seems Im having trouble starting youtube.. I start it up and crashes.. dont know if this is the skin or addons or xbmc itself. Running this on my atv2 (Built on Aug 15 2011 (Git:20110815-82f48cd)
see logs
logs
http://paste2.org/p/1618954
old log
http://paste2.org/p/1618956
RGB_Gamer Wrote:Is there any way to add a feature in the Youtube add on so that after doing a search, the results are alphabetized? I often use Youtube for watching episodes, and many episodes are split up into multiple parts. It kinda sucks when I do a search and multi part episodes are listed on different pages. Would be nice if after doing a search on Youtube, the results are alphabetized so that the multi part episodes are listed together.
Perhaps I need to ask the author of the Youtube add on about this? If so, how would I reach them?
I've looked at the api and youtube doesn't seem to expose this, we do allow the user to sort a view within xbmc so perhaps that could help you?
PantsOnFire Wrote:When looking at a list of subscribed channels, is it possible to make the list alphabetical order? It would make things smarter, easier and in line with the rest of xbmc listview file listings.
This is already done in the beta
rflores2323 Wrote:seems Im having trouble starting youtube.. I start it up and crashes.. dont know if this is the skin or addons or xbmc itself. Running this on my atv2 (Built on Aug 15 2011 (Git:20110815-82f48cd)
see logs
logs
old log
Hi
I've looked at those log and I can't really see anything going wrong (theres no backtrace):
11:05:41 T:148135936 NOTICE: YouTube2.6.2
11:05:41 T:129708032 DEBUG: WaitOnScriptResult- plugin returned successfully
11:05:41 T:148135936 INFO: Scriptresult: Success
Sadly you didn't enable the plugins debug mode so i cant really see anymore than that, but i suspect the error to be in the apple tv build you're using.
HenrikDK Wrote:I've looked at the api and youtube doesn't seem to expose this, we do allow the user to sort a view within xbmc so perhaps that could help you?
true you change the view/sort after performing a search, but there is no option in the youtube add on for saving the view/sort type. so in effect, you have to set the desired view/sort type after every search you make. If it were up to me, i would set the sort to always be big list and the view to be by name and set it so it always displays search results this way every time.
Hello,
I am in troble getting the plugin to work. I updated the chipset and video drivers, the flash version... i dont know what else to do
he log is here:
http://pastebin.com/yQjn1CQY
Thank you very much!
dreq Wrote:Hello,
I am in troble getting the plugin to work. I updated the chipset and video drivers, the flash version... i dont know what else to do .
he log is here: http://pastebin.com/yQjn1CQY
Hmm seems you're python installation is missing the json lib, we've already added a simplejson dependency to the plugin so im not really sure why your installation is failing. Could you try upgradeing to a later nightly build of xbmc (yours is from march 8 which is pretty old)?
0k, i installed 2 night6ly builds 30.08 and 31.08 and now i caN search for videos but when i click them the xbmc stops responding and i have to kill it. i tried to login but i keep getting login failed. can you recomend a stable night build?
http://pastebin.com/2KG81gEe
thank you very much!
Sounds fun at the minute I can't get any of the plugins to work, this includes YouTube, TVCatchup, Apple Trailers Lite, Yahoo Movie Trailers and Game Trailers just comes up with Script error every time I try and load them.
**** EDIT: I have managed to 'fix it' myself. Actually i updated the XBMC build to the nightly from 31st August 2011 and now 4OD content plays correctly. Who'd a thunk it?
I have a problem with the plugin version 2.6.2 on XBMC for the Apple TV 2.
Basically, although the plugin seed 4OD content it will not play it.
I have taken a quick look at the xbmc.log and it seems this section details the error:
15:49:32 T:121696256 M:119574528 DEBUG: ------ Window Deinit (DialogProgress.xml) ------
15:49:32 T:147783680 M:119939072 WARNING: HandShake: Type mismatch: client sent 6, server answered 9
15:49:33 T:147783680 M:119930880 WARNING: HandShake: Server not genuine Adobe!
15:49:33 T:147783680 M:119930880 ERROR: RTMP_Connect1, handshake failed.
15:49:33 T:147783680 M:119930880 ERROR: CDVDPlayer::OpenInputStream - error opening [rtmpe://cp59009.edgefcs.net/youtube?auth=daEdobcaQdQcPbgd6bdaUcraad_bzaqdEbd-boy4_3-eS-LyFCFnpd&aifp=YT2008121701&slist=c2/id/fa51787587f7169f/itag/34&stream=c2/id/fa51787587f7169f/itag/34&itag=34 swfurl=http://s.ytimg.com/yt/swfbin/watch_as3-vflUXLhsZ.swf swfvfy=1 playpath=c2/id/fa51787587f7169f/itag/34?ptchn=4oDDocumentaries&ptk=channel4]
15:49:33 T:147783680 M:119926784 NOTICE: CDVDPlayer::OnExit()
15:49:33 T:147783680 M:119926784 NOTICE: CDVDPlayer::OnExit() deleting input stream
Seemingly wants a genuine Adobe flash player?
I include the full xbmc.log
here (Pastebin).
Andy
edit: i uninstalled xbmc, installed a fresh build and everything works! thx for your suport.
dreq Wrote:0k, i installed 2 night6ly builds 30.08 and 31.08 and now i caN search for videos but when i click them the xbmc stops responding and i have to kill it. i tried to login but i keep getting login failed. can you recomend a stable night build?
so i installed later a night build from 4.09 and everything worked just fine! only the volume up button wasnt working, so i installed 3.09 and then the youtube woujldnt work again. i went back to 4.09 and is not working either. any ideas?
hey guys,
quick question when clicking "queue folder"
i have a playlist set to sort by "rating"<------ closest thing i can get to shuffle songs
but when i click queue folder it skips songs in alphabetic order
any ideas
thanks
