Ok thanks.
But, no update are available
TobiasTheCommie Wrote:Update the youtube plugin to version 2.1.2(Should be in the repo).
Ok sorry, my Youtube plugin is up to date (2.1.2).
But i have the same problem !
TobiasTheCommie Wrote:Something to do with your build of xbmc.
URLError : <urlopen error unknown url type: https
It appears that ssl is not supported.
Thanks. I updated to a nightly build and now it runs fine. Looks real good compared to whatever youtube plugin I was using in the past.
guiilty Wrote:Ok sorry, my Youtube plugin is up to date (2.1.2).
If you have a problem with 2.1.2 i need new debug log for 2.1.2
TobiasTheCommie Wrote:I need a debug log
http://code.google.com/p/youtubexbmc/wik...llDebugLog
vijayk416 Wrote:I am getting an error accessing a playlist after I have made changes to it directly in youtube. I set up the playlist initially without an issues, but afterwards if I delete items from it and then try to access the playlist I get this message:
playlist_root
No recent activity
The screen stays at the playlist menu and I am unable to view items in the playlist.
http://pastebin.com/nSR1RthA
Looks like the error is around line 790.
Sorry for the delay, here's a new debug log:
http://pastebin.com/A2ZQKs71
Hope I did it right this time, let me know if you need another one.
vijayk416 Wrote:Sorry for the delay, here's a new debug log:
Hm, i will investigate.
Are you sure the playlist isn't just empty?
wizardpc Wrote:http://pastebin.com/XTfCrH4x
Your debug log seems to be missing a lot, i don't know why. It looks like it might be the same problem as vijayk416, but i'm not sure.
ok so I keep getting a login failed using 2.6.3 on my atv2 (nightly build Oct 28)
I set up 2 step verification on my google account. and then I generated my password for youtube but still cant get it to log in.
Is this plugin still having problems with logging in to youtube? I really miss youtube especially at parties etc.. since I have to get the old ipod out instead (yuk).
Hi!
Same situation here. Latest XBMC, 2step authentication in GOOGLE, created an application password but no luck entering in in YouTube plugin
error log:
Quote:02:46:11 T:140599588263680 NOTICE: -->Python Interpreter Initialized<--
02:46:11 T:140599588263680 NOTICE: YouTube2.6.3
02:46:11 T:140600010622784 ERROR: GetDirectory - Error getting plugin://plugin.video.youtube/?path=/root/login&action=settings&
02:46:11 T:140600010622784 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.youtube/?path=/root/login&action=settings&) failed
02:46:11 T:140599544203008 NOTICE: -->Python Interpreter Initialized<--
02:46:12 T:140599544203008 NOTICE: YouTube2.6.3
02:46:20 T:140599544203008 NOTICE: -->Python Interpreter Initialized<--
02:46:20 T:140599544203008 NOTICE: YouTube2.6.3
TobiasTheCommie Wrote:Hm, i will investigate.
Definitely not empty. Not sure what is going on but this is not reproducible with other playlists I create so I guess you can disregard this for now. Sorry and thanks.
rflores2323 Wrote:ok so I keep getting a login failed using 2.6.3 on my atv2 (nightly build Oct 28)
Sorry, login is broken in 2.6.3.
You can either:
1) Downgrade to 2.1.2
2) Apply the fix that was posted a few pages back -
http://forum.xbmc.org/showpost.php?p=917...count=1426
3) Wait for the 2.7.0 beta
c0ba Wrote:Hi!
error log:
Same as above.
Application specific password should NOT be used for the plugin.
vijayk416 Wrote:Definitely not empty. Not sure what is going on but this is not reproducible with other playlists I create so I guess you can disregard this for now. Sorry and thanks.
Any weird settings on this playlist that isn't on your other playlists?
When is 2.7 suppose to be out.
