HenrikDK Wrote:Depends wether or not you've linked your youtube account to a google account:
In that case you need to write the entire gmail address remembering the @gmail.com part (or at least that's how i got it working), you could also try unlinking the accounts on youtube if your not comfortable using your google account.
Other than that its hard to tell but a log with the plugins debug mode enabled would be nice
/HenrikDK
Here's my xbmc.log with the YouTube plugin debug mode enabled:
http://pastebin.ca/2030729
I'll try some of the suggestions in TobiasTheCommie's post and see if that helps.
UPDATE: It appears that the problem may be that when I type the number 0 using a real keyboard when entering my password, a blank space appears instead of an asterisk. When my password is complete, there is then a missing asterisk where the 0 character should be.
If I instead type my password using the on-screen keyboard buttons, it works fine and the login is successful.
I also noticed that if I blank the password field and then hold down the 0 key on a real keyboard, I get a rapid rotation of various symbols on the screen! Looks like a bug in either the Youtube plugin or XBMC.
HunterZ Wrote:Here's my xbmc.log with the YouTube plugin debug mode enabled: http://pastebin.ca/2030729
This would be a problem with XBMC, since we don't control the keyboard implementation in either the plugin or xbmc
soufiane Wrote:okay hier is the xbmc.log
I can't really see anything wrong, could you try with a non live version?
Thanks for 2.0 HenrikDK and any others working on this plugin, I'm happy with what this is up to, any more development is just an added bonus ^_^
I really like the new "disco mode" but is there a way to play the full playlist (top 25) easilly? As for now I need to press play after each song.
Thx for a sweet plugin
Lol everytime I consider this plugin to be perfect, I come up with another suggestion. Sorry if it is bugging you.
But I was just wondering if it was at all possible, when downloading a video, to create a .txt file with video info, so that I could sort files in folders include the .txt and still have the info display through the downloads folder.
jaaahaaa Wrote:I really like the new "disco mode" but is there a way to play the full playlist (top 25) easilly? As for now I need to press play after each song.
Like on other folders you can select "Queue folder" from the context menu.
A "Play folder" can't be implemented before XBMC implements it.
Drir Wrote:Lol everytime I consider this plugin to be perfect, I come up with another suggestion. Sorry if it is bugging you.
What kind of info would you want in the txt file?
TobiasTheCommie Wrote:What kind of info would you want in the txt file?
Date added,Title, Description, Owners username, maybe even link address and category, but purely for reference.
Drir Wrote:Date added,Title, Description, Owners username, maybe even link address and category, but purely for reference.
Should be doable. We will investigate.
HenrikDK Wrote:This solutions is hopefully only temporary as it's really just a hack, we have created a trac for this issue some time ago which you can probably find a mention of it earlier in this thread.
This feature only works if your using the confluence skin thats default with xbmc.
Video Thumbnails = only video lists will be presented as thumbnails
Thumbnails Everywhere = all listings will be presented as thumbnails
XBMC default = this is the same as switching the feature off and will allow xbmc to use its default file listing for the plugin.
Btw what is a "full list"? (please post a screenshot)
/Henrik DK
OK I just use the "XBMC Default" setting and now it uses the "List" view which suits me somewhat.
The "Full List" was a view that I saw in the former Youtube plugin where it was just like the "List" but without a preview window, it was only a list occupying the whole screen from left to right. That was nice because you could read almost all of the big titled videos without scrolling.
I used the new feature "find similar" but it gives me a message "no login" which I guess that means that I have to be logged in to use that. Could this work without a login? I don't desire to be logged in to you tube.
Thanks for your great work Henrik.
Nektarios Wrote:I used the new feature "find similar" but it gives me a message "no login" which I guess that means that I have to be logged in to use that. Could this work without a login? I don't desire to be logged in to you tube.
Hmm thats a mistake that feature shouldn't require login, we'll look into it
