subscriptions']
16:39:04 T:4916 NOTICE: [StorageClient-2.5.2] '__init__' : 'Setting table to : YouTube'
16:39:05 T:4916 NOTICE: CommonFunctions-2.5.1
16:39:05 T:4916 NOTICE: [YouTube-4.4.6] __init__ : ''
16:39:05 T:4916 NOTICE: [StorageClient-2.5.2] '__init__' : 'Setting table to : Downloader'
16:39:05 T:4916 NOTICE: [YouTube-4.4.6] __init__ : 'Done'
16:39:05 T:4916 NOTICE: [YouTube-4.4.6] getXBMCVersion : '12.300000000000001'
16:39:05 T:4916 NOTICE: [YouTube-4.4.6] _getAuth : ''
16:39:05 T:4916 NOTICE: [YouTube-4.4.6] _fetchPage : 'called for : {'link': 'http://gdata.youtube.com/feeds/api/users/default/subscriptions?v=2.1&start-index=1&max-results=50', 'auth': 'true'}'
16:39:05 T:4916 NOTICE: [YouTube-4.4.6] _fetchPage : 'got auth'
16:39:05 T:4916 NOTICE: [YouTube-4.4.6] _fetchPage : 'updated link: http://gdata.youtube.com/feeds/api/users/default/subscriptions?v=2.1&start-index=1&max-results=50&oauth_token=ya29.1.AADtN_Vlk2KZ4pUWIGxV5d0i-BDsrrAK1kRiwf8llGwczAX58iX3M6tXGt4eyhPCku01UA'
16:39:05 T:4916 NOTICE: [YouTube-4.4.6] _fetchPage : 'got default: http://gdata.youtube.com/feeds/api/users/default/subscriptions?v=2.1&start-index=1&max-results=50&oauth_token=ya29.1.AADtN_Vlk2KZ4pUWIGxV5d0i-BDsrrAK1kRiwf8llGwczAX58iX3M6tXGt4eyhPCku01UA'
16:39:05 T:4916 NOTICE: [YouTube-4.4.6] _fetchPage : 'connecting to server... http://gdata.youtube.com/feeds/api/users/default/subscriptions?v=2.1&start-index=1&max-results=50&oauth_token=ya29.1.AADtN_Vlk2KZ4pUWIGxV5d0i-BDsrrAK1kRiwf8llGwczAX58iX3M6tXGt4eyhPCku01UA'
16:39:05 T:4916 NOTICE: [YouTube-4.4.6] _fetchPage : 'done'
16:39:05 T:4916 NOTICE: [YouTube-4.4.6] getFolderInfo : '<?xml version='1.0' encoding='UTF-8'?><feed xmlns='http://www.w3.org/2005/Atom' xmlns:openSearch='http://a9.com/-/spec/opensearch/1.1/' xmlns:gd='http://schemas.google.com/g/2005' xmlns:yt='http://gdata.youtube.com/schemas/2007' gd:etag='W/"CkAAQ3g9cSp7I2A9Wh5bFUQ."'><id>tag:youtube.com,2008:user:b6cOhdeKJhol2vmEDMLfbw:subscriptions</id><updated>2014-01-01T15:39:02.669Z</updated><category scheme='http://schemas.google.com/g/2005#kind' term='http://gdata.youtube.com/schemas/2007#subscription'/><title>Subscriptions of null null</title><logo>http://www.gstatic.com/youtube/img/logo.png</logo><link rel='related' type='application/atom+xml' href='http://gdata.youtube.com/feeds/api/users/b6cOhdeKJhol2vmEDMLfbw?v=2.1'/><link rel='alternate' type='text/html' href='http://www.youtube.com'/><link rel='hub' href='http://pubsubhubbub.appspot.com'/><link rel='http://schemas.google.com/g/2005#feed' type='application/atom+xml' href='http://gdata.youtube.com/feeds/api/users/b6cOhdeKJhol2vmEDMLfbw/subscriptions?v=2.1'/><link rel='http://schemas.google.com/g/2005#batch' type='application/atom+xml' href='http://gdata.youtube.com/feeds/api/users/b6cOhdeKJhol2vmEDMLfbw/subscriptions/batch?v=2.1'/><link rel='self' type='application/atom+xml' href='http://gdata.youtube.com/feeds/api/users/b6cOhdeKJhol2vmEDMLfbw/subscriptions?start-index=1&max-results=50&v=2.1'/><link rel='service' type='application/atomsvc+xml' href='http://gdata.youtube.com/feeds/api/users/b6cOhdeKJhol2vmEDMLfbw/subscriptions?alt=atom-service&v=2.1'/><author><name>null null</name><uri>http://gdata.youtube.com/feeds/api/users/b6cOhdeKJhol2vmEDMLfbw</uri><yt:userId>b6cOhdeKJhol2vmEDMLfbw</yt:userId></author><generator version='2.1' uri='http://gdata.youtube.com'>YouTube data API</generator><openSearch:totalResults>0</openSearch:totalResults><openSearch:startIndex>1</openSearch:startIndex><openSearch:itemsPerPage>50</openSearch:itemsPerPage></feed>'
16:39:05 T:4916 NOTICE: [YouTube-4.4.6] showMessage : '<type 'unicode'> - <type 'unicode'>'
16:39:05 T:4916 NOTICE: [YouTube-4.4.6] list : 'Error'
16:39:05 T:2108 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.youtube/?folder=true&login=true&path=%2froot%2fsubscriptions&user_feed=subscriptions
16:39:05 T:2108 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.youtube/?folder=true&login=true&path=%2froot%2fsubscriptions&user_feed=subscriptions) failed
16:39:05 T:3860 NOTICE: Thread XBPyThread start, auto delete: false
16:39:05 T:3860 NOTICE: -->Python Interpreter Initialized<--
16:39:06 T:3860 NOTICE: Loading cookies from :'C:\\Users\\Riccardo\\AppData\\Roaming\\XBMC\\userdata\\addon_data\\plugin.video.youtube\\yt-cookiejar.txt'
16:39:06 T:3860 NOTICE: YouTube-4.4.6 ARGV: ['plugin://plugin.video.youtube/', '3', '']
16:39:06 T:3860 NOTICE: [StorageClient-2.5.2] '__init__' : 'Setting table to : YouTube'
16:39:06 T:3860 NOTICE: CommonFunctions-2.5.1
16:39:06 T:3860 NOTICE: [YouTube-4.4.6] __init__ : ''
16:39:06 T:3860 NOTICE: [StorageClient-2.5.2] '__init__' : 'Setting table to : Downloader'
16:39:06 T:3860 NOTICE: [YouTube-4.4.6] __init__ : 'Done'
16:39:06 T:1724 NOTICE: Thread Background Loader start, auto delete: false
16:39:10 T:3532 NOTICE: Thread XBPyThread start, auto delete: false
16:39:10 T:3532 NOTICE: -->Python Interpreter Initialized<--
16:39:10 T:3532 NOTICE: Loading cookies from :'C:\\Users\\Riccardo\\AppData\\Roaming\\XBMC\\userdata\\addon_data\\plugin.video.youtube\\yt-cookiejar.txt'
16:39:10 T:3532 NOTICE: YouTube-4.4.6 ARGV: ['plugin://plugin.video.youtube/', '4', '?login=true&path=%2froot%2ffavorites&user_feed=favorites']
16:39:10 T:3532 NOTICE: [StorageClient-2.5.2] '__init__' : 'Setting table to : YouTube'
16:39:10 T:3532 NOTICE: CommonFunctions-2.5.1
16:39:10 T:3532 NOTICE: [YouTube-4.4.6] __init__ : ''
16:39:10 T:3532 NOTICE: [StorageClient-2.5.2] '__init__' : 'Setting table to : Downloader'
16:39:10 T:3532 NOTICE: [YouTube-4.4.6] __init__ : 'Done'
16:39:10 T:3532 NOTICE: [YouTube-4.4.6] getXBMCVersion : '12.300000000000001'
16:39:10 T:3532 NOTICE: [YouTube-4.4.6] _getAuth : ''
16:39:11 T:3532 NOTICE: [YouTube-4.4.6] _fetchPage : 'called for : {'api': 'true', 'link': 'http://gdata.youtube.com/feeds/api/users/default/favorites?start-index=1&max-results=50', 'auth': 'true'}'
16:39:11 T:3532 NOTICE: [YouTube-4.4.6] _fetchPage : 'got auth'
16:39:11 T:3532 NOTICE: [YouTube-4.4.6] _getAuth : ''
16:39:11 T:3532 NOTICE: [YouTube-4.4.6] _fetchPage : 'updated link: http://gdata.youtube.com/feeds/api/users/default/favorites?start-index=1&max-results=50&oauth_token=ya29.1.AADtN_Vlk2KZ4pUWIGxV5d0i-BDsrrAK1kRiwf8llGwczAX58iX3M6tXGt4eyhPCku01UA'
16:39:11 T:3532 NOTICE: [YouTube-4.4.6] _fetchPage : 'got default: http://gdata.youtube.com/feeds/api/users/default/favorites?start-index=1&max-results=50&oauth_token=ya29.1.AADtN_Vlk2KZ4pUWIGxV5d0i-BDsrrAK1kRiwf8llGwczAX58iX3M6tXGt4eyhPCku01UA'
16:39:11 T:3532 NOTICE: [YouTube-4.4.6] _fetchPage : 'got api'
16:39:11 T:3532 NOTICE: [YouTube-4.4.6] _fetchPage : 'connecting to server... http://gdata.youtube.com/feeds/api/users/default/favorites?start-index=1&max-results=50&oauth_token=ya29.1.AADtN_Vlk2KZ4pUWIGxV5d0i-BDsrrAK1kRiwf8llGwczAX58iX3M6tXGt4eyhPCku01UA'
16:39:11 T:3532 NOTICE: [YouTube-4.4.6] _fetchPage : 'done'
16:39:11 T:3532 NOTICE: [YouTube-4.4.6] updateVideoIdStatusInCache : 'videoidcache'
16:39:11 T:3532 NOTICE: [StorageClient-2.5.2] 'setMulti' : 'videoidcache'
16:39:11 T:3532 NOTICE: [StorageClient-2.5.2] '_sock_init' : ''
16:39:11 T:3532 NOTICE: [StorageClient-2.5.2] '_sock_init' : 'Done: ('127.0.0.1', 59994)'
16:39:11 T:3532 NOTICE: [YouTube-4.4.6] getVideoIdStatusFromCache : 'vidstatus-'
16:39:11 T:3532 NOTICE: [StorageClient-2.5.2] 'getMulti' : 'vidstatus-'
16:39:31 T:3532 NOTICE: [StorageClient-2.5.2] '_recv' : 'Except error timeout('timed out',)'
16:39:31 T:3532 NOTICE: [StorageClient-2.5.2] '_recv' : 'over time'
16:39:32 T:3532 NOTICE: [YouTube-4.4.6] showMessage : '<type 'unicode'> - <type 'unicode'>'
16:39:32 T:3532 NOTICE: [YouTube-4.4.6] list : 'Error'
16:39:32 T:2108 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.youtube/?login=true&path=%2froot%2ffavorites&user_feed=favorites
16:39:32 T:2108 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.youtube/?login=true&path=%2froot%2ffavorites&user_feed=favorites) failed
16:39:32 T:4132 NOTICE: Thread XBPyThread start, auto delete: false
16:39:32 T:4132 NOTICE: -->Python Interpreter Initialized<--
16:39:32 T:4132 NOTICE: Loading cookies from :'C:\\Users\\Riccardo\\AppData\\Roaming\\XBMC\\userdata\\addon_data\\plugin.video.youtube\\yt-cookiejar.txt'
16:39:32 T:4132 NOTICE: YouTube-4.4.6 ARGV: ['plugin://plugin.video.youtube/', '5', '']
16:39:32 T:4132 NOTICE: [StorageClient-2.5.2] '__init__' : 'Setting table to : YouTube'
16:39:32 T:4132 NOTICE: CommonFunctions-2.5.1
16:39:32 T:4132 NOTICE: [YouTube-4.4.6] __init__ : ''
16:39:32 T:4132 NOTICE: [StorageClient-2.5.2] '__init__' : 'Setting table to : Downloader'
16:39:32 T:4132 NOTICE: [YouTube-4.4.6] __init__ : 'Done'
16:39:32 T:4796 NOTICE: Thread Background Loader start, auto delete: false
