Full Version: proble with radiobutton
hi all
i am writing a liitle script and i am having problem with setSelected()
i am building a list of radiobutton with windowsxml
thats is how i build the radiobutton:
for($i=0,$k=101;$i<sizeof($elem);$i++)
                   $content=($content.'<control type="grouplist" id="900">
                    <visible>Container(9000).Hasfocus('.$i.')</visible>
                                <posx>290</posx>
                                    <posy>60</posy>
                                  <width>750</width>
                                  <height>530</height>
                                  <itemgap>-1</itemgap>
                                  <pagecontrol>-</pagecontrol>
                                  <onleft>9000</onleft>
                                  <onright>9000</onright>
                                  <onup>9001</onup>
                                  <ondown>9001</ondown>');
                                 for($j=0;$j<sizeof($elem[$i]);$j++)
                                 $content=($content.'<control type="radiobutton" id='.$k.'>
                                        <width>750</width>
                                        <height>40</height>
                                        <font>font13</font>
                                        <label>'.$elem[$i][$j]['name'].'</label>
                                        <textcolor>grey2</textcolor>
                                        <focusedcolor>white</focusedcolor>
                                        <texturefocus>MenuItemFO.png</texturefocus>
                                        <texturenofocus>MenuItemNF.png</texturenofocus>
                                        <selected>'.$elem[$i][$j]['status'].'</selected>
                                      </control>');
                                      $k++;
                      $content=($content.'</control>');
as you can see i build the xml dynamic with php
here the part on the script when i want to change the state of the radiobutton
class openRoomWindow(xbmcgui.WindowXML):
  def onClick(self, id):
    self.getControl( id ).setSelected(False)
def openroom(id):
  req=urllib2.Request('http://localhost/xbmc/GetElements.php?roomid='+id)
  response=urllib2.urlopen(req)
  ui = openRoomWindow('filename.xml', os.getcwd())
  ui.doModal()
but when i click on the radiobutton he dosent chagne state!!!!
anyone know what is the problem??
Thank you
ofer
i think i found what cause the problem but i dont know how to solve it
when i remove from the xml file the tag <selected></selected>
i can change the button state
but i dont want to remove this tag becuse i need the button load with my defualt state
any idle?
thank you
ofer
Perhaps because the internal control changes state, so you're just changing it back?
No it is not the case i try to change the same button to False and True no matter what i try to button doesnt change
any more idle
Thank you
Ah - I hadn't read that you have <selected> defined. In that case it will always be on (or off - depending on what you specify).
If you wish to specify a state initially, I suggest using onInit to setup the state.
Thank you very much
this is what i am trying to do now
