Full Version: [depricated] old YouTube Plugin - XBMC 13.0 Frodo/Gotham only
I'm having an issue where I cannot install YouTube either. It seems as though the repository mirror isn't complete? I'm a little uncertain, I was getting some help on the OpenELEC chat, and that seems to be what was decided.
EDIT: It might be a repository issue. http://forum.xbmc.org/showthread.php?tid=198324
Same for me. Vevo wont play. On Gotham 13.1 Windows 8.1 64bit
same here add on doesn't work since like 2 days ago... some videos works but ...that's it...
cannot install addon:
i've tried on 3-4 separate installations on different machines. windows/linux. flashes at 0%, ... any tips/tricks to get this to work?
Ok sounds like I'm not the only one. Was running frodo 12.0 for a long time. Youtube worked fine for viewing trailers etc. I installed gotham 13.1 and love it, but can't get youtube addon to install. Same deal as above...once I click install it says downloading flicks at 0% then stops. I have repeated this on many occasions and same thing.
Any advice?
Thanks Jeremy
(2014-06-21, 00:26)nerdstalker Wrote: [ -> ]Everything was working fine then as of 2 days ago VEVO videos won't play, anyone else experiencing this? Latest stable release on most recent stable os x on mac mini.
(2014-06-21, 02:14)msderganc Wrote: [ -> ]
Same for me on OpenElec.
(2014-06-21, 03:02)x-cimo Wrote: [ -> ]Same for me. Vevo worked fine and today it wont play. On Gotham 13.1 Windows 8.1.
(2014-06-21, 03:31)loki05 Wrote: [ -> ]Experiencing the same issue. All other videos work fine except Vevo. halp!! ?
(2014-06-21, 13:24)SomeoneCares Wrote: [ -> ]Same for me. Vevo wont play. On Gotham 13.1 Windows 8.1 64bit
(2014-06-21, 16:01)bakito Wrote: [ -> ]same here add on doesn't work since like 2 days ago... some videos works but ...that's it...
Same for me...
Would be great if someone can provide a quick fix Big Grin
Looks like it should be pretty simple to fix - i tried to change youtubeplayer.py but could not get it working
Maybe someone with more knowledge could have a look at it
I have Matricom G-Box MX2 - XBMC FRODO attached to my Samsung TV. I am using YATSE remote on my Galaxy Note 3 to share the YOUTUBE videos on my XBMC.
Everything was working perfectly couple of days ago but I don't know what happened. I did not made any changes for sure. Now, when I am on my smartphone, playing youtube videos and try to share & use the SEND TO XBMC command via yatse remote. It does NOTHING but before it used to play the video. Please help me with this issue. I posted the DEBUG LOG file from YATSE REMOTE in Yatse forum and they said everything is fine.
I have this humble request to XBMC techs, please help me out in this situation. I am pasting a link below for both the LOG files from XBMC & YATSE.
http://www.sendspace.com/filegroup/YxyRq...3iIyF24SFw
For anyone who's youtube addon stalls at 0% then stops try this (read elsewhere on forum):
Got to: settings: webserver allow control xbmc via http --> set on
Then try installing addon. Hope it works for you as it did me!
Jer
I have noticed in the last few days a lot of videos that I could play before are not able to play any longer.
Had something changed with Youtube to cause this? I am using 4.4.8
can we get an update if this has atleast been acknowledged as a problem? then what is the time frame of a possible fix? or do we just go another route?
Quote:can we get an update if this has atleast been acknowledged as a problem? then what is the time frame of a possible fix? or do we just go another route?
How can anyone tell you if what you are experiencing is the same as what anytone else is experienceing, or if you have some problem unique to you, or what, if you don't post a debug log (wiki).
almost all major labels music video not working (vevo and others)
(2014-06-26, 10:31)Olepir Wrote: [ -> ]almost all major labels music video not working (vevo and others)
Can you access them in your browser (if not welcome to Germany Sleepy)
