Full Version: [depricated] old YouTube Plugin - XBMC 13.0 Frodo/Gotham only
exobuzz Wrote:ok good. i was under the impression something wasnt working and it was being blamed (incorrectly) on your librtmp version.
Yeah, i didn't understand the patch correctly. Smile
Ticket 11584 workaround for Arch Linux x86_64 here.
im in uk using youtube plugin when i click on youtube shows i load list with 4od, channel 5, comedy, classic tv etc, but when i try and load one of these sub catorgries i just get a script error, i am using the 2.4 version of librtmp
javum Wrote:Ticket 11584 workaround for Arch Linux x86_64 here.
bladeds Wrote:im in uk using youtube plugin when i click on youtube shows i load list with 4od, channel 5, comedy, classic tv etc, but when i try and load one of these sub catorgries i just get a script error, i am using the 2.4 version of librtmp
Wow, that is one awesome debug log you got for us there, oh wait.. Wink
Quote:19:27:43 T:2100 M:2245480448 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.youtube/?path=/root/explore/shows&category=comedy%3Ffeature%3Dsh_c%26amp%3Bpt%3Dg&scraper=shows&login=true&) failed
19:27:43 T:4076 M:2245369856 NOTICE: -->Python Interpreter Initialized<--
19:27:43 T:4076 M:2245361664 NOTICE: YouTube-2.0.5
19:28:14 T:2100 M:2228936704 WARNING: XFILE::CVideoDatabaseDirectory::GetLabel - Unknown nodetype requested 6
I am getting this error while loading the YouTube TV shows. For rest the You Tube is working fine. I am using XBMC 10.1 on Windows XP SP 3.
I'm using version 2.2.4 on an Apple TV 2.
When I'm using my playlists I'd like to automatically play each video after the other within that playlist.
How does that work?
Thanks,
Kevin
I've updated librtmp and am running the 2.0.5 YouTube plugin and I have 4OD as YouTube subscriptions.
But, when I try to play a video from the YouTube plugin, I get an error:
ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.youtube/?path=/root/subscriptions&action=play_video&videoid=SgcMMvFjgTo]
Full debug log at http://pastebin.com/eLBTb6hW
David
I love the youtube plugin but it recently stopped working. On the Youtube Disco Top 25 I get all item named 'unknown title' and there is no thumbnails. When I try to play they do not play either.
I've tried to re-install the plugin with no luck...
Anyone with the same issue ?
I am running xbmc 10 with plugin 2.0.5 on windows 7 64 bit
Below is an extract of the log. Full log is here http://pastebin.com/fDt9r7RQ
22:36:17 T:1764 M:1522442240   DEBUG: XBPyThread::Process - Entering source directory C:\Users\admin\AppData\Roaming\XBMC\addons\plugin.video.youtube
22:36:17 T:1764 M:1522425856  NOTICE: YouTube-2.0.5
22:36:17 T:1280 M:1521364992   DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult- plugin returned successfully
22:36:17 T:1764 M:1521364992    INFO: Scriptresult: Success
22:36:17 T:1764 M:1521364992    INFO: Python script stopped
22:36:17 T:1764 M:1521364992   DEBUG: Thread 1764 terminating
22:36:17 T:3628 M:1521356800 WARNING: XFILE::CVideoDatabaseDirectory::GetLabel - Unknown nodetype requested 6
22:36:17 T:3620 M:1521356800   DEBUG: thread start, auto delete: 0
22:36:17 T:3628 M:1520824320   DEBUG: python thread 3 destructed
22:36:17 T:3620 M:1520910336   DEBUG: Thread 3620 terminating
22:36:20 T:3628 M:1522253824   DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.youtube/?path=/root/explore/disco&login=false&store=disco_searches&)
22:36:20 T:3628 M:1522253824   DEBUG:   ParentPath = [plugin://plugin.video.youtube/?path=/root/explore&login=false&]
22:36:20 T:1280 M:1522253824   DEBUG: XFILE::CPluginDirectory::StartScript - calling plugin YouTube('plugin://plugin.video.youtube/','0','?path=/root/explore/disco&login=false&store=disco_searches&')
22:36:20 T:1280 M:1522253824    INFO: initializing python engine.
22:36:20 T:1280 M:1522253824   DEBUG: new python thread created. id=4
22:36:20 T:1280 M:1522253824   DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - waiting on the YouTube plugin...
22:36:20 T:3256 M:1522253824   DEBUG: thread start, auto delete: 0
22:36:20 T:3256 M:1522253824   DEBUG: Python thread: start processing
22:36:20 T:3256 M:1522098176   DEBUG:   msg: 'import site' failed; use -v for traceback
22:36:20 T:3256 M:1522098176  NOTICE: -->Python Interpreter Initialized<--
22:36:20 T:3256 M:1522098176   DEBUG: XBPyThread::Process - The source file to load is C:\Users\admin\AppData\Roaming\XBMC\addons\plugin.video.youtube\default.py
22:36:20 T:3256 M:1522098176   DEBUG: XBPyThread::Process - Setting the Python path to C:\Users\admin\AppData\Roaming\XBMC\addons\plugin.video.youtube;C:\Users\admin\AppData\Roaming\XBMC\addons\script.module.beautifulsoup\lib;C:\Program Files (x86)\XBMC\addons\script.module.pil\lib;C:\Program Files (x86)\XBMC\addons\script.module.pysqlite\lib;special://xbmc/system/python/DLLs;special://xbmc/system/python/Lib;special://xbmcbin/system/python/python24.zip;special://xbmc/system/python\DLLs;special://xbmc/system/python\lib;special://xbmc/system/python\lib\plat-win;special://xbmc/system/python\lib\lib-tk;C:\Program Files (x86)\XBMC
22:36:20 T:3256 M:1522098176   DEBUG: XBPyThread::Process - Entering source directory C:\Users\admin\AppData\Roaming\XBMC\addons\plugin.video.youtube
22:36:20 T:3256 M:1522081792  NOTICE: YouTube-2.0.5
22:36:20 T:1280 M:1520680960   DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult- plugin returned successfully
22:36:20 T:3256 M:1520680960    INFO: Scriptresult: Success
22:36:20 T:3256 M:1520680960    INFO: Python script stopped
22:36:20 T:3256 M:1520680960   DEBUG: Thread 3256 terminating
22:36:21 T:3628 M:1520672768 WARNING: XFILE::CVideoDatabaseDirectory::GetLabel - Unknown nodetype requested 6
22:36:21 T:3172 M:1520603136   DEBUG: thread start, auto delete: 0
22:36:21 T:3628 M:1520504832   DEBUG: python thread 4 destructed
22:36:21 T:3172 M:1520549888   DEBUG: Thread 3172 terminating
22:36:24 T:3628 M:1522061312   DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.youtube/?path=/root/explore/disco/top_25&scraper=disco_top_25&login=false&)
22:36:24 T:3628 M:1522061312   DEBUG:   ParentPath = [plugin://plugin.video.youtube/?path=/root/explore/disco&login=false&store=disco_searches&]
22:36:24 T:3296 M:1522061312   DEBUG: XFILE::CPluginDirectory::StartScript - calling plugin YouTube('plugin://plugin.video.youtube/','0','?path=/root/explore/disco/top_25&scraper=disco_top_25&login=false&')
22:36:24 T:3296 M:1522061312    INFO: initializing python engine.
22:36:24 T:3296 M:1522061312   DEBUG: new python thread created. id=5
22:36:24 T:3296 M:1522061312   DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - waiting on the YouTube plugin...
22:36:24 T:2684 M:1522061312   DEBUG: thread start, auto delete: 0
22:36:24 T:2684 M:1522061312   DEBUG: Python thread: start processing
22:36:24 T:2684 M:1521983488   DEBUG:   msg: 'import site' failed; use -v for traceback
22:36:24 T:2684 M:1521983488  NOTICE: -->Python Interpreter Initialized<--
22:36:24 T:2684 M:1521983488   DEBUG: XBPyThread::Process - The source file to load is C:\Users\admin\AppData\Roaming\XBMC\addons\plugin.video.youtube\default.py
22:36:24 T:2684 M:1521983488   DEBUG: XBPyThread::Process - Setting the Python path to C:\Users\admin\AppData\Roaming\XBMC\addons\plugin.video.youtube;C:\Users\admin\AppData\Roaming\XBMC\addons\script.module.beautifulsoup\lib;C:\Program Files (x86)\XBMC\addons\script.module.pil\lib;C:\Program Files (x86)\XBMC\addons\script.module.pysqlite\lib;special://xbmc/system/python/DLLs;special://xbmc/system/python/Lib;special://xbmcbin/system/python/python24.zip;special://xbmc/system/python\DLLs;special://xbmc/system/python\lib;special://xbmc/system/python\lib\plat-win;special://xbmc/system/python\lib\lib-tk;C:\Program Files (x86)\XBMC
22:36:24 T:2684 M:1521983488   DEBUG: XBPyThread::Process - Entering source directory C:\Users\admin\AppData\Roaming\XBMC\addons\plugin.video.youtube
22:36:24 T:2684 M:1521967104  NOTICE: YouTube-2.0.5
22:36:25 T:3628 M:1522016256   DEBUG: ------ Window Init (DialogBusy.xml) ------
22:36:25 T:3628 M:1522016256    INFO: Loading skin file: DialogBusy.xml
22:36:25 T:2684 M:1521598464    INFO: Scriptresult: Success
22:36:25 T:2684 M:1521598464    INFO: Python script stopped
22:36:25 T:2684 M:1521598464   DEBUG: Thread 2684 terminating
22:36:25 T:3296 M:1521643520   DEBUG:  XFILE::CPluginDirectory::WaitOnScriptResult - plugin exited prematurely - terminating
22:36:25 T:3628 M:1521635328   ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.youtube/?path=/root/explore/disco/top_25&scraper=disco_top_25&login=false&
22:36:25 T:3628 M:1521635328   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.youtube/?path=/root/explore/disco/top_25&scraper=disco_top_25&login=false&) failed
22:36:25 T:3628 M:1521635328   DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.youtube/?path=/root/explore/disco&login=false&store=disco_searches&)
22:36:25 T:3628 M:1521635328   DEBUG:   ParentPath = [plugin://plugin.video.youtube/?path=/root/explore&login=false&]
22:36:25 T:1280 M:1521635328   DEBUG: XFILE::CPluginDirectory::StartScript - calling plugin YouTube('plugin://plugin.video.youtube/','0','?path=/root/explore/disco&login=false&store=disco_searches&')
22:36:25 T:1280 M:1521635328    INFO: initializing python engine.
22:36:25 T:1280 M:1521635328   DEBUG: new python thread created. id=6
22:36:25 T:1280 M:1521635328   DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult - waiting on the YouTube plugin...
22:36:25 T:3316 M:1521635328   DEBUG: thread start, auto delete: 0
22:36:25 T:3316 M:1521635328   DEBUG: Python thread: start processing
22:36:25 T:3316 M:1521557504   DEBUG:   msg: 'import site' failed; use -v for traceback
22:36:25 T:3316 M:1521557504  NOTICE: -->Python Interpreter Initialized<--
22:36:25 T:3316 M:1521557504   DEBUG: XBPyThread::Process - The source file to load is C:\Users\admin\AppData\Roaming\XBMC\addons\plugin.video.youtube\default.py
22:36:25 T:3316 M:1521557504   DEBUG: XBPyThread::Process - Setting the Python path to C:\Users\admin\AppData\Roaming\XBMC\addons\plugin.video.youtube;C:\Users\admin\AppData\Roaming\XBMC\addons\script.module.beautifulsoup\lib;C:\Program Files (x86)\XBMC\addons\script.module.pil\lib;C:\Program Files (x86)\XBMC\addons\script.module.pysqlite\lib;special://xbmc/system/python/DLLs;special://xbmc/system/python/Lib;special://xbmcbin/system/python/python24.zip;special://xbmc/system/python\DLLs;special://xbmc/system/python\lib;special://xbmc/system/python\lib\plat-win;special://xbmc/system/python\lib\lib-tk;C:\Program Files (x86)\XBMC
22:36:25 T:3316 M:1521557504   DEBUG: XBPyThread::Process - Entering source directory C:\Users\admin\AppData\Roaming\XBMC\addons\plugin.video.youtube
22:36:25 T:3316 M:1521545216  NOTICE: YouTube-2.0.5
22:36:25 T:1280 M:1520492544   DEBUG: XFILE::CPluginDirectory::WaitOnScriptResult- plugin returned successfully
22:36:25 T:3316 M:1520492544    INFO: Scriptresult: Success
22:36:25 T:3316 M:1520492544    INFO: Python script stopped
22:36:25 T:3316 M:1520492544   DEBUG: Thread 3316 terminating
22:36:25 T:3628 M:1520484352 WARNING: XFILE::CVideoDatabaseDirectory::GetLabel - Unknown nodetype requested 6
cmonpellier Wrote:Hi,
Yeah it seems that they removed the top 50 and switched it to the youtube weekly top 100 list. And I'm guessing that list works differently that the old top 50.
dlake02 Wrote:I've updated librtmp and am running the 2.0.5 YouTube plugin and I have 4OD as YouTube subscriptions.
David
4oD content still isn't working.
Sad
Beta Relase Announcement
We're currently testing what will become version 3 of the plugin which we have dubbed version 2.5 beta. This release includes a complete reworking of the plugins code and adds a lot of new features
In order to participate in the testing of the new beta you just need to upgrade to the latest nightly and XBMC will automatically fetch it from the nightly repo. We're looking for input on features we've might have missed, and issues like if there's a folder that needs play all support that we've missed, so please feel free to write in this thread about such issues Smile.
Tis exciting because a huge chunk of my viewing is now done through this wonderful addon, anyhoo the first problem I had was with My Subscriptions, great I thought sorted by a-z a nice improvement only to find a blank list after selecting more results, was unsuccessful in trying to unsubscribe, a couple of videos I tried didn't play (HD problem ?) and I was bit by a a problem which occurs I think with overlapping dialogues which kills XBMC.
I'm using the PVR ppa from https://launchpad.net/~lars-opdenkamp/+archive/xbmc-pvr which isn't the latest and greatest normally a little behind.
http://paste.ubuntu.com/655864/
If you need more info (maybe turn on debugging in the addon?) let me know.
-_Edit_-
The videos that didn't play work fine when max video quality is set to ask, if set at 1080p and the video to be played is a lower resolution playback fails
gott_sei_dank Wrote:Tis exciting because a huge chunk of my viewing is now done through this wonderful addon, anyhoo the first problem I had was with My Subscriptions, great I thought sorted by a-z a nice improvement only to find a blank list after selecting more results, was unsuccessful in trying to unsubscribe, a couple of videos I tried didn't play (HD problem ?) and I was bit by a a problem which occurs I think with overlapping dialogues which kills XBMC.
-_Edit_-
Hi thanks for the feedback, the subscriptions pagination not working thing is confirmed, for the video playback, youtube recently started enabling vp8 streams for most users and these fail on xbmc unless one is using a very new nightly (at most one week old), i would also like a debug log with the plugins debug mode enabled showing a video failing. The behaviour you describe with the gui.lock and the errors your log shows are very strange i've never had the gui.lock error before, could you reconfirm with a newer nightly?
It looks like a newer version of the PVR ppa should be available soon, hopefully it is new enough, when it is available I'll try it out.
https://github.com/opdenkamp/xbmc/tree/pvr-ppa
http://pastebin.com/Fihizqiu
The above log wasn't made in the logical manner but I think it shows the video playback problems, I think the order I tried was this, set the max video quality to ask, tried a known 1080p video that works, tried the two videos that had failed at their maximum of 720p (they worked), set the max video quality to 1080p (there was an error here) and then tried the videos again.
gott_sei_dank Wrote:It looks like a newer version of the PVR ppa should be available soon, hopefully it is new enough, when it is available I'll try it out.
Yup, seems you're getting a VP8 file on the last playback:
22:43:05 T:140302394300160 M:1566978048  NOTICE: YouTube2.5.0 _fetchPage making request
22:43:06 T:140302802974688 M:1564692480  NOTICE: DVDPlayer: Opening: http://v13.lscache6.c.youtube.com/videoplayback?sparams=id%2Cexpire%2Cip%2Cipbits%2Citag%2Cratebypass&fexp=908606%2C912202%2C910004%2C907302%2C911303&itag=45&ip=86.0.0.0&signature=577FC6FB80F32588A54C8AEFF6178590CC641636.D6C2113CD4771D8EDA30EA6374F153BC6DB1B3D1&sver=3&ratebypass=yes&expire=1312171200&key=yt1&ipbits=8&id=5b24fc2e7937d75e | Mozilla/5.0 (Windows; U; Windows NT 6.1; en-GB; rv:1.9.2.8) Gecko/20100722 Firefox/3.6.8
22:43:06 T:140302802974688 M:1564692480 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
22:43:06 T:140302174021376 M:1564692480  NOTICE: Creating InputStream
22:43:06 T:140302174021376 M:1564692480  NOTICE: Creating Demuxer
22:43:06 T:140302174021376 M:1564692480 WARNING: Seek - attempt to seek pass read data (seek to 37963619. max: 7200. reset read pointer. (37963619)
22:43:06 T:140302174021376 M:1564692480 WARNING: Seek - seek to 37963619 failed.
22:43:06 T:140302174021376 M:1564741632  NOTICE: Opening video stream: 0 source: 256
22:43:06 T:140302174021376 M:1564741632  NOTICE: Creating video codec with codec id: 146
22:43:06 T:140302174021376 M:1564741632  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: [b]On2 VP8[/b]
22:43:06 T:140302174021376 M:1564631040  NOTICE: Creating video thread
22:43:06 T:140302174021376 M:1564631040  NOTICE: Opening audio stream: 1 source: 256
22:43:06 T:140302174021376 M:1564631040  NOTICE: Finding audio codec for: 86021
22:43:06 T:140302394300160 M:1564631040  NOTICE: running thread: video_thread
22:43:06 T:140302174021376 M:1564631040  NOTICE: Creating audio thread
22:43:06 T:140302119302912 M:1564631040  NOTICE: running thread: CDVDPlayerAudio::Process()
22:43:06 T:140302174021376 M:1564631040  NOTICE: CDVDPlayer::OnExit()
22:43:06 T:140302174021376 M:1564631040  NOTICE: [b]DVDPlayer: eof, waiting for queues to empty[/b]
22:43:06 T:140302174021376 M:1564631040  NOTICE: DVDPlayer: closing audio stream
