Full Version: Setting main 'home' page options
I'm not quite getting my head around how to alter settings on the menu's etc. I'm afraid coming from MC7 to XBMC i've got a fair bit to learn.
Basically what i want to get is a main menu with:
Movies (this will take me straight to a library)
TV Series (this will take me straight to a library)
Kids (this will take me straight to a library)
Music (this will take me straight to a library)
Sport (this will take me straight to a library)
Video Options (this would be the normal video menu so i can have access to adding files / sources)
Settings (normal settings menu)
Should I be able to configure these via the Settings menu while XBMX is running or do i need to learn / rob n hack code from others to edit the skins themselfs??
So far it seems like a great system but since its for all the family to use i want it to be as easy going and almost locked down as i can.
Closest you'll come is this mod
Cheers, I'll give it a go after work tonight.
Is it worth me creating all the library's i need before adding the mod??
