21:42:08 T:3078645616 M:228192256 NOTICE: load settings...
21:42:08 T:3078645616 M:228192256 ERROR: Unable to load libcrystalhd.so.3, reason: libcrystalhd.so.3: Kann die Shared-Object-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden
21:42:08 T:3078645616 M:228192256 NOTICE: special://profile/ is mapped to: special://masterprofile/
21:42:08 T:3078645616 M:228192256 NOTICE: loading special://masterprofile/guisettings.xml
21:42:08 T:3078645616 M:227811328 NOTICE: Getting hardware information now...
21:42:08 T:3078645616 M:227811328 NOTICE: Checking resolution 12
21:42:08 T:3078645616 M:227811328 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
21:42:08 T:3078645616 M:227811328 NOTICE: Loaded playercorefactory configuration
21:42:08 T:3078645616 M:227811328 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
21:42:08 T:3078645616 M:227811328 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
21:42:08 T:3078645616 M:227811328 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
21:42:08 T:3078645616 M:227811328 NOTICE: Default DVD Player: dvdplayer
21:42:08 T:3078645616 M:227811328 NOTICE: Default Video Player: dvdplayer
21:42:08 T:3078645616 M:227811328 NOTICE: Default Audio Player: paplayer
21:42:08 T:3078645616 M:227811328 NOTICE: Loading media sources from special://masterprofile/sources.xml
21:42:08 T:3078645616 M:225394688 NOTICE: Using visual 0x100
21:42:09 T:3078645616 M:221978624 NOTICE: GL_VENDOR = DRI R300 Project
21:42:09 T:3078645616 M:221978624 NOTICE: GL_RENDERER = Mesa DRI R300 (R350 4E48) 20090101 x86/MMX+/3DNow!+/SSE2 TCL DRI2
21:42:09 T:3078645616 M:221978624 NOTICE: GL_VERSION = 1.5 Mesa 7.9-devel
21:42:09 T:3078645616 M:221978624 NOTICE: GL_SHADING_LANGUAGE_VERSION = NULL
21:42:09 T:3078645616 M:221978624 NOTICE: GL_EXTENSIONS = GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_imaging GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_point_parameters GL_ARB_provoking_vertex GL_ARB_shadow GL_ARB_shadow_ambient GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_MESAX_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_rectangle GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_window_pos GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_logic_op GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_convolution GL_EXT_copy_texture GL_EXT_draw_range_elements GL_EXT_framebuffer_blit GL_EXT_framebuffer_object GL_EXT_fog_coord GL_EXT_gpu_program_parameters GL_EXT_histogram GL_EXT_multi_draw_arrays GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_polygon_offset GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_subtexture GL_EXT_texture GL_EXT_texture3D GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_add GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_APPLE_packed_pixels GL_ATI_blend_equation_separate GL_ATI_texture_env_combine3 GL_ATI_texture_mirror_once GL_ATI_separate_stencil GL_IBM_multimode_draw_arrays GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_INGR_blend_func_separate GL_MESA_pack_invert GL_MESA_ycbcr_texture GL_MESA_window_pos GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_rectangle GL_NV_vertex_program GL_OES_read_format GL_SGI_color_matrix GL_SGI_color_table GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_SUN_multi_draw_arrays
21:42:09 T:3078645616 M:222232576 ERROR: GLX: Same window as before, refreshing context
21:42:09 T:3078645616 M:223866880 NOTICE: start dvd mediatype detection
21:42:09 T:3078645616 M:223866880 NOTICE: initializing playlistplayer
21:42:09 T:3078645616 M:223866880 NOTICE: DONE initializing playlistplayer
21:42:09 T:3078645616 M:220114944 NOTICE: UpdateLibraries - Starting video library startup scan
21:42:09 T:3078645616 M:220090368 NOTICE: UpdateLibraries - Starting music library startup scan
21:42:09 T:3051223920 M:220090368 NOTICE: VideoInfoScanner: Starting scan ..
21:42:09 T:3078645616 M:219709440 NOTICE: initialize done
21:42:09 T:3078645616 M:219709440 NOTICE: Running the application...
21:42:09 T:3078645616 M:219693056 NOTICE: ES: Starting event server
21:42:09 T:3078645616 M:219693056 NOTICE: DS: Starting dbus server
21:42:09 T:3024083824 M:219660288 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
21:42:09 T:3024083824 M:219660288 NOTICE: UDP: Listening on port 9777
21:42:09 T:3078645616 M:220119040 NOTICE: starting zeroconf publishing
21:42:09 T:3015691120 M:220246016 NOTICE: DS: Starting DBUS server in Run Application aka thread
21:42:09 T:3040869232 M:220119040 NOTICE: My Music: Scanning for music info using worker thread, operation took 00:00
21:42:23 T:2884787056 M:223756288 NOTICE: -->Python Interpreter Initialized<--
21:42:24 T:2884787056 M:220827648 ERROR: TranslateResolution invalid resolution specified for 0
21:42:24 T:2884787056 M:220827648 NOTICE: PMPDClient
21:42:24 T:2884787056 M:220827648 NOTICE: Connecting to MPD 192.168.2.26:6600
21:42:24 T:2884787056 M:220811264 NOTICE: Connected
21:42:24 T:2884787056 M:220684288 NOTICE: Handling changes - ['mixer', 'playlist', 'player', 'options']
21:42:24 T:2815183728 M:221413376 NOTICE: Starting time poller thread
21:42:24 T:2884787056 M:221396992 NOTICE: Traceback (most recent call last):
21:42:24 T:2884787056 M:221396992 NOTICE: File "/home/guenter/.xbmc/addons/lzoubek-xbmc-plugin-mpdc-c673dcb/resources/lib/gui.py", line 204, in _connect
21:42:24 T:2884787056 M:221396992 NOTICE: self._handle_changes(self.client,['mixer','playlist','player','options'])
21:42:24 T:2884787056 M:221396992 NOTICE: File "/home/guenter/.xbmc/addons/lzoubek-xbmc-plugin-mpdc-c673dcb/resources/lib/gui.py", line 555, in _handle_changes
21:42:24 T:2884787056 M:221396992 NOTICE: self.controls.update_player_controls(self.getControl(PLAYER_CONTROL),state)
21:42:24 T:2884787056 M:221396992 NOTICE: File "/home/guenter/.xbmc/addons/lzoubek-xbmc-plugin-mpdc-c673dcb/resources/lib/playercontrols.py", line 103, in update_player_controls
21:42:24 T:2884787056 M:221396992 NOTICE: img = self._get_image(name+status[name])
21:42:24 T:2884787056 M:221396992 NOTICE: KeyError: 'single'
21:42:26 T:2884787056 M:221167616 NOTICE: disconnecting
21:42:26 T:2884787056 M:221167616 NOTICE: waiting for poller thread
21:42:26 T:2884787056 M:221167616 NOTICE: done
21:42:26 T:2884787056 M:221167616 NOTICE: disconnecting time poller
21:42:26 T:2884787056 M:221184000 NOTICE: waiting for time poller thread
21:42:26 T:2884787056 M:221184000 NOTICE: done
21:42:26 T:2884787056 M:221184000 NOTICE: client disconnected
21:42:30 T:3078645616 M:221675520 NOTICE: Storing total System Uptime
21:42:30 T:3078645616 M:221675520 NOTICE: Saving settings
21:42:30 T:3078645616 M:221708288 NOTICE: stop all
21:42:32 T:3051223920 M:221720576 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:23
21:42:32 T:3078645616 M:221847552 NOTICE: ES: Stopping event server
21:42:32 T:3078645616 M:221847552 NOTICE: stopping zeroconf publishing
21:42:33 T:3015691120 M:221847552 NOTICE: DS: DBUS server stopped
21:42:33 T:3024083824 M:221863936 NOTICE: ES: UDP Event server stopped
21:42:33 T:3078645616 M:221876224 NOTICE: stop dvd detect media
21:42:33 T:3078645616 M:221888512 NOTICE: stop sap announcement listener
21:42:33 T:3078645616 M:221888512 NOTICE: clean cached files!
21:42:33 T:3078645616 M:221888512 NOTICE: unload skin
21:42:34 T:3078645616 M:221917184 ERROR: ClearBlock: Trying to clear non existent block /home/guenter/.xbmc/addons/lzoubek-xbmc-plugin-mpdc-c673dcb
21:42:34 T:3078645616 M:221941760 ERROR: Previous line repeats 1 times.
21:42:34 T:3078645616 M:221941760 WARNING: Cleanup: Having to cleanup texture OSDPrevTrackNF.png
21:42:34 T:3078645616 M:221941760 WARNING: Cleanup: Having to cleanup texture OSDPlayNF.png
21:42:34 T:3078645616 M:221941760 WARNING: Cleanup: Having to cleanup texture OSDStopNF.png
21:42:34 T:3078645616 M:221941760 WARNING: Cleanup: Having to cleanup texture OSDNextTrackNF.png
21:42:34 T:3078645616 M:221941760 WARNING: Cleanup: Having to cleanup texture OSDRandomOffNF.png
21:42:34 T:3078645616 M:221941760 WARNING: Cleanup: Having to cleanup texture OSDRepeatNF.png
21:42:34 T:3078645616 M:221941760 WARNING: Cleanup: Having to cleanup texture SingleOffNF.png
21:42:34 T:3078645616 M:221941760 WARNING: Cleanup: Having to cleanup texture ConsumeOffNF.png
21:42:34 T:3078645616 M:222576640 NOTICE: stop python
21:42:34 T:3078645616 M:224075776 NOTICE: stopped
21:42:34 T:3078645616 M:224075776 NOTICE: destroy
21:42:34 T:3078645616 M:224075776 NOTICE: unload sections
