Full Version: [depricated] old YouTube Plugin - XBMC 13.0 Frodo/Gotham only
(2015-01-10, 18:19)giaur Wrote: [ -> ]I'm on recent version and I noticed some options missing:
- no movie max resolution settings (720p always), no support for 1080p
- I can't see any option for download movie, is this removed? Any plans to add it again in new version?
Why are you posting here if you are asking about the new version?
(2015-01-10, 21:30)nickr Wrote: [ -> ]
No one can read any more Wink
I changed the Topic of the other thread. I hope this will help.... Rolleyes
YouTube 5.X.X - KODI 14.0 Helix
Sorry, I didn't know that there is other thread for new version
(2015-01-03, 18:22)Icarus3000 Wrote: [ -> ]This addon updated automatically a few days ago, and I can no longer sign in. When I click "Sign In" I just get the busy icon spinning and spinning. I'm on Gotham 13.2. Any suggestions for a fix? Everything worked perfectly up until a few days ago Sad
Anyone? Am I the only one who can no longer log on to google on xbmc?
Exactly which addon are you using?
Hi vevo video don't work at all for me. Any solution for that? I'm on the newest stable version of Kodi..
I use the ordinary youtube addon in Kodi.. Is it any other youtube addon to install for my Mac mini?
Solved my problem..
Frodo user reporting, plugin version 4.4.10. Vevo videos stopped working for me some time last week - signature problems, again. If anyone has the same problem, the following hack worked for me. Open YouTubePlayer.py, go to line 487. It should look like this:
fullAlgoCode += '\n\treturn %s(param)' % mainFunName
Replace this line with the following one:
fullAlgoCode += '\n\treturn %s(param)' % mainFunName.replace('$','_S_')
Worked for me, YMMV.
(2015-02-03, 22:01)Kempniu Wrote: [ -> ]Frodo user reporting, plugin version 4.4.10. Vevo videos stopped working for me some time last week - signature problems, again. If anyone has the same problem, the following hack worked for me. Open YouTubePlayer.py, go to line 487. It should look like this:
This worked for me. Many thanks Kempniu!
Actually this is only a partial fix which has been known for sometime. Some of the signature functions are now referencing sub-functions assigned to a global variable, rather than sub-functions within the signature function. It doesn't look to me like the code is structured correctly to go back through the global variable/functions and their sub-functions to find the correct function to complete the signature function. You can see this type of a function here:
12:00:39 T:9772 NOTICE: [YouTube-4.4.10] _jsToPy : 'function at(a){a=a.split("");$s.Ov(a,3);$s.Vg(a,51);$s.hJ(a,23);$s.Ov(a,2);$s.hJ(a,29);$s.Vg(a,32);$s.hJ(a,44);return a.join("")}'
$s is assigned functions preceding this as:
var $s={Ov:function(a,b){a.splice(0,b)},hJ:function(a,b){var c=a[0];a[0]=a[b%a.length];a[b]=c},Vg:function(a){a.reverse()}}; - though I think you could get away with just searching for hJ:function\(.+?\){.+?}, Ov:function\(.+?\){.+?), etc as function definitions in the cases I looked at.
Someone who has time and understands the code better could come up with a fix, it's just a pain to keep this going. My explanation above is probably not technically correct as I know less than 0 about javascript.
You can find such signatures if you just search for "VEVO" and click on a Taylor Swift or Mark Ronson video (not an endorsement).
Xbmc: 13.2, plugin: 4.4.10.
When I tried to download anything, nothing happens. Here's log (though it shows nothing useful, maybe I've done something wrong?) http://pastebin.com/VAz1F0j1
(2015-02-07, 16:45)myapp Wrote: [ -> ]
i can't play vevo videos from youtube addon 4.4.10 on my XBMC 13.2.
I tried this fix but it doesn't work for me. Something else ?
thanks
classical music for president of Ukraine Petro Poroshenko
Beethoven
I cannot get most videos on youtube to work. This is what the log says:
12:11:09 T:139811921872704   ERROR: CCurlFile::Stat - Failed: HTTP response code said error(22) for https://r3---sn-4p8xoxu-cvhl.googlevideo.com/videoplayback?expire=1426768866&itag=22&upn=Py_6B22a_tE&id=o-AFzC0I7hBcaB2nt08XTnvmpF0ccRPcuI8vAOlBcEjEJ0&fexp=900720,901642,907263,933237,934954,9405643,9406205,9407103,9408101,9408140,942654,948124,948207,951511,951703,952302,952612,952901,955301,957201,959701,961404&pcm2=no&sparams=dur,id,initcwndbps,ip,ipbits,itag,mime,mm,ms,mv,pcm2,pl,ratebypass,requiressl,source,upn,expire&source=youtube&ipbits=0&ip=202.177.224.221&key=yt5&requiressl=yes&sver=3&ms=au&mv=m&pl=22&mt=1426747133&dur=272.462&mime=video/mp4&mm=31&ratebypass=yes&initcwndbps=2697500&signature=|User-Agent=Mozilla%2F5.0+%28Windows+NT+6.2%3B+Win64%3B+x64%3B+rv%3A16.0.1%29+Gecko%2F20121011+Firefox%2F16.0.1
12:11:09 T:139811921872704  NOTICE: DVDPlayer: Opening: https://r3---sn-4p8xoxu-cvhl.googlevideo.com/videoplayback?expire=1426768866&itag=22&upn=Py_6B22a_tE&id=o-AFzC0I7hBcaB2nt08XTnvmpF0ccRPcuI8vAOlBcEjEJ0&fexp=900720,901642,907263,933237,934954,9405643,9406205,9407103,9408101,9408140,942654,948124,948207,951511,951703,952302,952612,952901,955301,957201,959701,961404&pcm2=no&sparams=dur,id,initcwndbps,ip,ipbits,itag,mime,mm,ms,mv,pcm2,pl,ratebypass,requiressl,source,upn,expire&source=youtube&ipbits=0&ip=202.177.224.221&key=yt5&requiressl=yes&sver=3&ms=au&mv=m&pl=22&mt=1426747133&dur=272.462&mime=video/mp4&mm=31&ratebypass=yes&initcwndbps=2697500&signature=|User-Agent=Mozilla%2F5.0+%28Windows+NT+6.2%3B+Win64%3B+x64%3B+rv%3A16.0.1%29+Gecko%2F20121011+Firefox%2F16.0.1
12:11:09 T:139811921872704 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
12:11:09 T:139809825740544  NOTICE: Thread DVDPlayer start, auto delete: false
12:11:10 T:139809825740544  NOTICE: Creating InputStream
12:11:13 T:139809825740544   ERROR: CCurlFile::FillBuffer - Failed: HTTP response code said error(22)
12:11:13 T:139809825740544  NOTICE: CCurlFile::FillBuffer - Reconnect, (re)try 1
12:11:13 T:139809825740544   ERROR: CCurlFile::CReadState::Connect, didn't get any data from stream.
How do I resolve this?
EDIT: It['s mostly VEVO videos like everyone else. No solution for this yet?
