HenrikDK Wrote:Did you actually try to play a video in that log? the only thing I can see it doing is trying to do a login with youtube
third times a charm.
http://pastebin.com/SVWr4dpR
heres the problem, i can navigate the menus, the thumbnails load up for the video.....the problem is when i press enter to play the video nothing happens, no loading no nothing.
krish_2k4 Wrote:third times a charm.
This is very wierd,
Basically I can see that you login and list your recommended videos on youtube but after that the only error i can see is an internal XBMC error about the remote control not registering..
21:51:38 T:352 M:433016832 ERROR: CRemoteControl::Connect - failed to connect
21:51:59 T:2164 M:437751808 ERROR: Previous line repeats 3 times.
21:51:59 T:2164 M:437751808 WARNING: Trying to add unsupported control type 3
21:51:59 T:352 M:437743616 WARNING: Previous line repeats 7 times.
21:51:59 T:352 M:437743616 ERROR: CRemoteControl::Connect - failed to connect
21:52:04 T:2164 M:439017472 WARNING: Trying to add unsupported control type 3
21:52:04 T:352 M:427274240 WARNING: Previous line repeats 7 times.
21:52:04 T:352 M:427274240 ERROR: CRemoteControl::Connect - failed to connect
21:52:32 T:2164 M:441217024 ERROR: Previous line repeats 5 times.
21:52:32 T:2164 M:441217024 WARNING: Trying to add unsupported control type 3
21:52:35 T:352 M:441376768 WARNING: Previous line repeats 7 times.
21:52:35 T:352 M:441376768 ERROR: CRemoteControl::Connect - failed to connect
21:52:35 T:2164 M:441376768 WARNING: Trying to add unsupported control type 3
21:52:40 T:352 M:442740736 WARNING: Previous line repeats 15 times.
XBMC never ask the plugin to resolve video playback for the item, so the best guess I can give is that xbmc currently has a bug with plugins on windows 7? Have you tried any other video plugins that work?
yeap just installed the Yahoo Music Video plugin from bluecops registery and that is not working too when i press enter.
however the tvcatchup plugin, icefilms, bbc iplayer and apple trailers plugins are working fine.
what i'll do is update xbmc to the 19th march nightly build and report back.
ok installed the new nightly build (19th march)
i played the tvcatchup plugin and it worked, went to the youtube plugin and it didnt work.
http://pastebin.com/T3XYdfbB
also the apple trailers one does not work now when i press enter, but when i play through the options menu it plays
is it a bug in the windows version? the enter button seems to work for some plugins and not others.
Did something change in the youtube site today?
I am getting an Uncaught error every time I try to play any video file in both youtube 2.0.2 and beta 1.9.6 version of the add-on.
Confirmed on youtube plugin V2.0.2,
Starting XBMC, Platform: Linux (Ubuntu 10.04.1 LTS - XBMCLive Dharma, 2.6.32-26-generic i686). Built on Mar 9 2011 (Git:Unknown)
uname -a
Linux XBMCLive 2.6.32-26-generic #48-Ubuntu SMP Wed Nov 24 09:00:03 UTC 2010 i686 GNU/Linux
full xbmc.log with debugging on:
http://pastebin.com/S3g7bLxR
I know it was working last night so the change was extremely recent.
blm14 Wrote:Confirmed on youtube plugin V2.0.2,
I concur, Yesterday It was working perfectly fine on beta 1.9.6, so the change seems very recent.
was working about 6 hours ago today, now this error. I swear these places deliberately change stuff to bugger up plugins and whatnot... apple do it every other week as well.
I just wanted to confirm that I am also having the same issue (Playback Failed: Uncaught Error) on XBMC 10.1 running on Ubuntu Linux 10.4.02 (Linux 2.6.32-29-generic).
It was working perfectly earlier today, then when went to use it tonight, I can't get any videos to play, whether I'm logged in or not. I even uninstalled and reinstalled the plugin, but no luck.
EDIT: Using version 2.0.2 of the YouTube plugin, in case that matters. Seems like a change in the YouTube API to me, so the plugin probably isn't at fault.
Youtube has switched to handshake 9, along with a few other sites. The rtmp guys are on it, but this one's likely not going to be a quick fix.
TheUni
Hope it will be soon because I'm having the same problem
theuni Wrote:Youtube has switched to handshake 9, along with a few other sites. The rtmp guys are on it, but this one's likely not going to be a quick fix.
TheUni
Thanks for the quick update on the problem!
I realize it's hard to give time estimates for this kind of thing, but what do you consider "not a quick fix"? A week? A month?
salvi Wrote:Did something change in the youtube site today?
While TheUni is correct about the version 9 rtmp handshake this only applies to a small subset of video content.
It seems that the youtube decided to change encoding on their html and that is currently messing with our url extraction code. I've had a fix in our trunk since last night (caught this error while watching up on some lets plays). I wanted to see if this was a temporary problem with youtubes servers but it seems that its a permanent change so I'll push a bugfixing update out later today.
