I installed the new Dharma beta LiveCD last night and the resulting XBMC install seems to have trouble consistently getting data from TheTVDB.com.
Has anyone else encountered these issues? It fails to look up a number of TV shows and will often fail to download thumbs and fanart as well. It gives me a "unable to connect to remote server" error.
Any help would be greatly appreciated.
Yep, I am having a very very very very very slow time scraping my library. 99% of my files are pre-scraped already, but the ones that aren't are taking 5mins each to scrape.
I'm using XBMCFeaks latest CD, everything else works spot on so can only assume TVDB is having troubles tonight.
Check your debug log. I believe thetvdb.com was having issues over the last 24 hours or so.
jmarshall Wrote:Check your debug log. I believe thetvdb.com was having issues over the last 24 hours or so.
+1
The site was up and down all morning for me.
We've been having some issues with what looks to be a DDOS. Workarounds are in place and scraping should be working again, however the issues are ongoing so there may be more interruptions of service.
theTVDB.com is up, but I'm still having the same problem.
XBMC does not get any info about House series.
Fragmant from xbmc.log:
12:19:47 T:2601012080 M:1405440000 DEBUG: VideoInfoScanner: No NFO file found. Using title search for '/mnt/media/filmy/HouseMD/House.S06E21.Help.Me.HDTV.XviD-FQM.[VTV].avi'
12:19:47 T:2601012080 M:1405440000 DEBUG: SECTION:LoadDLL(libcurl-gnutls.so.4)
12:19:47 T:2601012080 M:1405440000 DEBUG: Loading: libcurl-gnutls.so.4
12:19:47 T:2601012080 M:1405440000 DEBUG: InternalFindMovie: Searching for 'house s06e21 help me' using The TVDB scraper (path: '/usr/share/xbmc/addons/metadata.tvdb.com', content: 'tvshows', version: '1.0.6')
12:19:47 T:2601012080 M:1405440000 DEBUG: scraper: CreateSearchUrl returned <url>http://www.thetvdb.com/api/GetSeries.php?seriesname=house%20s06e21%20help%20me&language=en</url>
12:19:47 T:2601012080 M:1405440000 DEBUG: FileCurl::Open(0x9b082b78) http://www.thetvdb.com/api/GetSeries.php?seriesname=house%20s06e21%20help%20me&language=en
12:19:47 T:2601012080 M:1405440000 INFO: easy_aquire - Created session to http://www.thetvdb.com
12:19:48 T:2601012080 M:1405599744 DEBUG: FileCurl::Close(0x9b082b78) http://www.thetvdb.com/api/GetSeries.php?seriesname=house%20s06e21%20help%20me&language=en
12:19:48 T:2601012080 M:1405599744 DEBUG: scraper: GetSearchResults returned <?xml version="1.0" encoding="utf-8" standalone="yes"?><results></results>
12:19:48 T:2601012080 M:1405599744 DEBUG: InternalFindMovie: Searching for 'house.s06e21.help.me' using The TVDB scraper (path: '/usr/share/xbmc/addons/metadata.tvdb.com', content: 'tvshows', version: '1.0.6')
12:19:48 T:2601012080 M:1405599744 DEBUG: scraper: CreateSearchUrl returned <url>http://www.thetvdb.com/api/GetSeries.php?seriesname=house%2es06e21%2ehelp%2eme&language=en</url>
12:19:48 T:2601012080 M:1405599744 DEBUG: FileCurl::Open(0x9b082b78) http://www.thetvdb.com/api/GetSeries.php?seriesname=house%2es06e21%2ehelp%2eme&language=en
12:19:48 T:2792934256 M:1405599744 NOTICE: WebServer: GET | /xbmcCmds/xbmcHttp
12:19:48 T:3054663552 M:1405599744 DEBUG: HttpApi Start command: GetCurrentlyPlaying paras: GetCurrentlyPlaying
12:19:49 T:2601012080 M:1405476864 DEBUG: FileCurl::Close(0x9b082b78) http://www.thetvdb.com/api/GetSeries.php?seriesname=house%2es06e21%2ehelp%2eme&language=en
12:19:49 T:2601012080 M:1405476864 DEBUG: scraper: GetSearchResults returned <?xml version="1.0" encoding="utf-8" standalone="yes"?><results></results>
anyone having issues with tvdb scraper today?
Ive added numerous shows to my library (fresh library, first additions) and it says "downloading information" but then just stops, no errors or anything come up..?
Help?
