Full Version: Trouble installing .pkg
Hi all,
I was trying to install one .pkg with usb audio driver with this command:
sudo installer -pkg MAudioAudiophileUSB.pkg/ -target /
and the terminal returns:
dyld: Symbol not found: __ZTIN3KJS11InterpreterE
  Referenced from: /System/Library/PrivateFrameworks/JavaScriptGlue.framework/Versions/A/JavaScriptGlue
  Expected in: /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
Trace/BPT trap
After that I tried
DYLD_FRAMEWORK_PATH='/System/Library/Frameworks/OSXFrames/' installer -pkg MAudioAudiophileUSB.pkg/ -target /
but the pkg requires authentication... is there any workaround?
Thanks a lot in advance!!
juanlu Wrote:Hi all,
Trace/BPT trap
After that I tried
maybe open up the pkg, see what it's doing and do it manually.
