I have got Twisted Melon's Mira IR Receiver
I installed lirc
configured it by Mythbuntu Control Centre to "apple mini IR receiver"
when I run irw and press some buttons on my remote (apple remote) the led light flashes but noting is displayed
i dont know how debug this?
If "irw" doesn't register anything when you press the remote buttons, you need to reconfigure lirc
sudo dpkg-reconfigure lirc
This should bring up the window to choose the receiver & remote for lirc.
After it's configured
and press the buttons on your remote to see if they register with lirc.
If no joy, reconfigure again choosing a different receiver & remote, until "irw" registers your remote key presses.
If you're using Ubuntu with Gnome try installing "gnome-lirc-properties".
it's a GUI for configuring lirc with a few more remote & receiver options.
Once you have a fully working lirc setup, if xbmc doesn't see your remote you need to map the keys. See this How-To by "Temar"
http://forum.xbmc.org/showthread.php?tid...mce+remote
how would you do this on live if you have no desktop?
thanks
abs
leadfingers Wrote:If "irw" doesn't register anything when you press the remote buttons, you need to reconfigure lirc
It's all be done in terminal
You can close the irw process with
from terminal i dont think you get the remote choice?
leadfingers Wrote:It's all be done in terminal
As far as I know, the Mira receiver is an eHome receiver. You should set it up as an MCE receiver.
