Full Version: The videolibrary and changed info
Hi!
Im trying to understand how XBMC videolibrary is working, for several reasons have i used Ember Media Manager to scrape all my movies and XBMC indexing the .nfo files like a charm. But if i make changes in those files or if i change fanart/poster it dosnt always update the information other than if i remove the movie from the library and rescan it. Isnt there a way for XBMC to rescan the changed information automagically?
Info > Refresh Information.
Hitcher Wrote:Info > Refresh Information.
Ok you managed to make me look stupid here Big Grin
but...thats on the specific movie, lets say i change information on 10-15 movies. As it is now ive autoscraped 1300 movies, and i promise you its a great deal of changes i want to make, but i dont do them on one evening ...
Thanks guys for your fantastic help and fast replies
/ilBrutto
Your have to refresh all the ones you make changes to if there are loads to do then I'm afraid the only other way is to rebuild your library from scratch unless the changes are to fanart only then you can get away with deleting the fanart in the cache and xbmc will re add them
