Full Version: Rss podcast feeds in Music don't work
I added an rss feed to the music subsystem. I used Linux outlaws (great show by the way). I tried both the OGG and MP3 feed. (using using rss://feeds.feedburner.com/linuxoutlaws-ogg and using rss://feeds.feedburner.com/linuxoutlaws respectively). Neither work. I know XBMC will play ogg and mp3 files situated on the machine as I have and use both these sources with no problem.
The rss feed correctly shows the available podcast files but when you click on them it appears to download the file but then doesn't play it. the file progress indicator flickers between 0 and 1.
Is this a problem with XBMC 10 or something more general? Happy to provide debug logs etc if it helps to solve the problem.
Should I log this on the issue tracker?
It appears this is an issue. Two tickets on issue tracker about 9 months old have not resolved the problem.
ticket 7877
ticket 7757
