2010-08-29, 12:40
I'm a new use so forgive me if this has been answered before (I did a quick search but didn't see any posts with the issue I'm having)
I had been using Ember Media Manager to scrape my movies. I've scraped about 200 odd of them but when I add the folder with the movies into xbmc they don't seem to be getting added to the library.
I have added the folder containing the movies to xbmc, set the content of the folder to movies, I'm not sure what else I need to do?
All my movies are stored in the following way
movies
etc
The only way I can get the movies to add to the library is to right click on them and select update information and as you can imagine I really don't fancy doing that for hundreds of movies.
Am I missing some vital step somewhere?
movies
MacGruber (2010)
[INDENT]MacGruber.avi
[/INDENT][INDENT]MacGruber.jpg
[/INDENT][INDENT]MacGruber.nfo
[/INDENT][INDENT]MacGruber.tbn
[/INDENT][INDENT]MacGruber-fanart.jpg
[/INDENT]Avatar (2009)
[INDENT]Avatar.avi
[/INDENT][INDENT]Avatar.jpg
[/INDENT][INDENT]Avatar.nfo
[/INDENT][INDENT]Avatar.tbn
[/INDENT][INDENT]Avatar-fanart.jpg
[/INDENT]etc
