Full Version: Which version should I use?
Hello
I have an older Dell Dimension desktop I want to set up as a HTPC for my family. It has delegated ram for video processing. I have checked the required video card driver version for the current version of XBMC to play videos properly (as of now I get white screens) and it is well below it.
I created my own xml documents to run the video with vlc or mplayer classic but it causes XBMC to lock up or crash 75% of the time. When the video does play it is usually very choppy. The program itself seems a bit much for the computer to handle.
So I was wondering if there is an older version that is less intensive that I could run instead?
Thanks for your help.
Computer:
Dimension 4200
1 gig sd ram
celeron 1.9ghz
I think Dharma fixes the white screen problem. Try one of the recent Dharma betas from http://mirrors.xbmc.org/nightlies/win32/
JR
