Full Version: [depricated] old YouTube Plugin - XBMC 13.0 Frodo/Gotham only
HenrikDK Wrote:Under advanced settings "Viewmode in confluence" set it to "XBMC default" that means the plugin will stop setting view mode, since this feature was made only to work with the confluence skin.
Doesnt work :S
All still stretched over a poster format. Could you maybe add a Aeon(Nox) option in the addon?
Rionsic Wrote:Doesnt work :S
Strange seems to works fine here:
Huh
and no we won't add view options for more skins cause that would basically mean we could spend the rest of our time hard-coding support for every "skin" or "skin mod" out there. We've created a trac ticket (see here: http://trac.xbmc.org/ticket/9952) for this issue and noted it on both the plugins homepage and in the changelog. This problem will have to wait until Team XBMC finds time to do something about it..
Any timeframe on the beta that lets us watch 18+ videos? Pretty much all of my subscriptions are 18+ videos.
Rickie Wrote:Any timeframe on the beta that lets us watch 18+ videos? Pretty much all of my subscriptions are 18+ videos.
Setting safe search to off in plugin settings will do the same thing, 18+ videos should work (I've just tested : http://www.youtube.com/watch?v=XDxkSqIaGOs and http://www.youtube.com/watch?v=O-77ElyvRxI) and both work fine in the current plugin, if you're still having problem a debug log with the plugins debug mode enabled will be required..
Hihou
I have the problem that when I download a video from Youtube to my harddrive it has the '-incomplete' tag at the end of the filename when I open the Mydownloads section. I looks like the download is complete, it shows the correct filesize and I can play the file from my harddrive, but XBMC doesn't rename the file.
Has anyone the same problem?
http://pastebin.com/wv9x34sp
Regards
Astaroth Wrote:Hihou
Regards
The video didn't download for some reason:
16:56:02 T:1340 M:1121460224  NOTICE: YouTube-2.0.3 downloadVideo uncaught exception
16:56:02 T:1340 M:1121443840  NOTICE: ERROR: YouTubeCore::downloadVideo (386) - (0, 'Error')
Personally I'm blaming pixies, I just tested the same video myself and it downloaded fine here, try downloading it again Smile
Hi
I tried it with different videos and different download locations, no success.
Looks kinda strange to me.
I'm on XBMC 10.1, Aeon MQ2 skin and Youtube 2.0.3.
Any idea why this is happening?
Thanks for your help!
Astaroth
is the handshaking still a problem?
because I'm getting
WARNING: HandShake: Type mismatch: client sent 6, server answered 9
wasn't sure if that's one of the things you fixed in 2.0.3 or not?
+1 on the handshake error
HenrikDK Wrote:Strange seems to works fine here:
Huh
Strange indeed, Did you use the Aeon Nox version in that pic?
What strange is to me is that the pictures in the first screen for when i have to select if i want to Watch my favorites or subscriptions etc. the pics there arent stretched out...
Rionsic Wrote:Strange indeed, Did you use the Aeon Nox version in that pic?
I just downloaded the version of Aeon Nox (yes i double checked that i am using the Nox version ) thats in the official repo set the plugins view mode to XBMC default. But you are right by default the plugin doesn't look very good in that skin.
tomolac Wrote:is the handshaking still a problem?
because I'm getting
This isn't something that the plugin controls this is a part of XBMC video playback engine as such this will probably be a while:
http://forum.xbmc.org/showpost.php?p=758...tcount=747
So the answer is no not something we can fix in the plugin.. Sad
HenrikDK Wrote:Setting safe search to off in plugin settings will do the same thing, 18+ videos should work (I've just tested : http://www.youtube.com/watch?v=XDxkSqIaGOs and http://www.youtube.com/watch?v=O-77ElyvRxI) and both work fine in the current plugin, if you're still having problem a debug log with the plugins debug mode enabled will be required..
Here's me attempting to play one of the videos, and failing... Safesearch is Off
Debug Log
pike Wrote:Here's me attempting to play one of the videos, and failing... Safesearch is Off
Debug Log
Hmm strange youtube seems to think you're not 18 years old
test linky
if you access this url are you redirected to the video or do you get a warning?
HenrikDK Wrote:Hmm strange youtube seems to think you're not 18 years old
test linky
I see this here
