realize it is no longer supported, but is there an easy way to remove shutdown menu items so that only shutdown, logoff and the timer entries remain? if you accidentally hit quit, minimize etc problems arise.
nchall Wrote:realize it is no longer supported, but is there an easy way to remove shutdown menu items so that only shutdown, logoff and the timer entries remain? if you accidentally hit quit, minimize etc problems arise.
Should be easy to do. I'll add it to the next release.
and reboot too. forgot about that one, and it is actually the most important.
There's no reboot entry, only shutdown. And the action that is tied to that entry is determined by an XBMC user setting. So it either shuts down XBMC or it shuts down the entire system. Is that the one you mean?
well for instance on the pmiii skin there is a reboot entry on the xbox shutdown menu--this may be configurable on the skin level or maybe it depends on the build--not sure.
