Full Version: Cant find or update XBMC Add-ons
Hi, have had this problem a long time but havent been a problem til now,
i just innstalled latest xbmc pvr via henningpingel ppa/updated the old one
svn30316S, when i go to settings - addons all i find is a folder with enabled add-ons.
How do i get new ones?, or most important the pvr plugin needed?
tried deleting Addons.db in the userdata folder with no luck,
or do i enable pvr support another place?
Edit:
Startuplog xbmc http://pastebin.com/9AbxVfdM
Got this working, it was starting the old svn version not the newly installed from ppa, a make unistall did the trick.
