Full Version: Plays wrong song when select via xbmc remote for android?
Hi, I have some problems when I using the XBMC library to select a song in one of my albums through the Android remote control.
When I select a song the howl album is added to the play list, and a song is being played equals to the position I pressed where I found the song in the library, and it's not taking the conditions of the ordering of the song (ascending/descending...) A bit frustrating, it is working when I use the file browser to select the songs, but I like to search the library.
Have any had similar problem and know how to fix it?, As i know i should be running the latest software for XBMC (Windows) and XBMC remote (Android)
I have the same problem with xbmc for iphone....I don't know what to do....
Problem SOLVED!! I have the shuffle play set up on xbmc.
