gott_sei_dank Wrote:Tis exciting because a huge chunk of my viewing is now done through this wonderful addon, anyhoo the first problem I had was with My Subscriptions, great I thought sorted by a-z a nice improvement only to find a blank list after selecting more results, was unsuccessful in trying to unsubscribe, a couple of videos I tried didn't play (HD problem ?) and I was bit by a a problem which occurs I think with overlapping dialogues which kills XBMC.
I'm using the PVR ppa from https://launchpad.net/~lars-opdenkamp/+archive/xbmc-pvr which isn't the latest and greatest normally a little behind.
http://paste.ubuntu.com/655864/
Beyond the the playback issues and the gui.lock problems i think are cause by outdated nightly, i've been chewing my way trough the rest of the problems, pagination has been restored to subscriptions and it's now possible to unsubscribe again (youtube apparently has different opinions on whether a public api needs to be stable). I'll push out an update at the end of the week once i've gotten around to merging with version 2.6
The new version of the PVR build did fix the VP8 problems, though they seem slower to start with a little pause at the beginning probably a part of Youtube's master plan, hopefully the unstable api is also the cause of not being able to add favourites which is the only other problem I found. Keep up the good work
If anyone feels up to running some 4oD tests send me a pm.
This will require you to run unstable xbmc(eden-pre), unstable librtmp(2.4) and unstable youtube plugin code(i'll provide it)
If you feel comfortable with all that, send me a pm.
ETA: Thanks to the help of gott_sei_dank it appears that 4oD is now working in our really really buggy pre-beta code. So it is coming.
Tobias I've sent you a pm, well I have tried not sure if they are getting through (sorry if they are
) but I'm not getting any acknowledgement that I've sent them.
edit
there is an option to save a copy of a pm, still a more obvious acknowledgement that a pm has been sent would be nice for simpletons like me
Got it three times. is aok
I've send you a pm. Crossed fingers here...
So I have been reminded
that with the pre-eden build searches are no longer are saved.
Running XBMC on Ubuntu 10.10... YT plugin was working fine last night, today it's not (same XBMC process running)... get the uncaught error when trying to launch a video from search.
Tried a reboot, no dice. Other online plugins working fine so it's not a network issue.
Log only shows:
Quote:18:51:24 T:2940484464 M:2831179776 NOTICE: -->Python Interpreter Initialized<--
18:51:24 T:2940484464 M:2831179776 NOTICE: YouTube-2.0.5
18:51:26 T:3079313264 M:2830446592 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.youtube/?path=/root/search&action=play_video&videoid=fMvSryOVKz0]
Did they change their API/interface?
It was running this morning actually and a few hours ago I noticed it die out.
I'm running XBMC PRE-11.0 GIT:201 10715-78a51df
XBMC plugin version 2.5.0
Im building the latest GIT pull now and I'll post back to let you know if that fixes it.
First part of excerpt from my xbmc.log
T:4491152 M:1713074176 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.youtube/?path=/root/explore/categories&scraper=categories&login=false&folder=true&)
16:24:25 T:4491152 M:1713074176 DEBUG: ParentPath = [plugin://plugin.video.youtube/?path=/root/explore&login=false&]
16:24:25 T:3021994864 M:1713074176 DEBUG: StartScript - calling plugin YouTube('plugin://plugin.video.youtube/','0','?path=/root/explore/categories&scraper=categories&login=false&folder=true&')
16:24:25 T:3021994864 M:1713074176 INFO: initializing python engine.
16:24:25 T:3021994864 M:1713074176 DEBUG: new python thread created. id=39
16:24:25 T:3021994864 M:1713074176 DEBUG: WaitOnScriptResult - waiting on the YouTube plugin...
16:24:25 T:3042950000 M:1713074176 DEBUG: Thread XBPyThread start, auto delete: 0
16:24:25 T:3042950000 M:1713074176 DEBUG: Python thread: start processing
16:24:25 T:3042950000 M:1713074176 NOTICE: -->Python Interpreter Initialized<--
16:24:25 T:3042950000 M:1713074176 DEBUG: Process - The source file to load is /home/poquette/.xbmc/addons/plugin.video.youtube/default.py
16:24:25 T:3042950000 M:1713074176 DEBUG: Process - Setting the Python path to /home/poquette/.xbmc/addons/plugin.video.youtube:/home/poquette/.xbmc/addons/script.module.simplejson/lib:/home/poquette/.xbmc/addons/script.module.beautifulsoup/lib:/usr/local/share/xbmc/addons/script.module.pil/lib:/usr/local/share/xbmc/addons/script.module.pysqlite/lib:/usr/lib/python2.7/site-packages/tvdb_api-1.5-py2.7.egg:/usr/lib/python2.7/site-packages/FlexGet-1.0-py2.7.egg:/usr/lib/python2.7/site-packages/progressbar-2.3_dev-py2.7.egg:/usr/lib/python2.7/site-packages/pynzb-0.1.0-py2.7.egg:/usr/lib/python2.7/site-packages/PyRSS2Gen-1.0.0-py2.7.egg:/usr/lib/python2.7/site-packages/html5lib-0.90-py2.7.egg:/usr/lib/python2.7/site-packages/PyYAML-3.09-py2.7-linux-i686.egg:/usr/lib/python2.7/site-packages/SQLAlchemy-0.6.5-py2.7.egg:/usr/lib/python2.7/site-packages/transmissionrpc-0.7-py2.7.egg:/usr/lib/python2.7/site-packages/tvnamer-2.0-py2.7.egg:/usr/lib/python2.7/site-packages/mpich2:/usr/lib/python27.zip:/usr/lib/python2.7:/usr/lib/python2.7/plat-linux2:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/lib/python2.7/site-packages:/usr/lib/python2.7/site-packages/gst-0.10:/usr/lib/python2.7/site-packages/gtk-2.0:/usr/lib/python2.7/site-packages/setuptools-0.6c11-py2.7.egg-info:/usr/lib/python2.7/site-packages/webkit-1.0:
16:24:25 T:3042950000 M:1713074176 DEBUG: Process - Entering source directory /home/poquette/.xbmc/addons/plugin.video.youtube
16:24:25 T:3042950000 M:1713074176 DEBUG: Instantiating addon using automatically obtained id of "plugin.video.youtube" dependent on version 2.0 of the xbmc.python api
16:24:25 T:3042950000 M:1713074176 NOTICE: YouTube2.5.0
16:24:26 T:4491152 M:1712947200 DEBUG: ------ Window Init (DialogBusy.xml) ------
16:24:26 T:4491152 M:1712947200 DEBUG: Alloc resources: 0.01ms (0.00 ms skin load)
16:24:26 T:4491152 M:1712947200 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/libexif-i486-linux.so)
16:24:26 T:4491152 M:1712947200 DEBUG: Unloading: libexif-i486-linux.so
16:24:26 T:3021994864 M:1712562176 DEBUG: WaitOnScriptResult- plugin returned successfully
16:24:26 T:3042950000 M:1712562176 INFO: Scriptresult: Success
16:24:26 T:3042950000 M:1712562176 INFO: Python script stopped
16:24:26 T:3042950000 M:1712562176 DEBUG: Thread Python Thread 3042950000 terminating
16:24:26 T:3032480624 M:1712562176 DEBUG: Thread Background Loader start, auto delete: 0
16:24:26 T:4491152 M:1712562176 DEBUG: waiting for python thread 39 to stop
16:24:26 T:4491152 M:1712562176 DEBUG: python thread 39 destructed
16:24:26 T:3032480624 M:1712562176 DEBUG: Thread Background Loader 3032480624 terminating
16:24:26 T:4491152 M:1712562176 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
16:24:27 T:4491152 M:1712562176 DEBUG: LIRC: Update - NEW at 914047:000000037ff07bdd 00 OK mceusb (OK)
16:24:27 T:4491152 M:1712562176 DEBUG: OnKey: 11 (0b) pressed, action is Select
16:24:27 T:4491152 M:1712562176 DEBUG: Clearing cached fileitems [plugin://plugin.video.youtube/?path=/root/explore/categories&category=%3Fc%3D2&scraper=categories&]
16:24:27 T:4491152 M:1712562176 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.youtube/?path=/root/explore/categories&category=%3Fc%3D2&scraper=categories&)
16:24:27 T:4491152 M:1712562176 DEBUG: ParentPath = [plugin://plugin.video.youtube/?path=/root/explore/categories&scraper=categories&login=false&folder=true&]
16:24:27 T:31058800 M:1712562176 DEBUG: StartScript - calling plugin YouTube('plugin://plugin.video.youtube/','0','?path=/root/explore/categories&category=%3Fc%3D2&scraper=categories&')
16:24:27 T:31058800 M:1712562176 INFO: initializing python engine.
16:24:27 T:31058800 M:1712562176 DEBUG: new python thread created. id=40
16:24:27 T:31058800 M:1712562176 DEBUG: WaitOnScriptResult - waiting on the YouTube plugin...
16:24:27 T:3042950000 M:1712562176 DEBUG: Thread XBPyThread start, auto delete: 0
16:24:27 T:3042950000 M:1712562176 DEBUG: Python thread: start processing
16:24:27 T:3042950000 M:1712562176 NOTICE: -->Python Interpreter Initialized<--
16:24:27 T:3042950000 M:1712562176 DEBUG: Process - The source file to load is /home/poquette/.xbmc/addons/plugin.video.youtube/default.py
16:24:27 T:3042950000 M:1712562176 DEBUG: Process - Setting the Python path to /home/poquette/.xbmc/addons/plugin.video.youtube:/home/poquette/.xbmc/addons/script.module.simplejson/lib:/home/poquette/.xbmc/addons/script.module.beautifulsoup/lib:/usr/local/share/xbmc/addons/script.module.pil/lib:/usr/local/share/xbmc/addons/script.module.pysqlite/lib:/usr/lib/python2.7/site-packages/tvdb_api-1.5-py2.7.egg:/usr/lib/python2.7/site-packages/FlexGet-1.0-py2.7.egg:/usr/lib/python2.7/site-packages/progressbar-2.3_dev-py2.7.egg:/usr/lib/python2.7/site-packages/pynzb-0.1.0-py2.7.egg:/usr/lib/python2.7/site-packages/PyRSS2Gen-1.0.0-py2.7.egg:/usr/lib/python2.7/site-packages/html5lib-0.90-py2.7.egg:/usr/lib/python2.7/site-packages/PyYAML-3.09-py2.7-linux-i686.egg:/usr/lib/python2.7/site-packages/SQLAlchemy-0.6.5-py2.7.egg:/usr/lib/python2.7/site-packages/transmissionrpc-0.7-py2.7.egg:/usr/lib/python2.7/site-packages/tvnamer-2.0-py2.7.egg:/usr/lib/python2.7/site-packages/mpich2:/usr/lib/python27.zip:/usr/lib/python2.7:/usr/lib/python2.7/plat-linux2:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/lib/python2.7/site-packages:/usr/lib/python2.7/site-packages/gst-0.10:/usr/lib/python2.7/site-packages/gtk-2.0:/usr/lib/python2.7/site-packages/setuptools-0.6c11-py2.7.egg-info:/usr/lib/python2.7/site-packages/webkit-1.0:
16:24:27 T:3042950000 M:1712562176 DEBUG: Process - Entering source directory /home/poquette/.xbmc/addons/plugin.video.youtube
16:24:27 T:3042950000 M:1712562176 DEBUG: Instantiating addon using automatically obtained id of "plugin.video.youtube" dependent on version 2.0 of the xbmc.python api
16:24:27 T:3042950000 M:1712562176 NOTICE: YouTube2.5.0
16:24:27 T:4491152 M:1712504832 DEBUG: ------ Window Init (DialogBusy.xml) ------
16:24:27 T:4491152 M:1712504832 DEBUG: Alloc resources: 0.01ms (0.00 ms skin load)
16:24:28 T:31058800 M:1711497216 INFO: Loading skin file: DialogProgress.xml
16:24:28 T:31058800 M:1711497216 DEBUG: Load DialogProgress.xml: 2.51ms
16:24:28 T:31058800 M:1711497216 DEBUG: DialogProgress::StartModal called
16:24:28 T:31058800 M:1711497216 DEBUG: ------ Window Init (DialogProgress.xml) ------
16:24:28 T:31058800 M:1711497216 DEBUG: Alloc resources: 0.25ms (0.00 ms skin load)
16:24:29 T:31058800 M:1709084672 DEBUG: WaitOnScriptResult- plugin returned successfully
16:24:29 T:3042950000 M:1709084672 INFO: Scriptresult: Success
16:24:29 T:4491152 M:1709084672 DEBUG: Saving fileitems [plugin://plugin.video.youtube/?path=/root/explore/categories&category=%3Fc%3D2&scraper=categories&]
16:24:29 T:4491152 M:1709084672 DEBUG: -- items: 26, sort method: 0, ascending: false
16:24:29 T:3042950000 M:1709084672 INFO: Python script stopped
16:24:29 T:3042950000 M:1709084672 DEBUG: Thread Python Thread 3042950000 terminating
16:24:29 T:3032480624 M:1709084672 DEBUG: Thread Background Loader start, auto delete: 0
16:24:29 T:4491152 M:1708068864 DEBUG: waiting for python thread 40 to stop
16:24:29 T:4491152 M:1708068864 DEBUG: python thread 40 destructed
16:24:29 T:3032480624 M:1707388928 DEBUG: Thread Background Loader 3032480624 terminating
16:24:29 T:4491152 M:1707388928 DEBUG: ------ Window Deinit (DialogProgress.xml) ------
16:24:29 T:4491152 M:1707294720 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
16:24:30 T:4491152 M:1707479040 DEBUG: LIRC: Update - NEW at 917447:000000037ff07bdd 00 OK mceusb (OK)
16:24:30 T:4491152 M:1707479040 DEBUG: OnKey: 11 (0b) pressed, action is Select
16:24:30 T:4491152 M:1707479040 DEBUG: StartScript - calling plugin YouTube('plugin://plugin.video.youtube/','0','?path=/root/explore/categories&action=play_video&videoid=JHmesVibyXc')
Final part of xbmc.log excerpt
16:24:30 T:4491152 M:1707479040 INFO: initializing python engine.
16:24:30 T:4491152 M:1707479040 DEBUG: new python thread created. id=41
16:24:30 T:4491152 M:1707479040 DEBUG: WaitOnScriptResult - waiting on the YouTube plugin...
16:24:30 T:3042950000 M:1707479040 DEBUG: Thread XBPyThread start, auto delete: 0
16:24:30 T:3042950000 M:1707479040 DEBUG: Python thread: start processing
16:24:30 T:3042950000 M:1707479040 NOTICE: -->Python Interpreter Initialized<--
16:24:30 T:3042950000 M:1707479040 DEBUG: Process - The source file to load is /home/poquette/.xbmc/addons/plugin.video.youtube/default.py
16:24:30 T:3042950000 M:1707479040 DEBUG: Process - Setting the Python path to /home/poquette/.xbmc/addons/plugin.video.youtube:/home/poquette/.xbmc/addons/script.module.simplejson/lib:/home/poquette/.xbmc/addons/script.module.beautifulsoup/lib:/usr/local/share/xbmc/addons/script.module.pil/lib:/usr/local/share/xbmc/addons/script.module.pysqlite/lib:/usr/lib/python2.7/site-packages/tvdb_api-1.5-py2.7.egg:/usr/lib/python2.7/site-packages/FlexGet-1.0-py2.7.egg:/usr/lib/python2.7/site-packages/progressbar-2.3_dev-py2.7.egg:/usr/lib/python2.7/site-packages/pynzb-0.1.0-py2.7.egg:/usr/lib/python2.7/site-packages/PyRSS2Gen-1.0.0-py2.7.egg:/usr/lib/python2.7/site-packages/html5lib-0.90-py2.7.egg:/usr/lib/python2.7/site-packages/PyYAML-3.09-py2.7-linux-i686.egg:/usr/lib/python2.7/site-packages/SQLAlchemy-0.6.5-py2.7.egg:/usr/lib/python2.7/site-packages/transmissionrpc-0.7-py2.7.egg:/usr/lib/python2.7/site-packages/tvnamer-2.0-py2.7.egg:/usr/lib/python2.7/site-packages/mpich2:/usr/lib/python27.zip:/usr/lib/python2.7:/usr/lib/python2.7/plat-linux2:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/lib/python2.7/site-packages:/usr/lib/python2.7/site-packages/gst-0.10:/usr/lib/python2.7/site-packages/gtk-2.0:/usr/lib/python2.7/site-packages/setuptools-0.6c11-py2.7.egg-info:/usr/lib/python2.7/site-packages/webkit-1.0:
16:24:30 T:3042950000 M:1707479040 DEBUG: Process - Entering source directory /home/poquette/.xbmc/addons/plugin.video.youtube
16:24:30 T:3042950000 M:1707479040 DEBUG: Instantiating addon using automatically obtained id of "plugin.video.youtube" dependent on version 2.0 of the xbmc.python api
16:24:30 T:3042950000 M:1707479040 NOTICE: YouTube2.5.0
16:24:30 T:3042950000 M:1707606016 NOTICE: YouTube2.5.0 getVideoObject trying embedded
16:24:30 T:3042950000 M:1707606016 NOTICE: YouTube2.5.0 getVideoObject trying website
16:24:31 T:3042950000 M:1707352064 NOTICE: YouTube2.5.0 couldn't locate fmt_url_map or fmt_stream_map, no videos on page?
16:24:31 T:3042950000 M:1707352064 INFO: Scriptresult: Success
16:24:31 T:3042950000 M:1707352064 INFO: Python script stopped
16:24:31 T:3042950000 M:1707352064 DEBUG: Thread Python Thread 3042950000 terminating
16:24:31 T:4491152 M:1707352064 DEBUG: WaitOnScriptResult - plugin exited prematurely - terminating
16:24:31 T:4491152 M:1707352064 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.youtube/?path=/root/explore/categories&action=play_video&videoid=JHmesVibyXc]
16:24:31 T:4491152 M:1707352064 DEBUG: Playlist Player: no more playable items... aborting playback
16:24:31 T:3032480624 M:1707352064 DEBUG: Thread Background Loader start, auto delete: 0
16:24:31 T:4491152 M:1707352064 DEBUG: waiting for python thread 41 to stop
16:24:31 T:4491152 M:1707352064 DEBUG: python thread 41 destructed
16:24:31 T:4491152 M:1707352064 DEBUG: ------ Window Init (DialogKaiToast.xml) ------
If there is anything that might help, just let me know
UPDATE: Plugin remains broken with GIT:20110803-e852572
^please use pastebin services in future
Noticed people on a ROKU forum also commenting YT is not playing for them anymore... this is obviously some kind of move by YT to block players that bypass any adverts.
Just looked at the plugin code and I can confirm that youtube changed their html content which caused the regex in _extractVariables to fail ...
