2010-08-31, 11:56
I don't see a Live sticky this time so I will post my test results in this thread.
Please join in.
So far I can only find one issue on asrock ion 330 - grub2 is still hanging for 2minutes
Now we only need a launcher to get ff up and running and I am ready to upgrade!
Working
Standard installation - no issues
USB auto mounting - working
USB auto mounting after gnome-core installed - still working!
MS MCE remote working out of box
VDPAU & killa sample plays fine without any change of setup. (it is struggling a bit to start up)
DVD seem to play fine (and eject works)
suspend works but resume on remote does not work.
The few issues I have seen is boot related and I see the same in the two dharma live threads from today.
Edit: Have now tested on the asrock using an USB.
Issues(?):
1) Grub2 still slow on Asrock IOS 330 (confirmed on my asrock)
2) Some error messages fly by while booting. Less errors now, Can only see someting about 1024x etc (resolutions that does not exists)
Fix:http://forum.xbmc.org/showpost.php?p=595261&postcount=6
3) Exit xbmc does not bring me back to cli. Hangs in xorg somewhere (grey and X)
EDIT: This seem to be display related. It is working fine on the asrock
EDIT: Probably also related to grub resolution.
4) Is it not possible exit to grub menu while booting?
Edit: I do get a grub menu now when I have old OS on fixed disk...not sure if this is an real issue or not.
Edit2: Again, probably related to grub resolution. If so, not very nice since you may want to enter safe mode to fix it....
5) When I add a partition in fstab it used to show up in the highest level in browse for source, now you have to go via root. I guess more a feature than an issue?
6) Resume from suspend does not work out of box (same in 9.11 but worked in 9.04)
Please join in.
Working
Issues(?):
