Full Version: XBMC mouse cursor tends to return to the center point
I self-compiled the XBMC from svn in ubuntu 9.04. When it gets run, the mouse cursor always returns to the center of the screen whenever you are trying to move your mouse. It returns after about a second that you move. It's so annoying since I'm having a hard time using mouse to navigate. Anyone has the same problem or know how to fix it? My platform is Nvidia ION. Thanks in advance. Wink
I have already solved it. I added the "fit to screen" to advancedsettings.xml and the problem was gone. Cheers!
