Full Version: IRK-200 reciever
Hey,
I'm wondering if it's possible to use the included IR-reciever that comes with the IRK-200 package with XBMC? Well, I'm probably just asking if the reciever works with windows - if it does it shouldn't be a problem to get it to work with XBMC.
Has anyone tried it?
http://www.popcornhour.com/onlinestore/i...ccessories
If it's a Media Center remote in disguise http://wiki.xbmc.org/index.php?title=Usi..._with_XBMC might help. Otherwise you're looking at using Eventghost or something similar.
JR
jhsrennie Wrote:If it's a Media Center remote in disguise http://wiki.xbmc.org/index.php?title=Usi..._with_XBMC might help. Otherwise you're looking at using Eventghost or something similar.
JR
Thanks for your reply!
I'm actually going to use my Harmony One, it's only the reciever I want. I'm not sure if there's any drivers for the reciever for Windows (7), as it's built for Popcorn Hour.
As long as Windows recognizes it, I won't have a problem configuring it.
