I am running XBMC version 33300 on AppleTV with a CrystalHD card installed.
I have installed the drivers but when I go to XBMC there is no option to select CrystalHD in the render options.
What is the best way to diagnose the problem?
Dave
gsi095 Wrote:Hi,
Dave
look below the render setting, it's been moved to it's own setting. if you don't see it there, dmesg, xbmc.log, etc.
it wasnt in 33300 so reran smart installer and updated CrystalHD driver, updated to 33324 and still not there.
Davilla, how do I do the xbmc.log? I havent done this before
Dave
gsi095 Wrote:Davilla, how do I do the xbmc.log? I havent done this before
Dave
check out my signature below
"In Settings > System > Debugging there is a setting Enable debug logging." appears in "%APPDATA%\XBMC\xbmc.log"
