Full Version: Logitech Harmony Remote codes for XBMC
I have created a couple devices in the Logitech Harmony device DB that may be beneficial for XBMC users that own a Logitech Harmony remote.
The devices contain many Hotkeys and Shortcuts allowing the user more control with their Logitech harmony remote.
Here are the the 3 device users can add to their Logitech harmony account.
Device type: Computer -> Media Center PC
Manufacturer: Microsoft
Model: Windows Media Center SE
Model: Windows MCE Hotkeys
Model: MCE Keyboard
Below is a list of all the commands availible for the "Special Edition" Windows Media Center "SE" device, the MCE Hotkeys device als contains IR commands for shortcuts e.g Ctrl+Alt+F10, Ctrl+Alt+1 etc.
Win + - (plus or minus key) Zoom in or out.
Win-
Win+
Win+Up: Maximize
Win+Down: Restore / Minimize
Win+Left: Snap to left
Win+Right: Snap to right
Win+Home: Minimize / Restore all other windows
Win+T: Focus the first taskbar entry
Win+F: Open Windows search
Win+E: Open Windows Explorer
Win+Space: Peek at the desktop
Win+G: Bring gadgets to the top of the Z-order
Win+P: External display options (mirror, extend desktop, etc)
Win+M: Minimize all open windows
Win+1 / Win+2 / Win+3 etc (Hotkeys for programs added to the Quicklaunch)
Win+Tab: Flip 3D
Win+Shift+M: Undo all window minimization
Win+Home: Minimize all but the current window
Win + L: Lock the computer
Win + R: Open ‘Run’ command
Alt+1 / Alt+2 Alt+3 etc (Hotkeys for Video card display settings)
Alt+Esc: Cycle through all open windows
Alt+Tab: Switch to previous active window
Alt+Enter: Display properties for the selected item
Alt+Space: Pop up window menu
Alt+F4: Shutdown current window
Ctrl+A: Select all items in a document or window
Ctrl+C: Copy the selected item
Ctrl+X: Cut the selected item
Ctrl+V: Paste the selected item
Ctrl+Z: Undo an action
Ctrl+W Closes the tabs for most web browsers
Ctrl+Shift+Tab: Left Navigation through the web browser tabs
Ctrl+Tab: Right Navigation though the web browser tabs
Ctrl+ESC: Opens the Start menu
Shift+Del: Permently deletes an item and bypasses the recycle bin
Shift+F10: Opens Shortcut Menu
First off you took this almost word for word from a post on the logitech forums here: http://forums.logitech.com/t5/Harmony-Re...m-p/374844
Also this info isn't all that helpful for XBMC use. The info that is really needed is the Keyboard config and there is already a number of posts for that.
